Samsung NX1 issues
  • A lot of early Samsung NX1 users are returning their cameras on account of an ugly exposure bug in the NX1's 4k video. There's an odd, and so far unfixable glitch in the camera when in full manual video mode. The camera randomly hunts for exposure, even when locked down. You'll see the brightness increase and decrease randomly, even if the light doesn't change and the camera doesn't move. The symptoms are worse when you pan or tilt from an overexposed area, such as a light, to a dark area, you'll see the camera hunt around for exposure as if it's set on AUTO, problem is, this is in FULL manual mode. Many say a firmware fix can solve it, but Samsung already released v1.1 and this issue wasn't addressed, so people don't want to gamble that Samsung will fix the issue. So cameras are going back. Look for USED NX1's on the shelves of B&H and on ebay. It's still a great still cam, but video functions weren't done right. Until it's fixed, IMO this camera isn't viable for serious video work. sample:
    locked down, still getting exposure drift
  • 29 Replies sorted by
  • It has been figured out. I'm relieved to say, it wasn't the NX1's fault at all, nor the fault of iFFMpeg's converting. The editor was importing the files into FCPX with the option to "remove silent channels" checked, and FCPX was removing good channels on longer video clips. (I'm shooting weddings so obviously that would be the important clips like ceremony/toasts/dances.)
    The only other issue I've encountered in several years with the NX1 as my main camera is occasional corrupted files. It seems to happen if the REC button initiates a clip and then is pressed very soon after (<4sec). These ultra-short clips become corrupted, and that wouldn't be terrible except for the camera will often freeze up when trying to initiate recording of the subsequent file. I suppose that the corrupted file is confusing the sequential file numbering system somehow but IDK. Pulling the battery to reboot doesn't always clear the issue, as the file recorded that freezes the camera will also be a second corrupted file, perpetuating the issue. Taking a picture instead of a video often helps, or just being very patient with the camera when starting up . . . switching into movie mode . . . and . . . hitting the REC button.
  • Yeah these are h.264 files I've converted.
  • @B3Guy My workaround was to transcode this particular file to ProRes in EditReady and import that into the project - clip plays back normally now.
  • Possibly. The person I sent the clips to is using Final Cut Pro X. They've checked the clips with QuickTime (though if QT is having an issue, it's likely FCPX would have the same one). I'll tell them to check with VLC.
  • @B3Guy Well this is interesting: I'm editing a project in Premiere Pro CC using the native NX1 .h265 files. Things have been going smoothly until tonight when I noticed one clip whose sound goes out midclip (playing back within PP). Playing the clip in VLC is fine other than the expected stutter. The sound is there, it's just PP that isn't playing it back properly. Could this be the same issue that you are having?
  • My NX1 hasn't exhibited this audio issue. If the problem is intermittent, I'd suspect a loose connection internally or some part that has become damaged. Which brings up the question of where you would take an NX1 for servicing.
  • @B3Guy are you using the onboard mics or an external mic?
  • Has anyone had issues with the NX1 not recording audio? I've had this now on several occasions. Certain clips having NO audio, when others on the same card are fine. I know that slow-mo is silent, I'm talking normal frame rate clips. Getting my butt reamed for delivering these clips like this, and it's honestly starting to seriously frustrate me as I can't source the problem and I don't feel like having to wear headphones comstantly while recording.
  • @brianl:
    Yes I know plural eyes and also final cut pro x has something like this on board, but as I said, I would forget to press the audio recbutton sometimes and so the clip would be unusable.
  • Angry-C, have you tried plural eyes? I always use double system sound with dslr shooting. It's pretty painless with plural eyes.
  • Hi guys. Vitaliy, please give brianl a hug cause I'm the one who has been spewing emotions and panic over the NX1 :(
    Sorry about that. I posted the first video in the op. The users who have not experienced the bug seem all to be on firmware 1.0
    I have been fiddling more with the menu. I never thought of trying A,S and P dial mode and then enable video :P
    Well there's a reason for that, you don't have full control of shutter speed, ISO, f-stop. Different for each mode of course. I would never shoot with these modes.
    But.....the ISO shifting is not happening in these modes, yes the camera adjusts itself because something is on auto in these modes, but here it behaves like I would expect it to.
    Then I go back to manual on the dial. Check if SmartRange+ is off in both photo and video menu. Set metering to center, and voila.....the shifting stops.
    Wow this is weird. But tells me this is definitely a bug and can be fixed with firmware......right?
  • @DrDave
    I film only privately and often spontaneous. I would often forget to press the recording button. And then I have to sync all audiotakes on video, etc. No, that would be too cumbersome. It would be different if it were timecode triggered, but it is unfortunately not.
  • @Angry_C Just buy a simple audio recorder.
  • @brianl:
    I checked the exposure issue. I don´t know why, but in manual mode the exposure bounces, this is a fact, but in A/S/P mode with locked AEL the exposure doesn´t bounce. This is strange. Is there any setting which causes this?
  • @Vitaliy:
    I doubt that samsung will fix the audio engine, so I have to determine if I can live with this fact. Fotunately I´m alowed to return the camera until 31 of january. I wonder why no one else noticed the poor audio quality.
  • @Angry_C
    I doubt that bitrate make things "noisy". 128kbit AAC is quite good bitrate if you do not make heavy audio processing.
    All else must be fixed by firmware.
  • Another Issue is the bad audio quality.
    • only very noisy 128 kbit/s aac
    • automatic gain control which cannot be turned off
    • noisegate which cannot be turned off, so quiet sounds will be mutet completely!
    I´m thinking of returning the nx1. What a mess, I´m liking the image quality a lot!
  • @brianl Followed this on eoshd and was also able to recreate some subtle shift while playing around in movie preview mode. This hasn't bitten me yet on any real recordings though. But I agree it's a bug, and one I'm sure the camera's large dev team will squash soon. It's not true that everyone who tests can recreate it though - some are still claiming its user error.
    It reminds me a bit of the issues that the BMD cams had for a while, and there were howls of that platform being a joke for pro use - and the used market will be flooded with useless cameras, etc. Soon the dust settled and the issues were patched, those cameras are used reliably across the world now. Any new system will have kinks to iron out. Dave is right that we are beta testing.
  • Preorder=beta tester.
  • @vitaliy Can you please just give me a hug?
    ha ha ha @briani ... best comment of the year so far, just precious =)
    C'won @VK to kill the bugs what about some scientifically free hugs? :P
    A good weekend for y'@ll
  • @racer5 Yes I get it. Playing with framing mode and shifting back and forth between metering modes clears the glitch but then it comes back again. So far, I haven't read any comment like "I have that NX1 and it doesn't exposure hunt like that." Everyone who tests for it, seems to bring it up. Sorry, no charts or data sets to support my claims, but it's definitely the cause of some web chatter over the last few days.
  • @brianl
    Again, do not jump on conclusions and do not add emotional part.
    As even few comments and posts I read are conflicting.
    Such thing need normal, systematic test case, simple to repeat and report.
    With extensive test of various settings that can affect camera behavior.
    Anyway, it is not "killer flaw" of camera, at worst it is current version firmware issue.
