Spec
Samples
PR
Look into the bag of nearly any Nikon-wielding pro and you will find Nikon’s iconic 24-70mm f/2.8, and with good reason; this lens’ versatility and image quality has made it an essential workhorse lens for every type of shooter. The new AF-S NIKKOR 24-70mm f/2.8E ED VR improves upon its respected predecessor in nearly every aspect, adding the best Nikon lens technologies to create an essential optic. An exciting evolution to come to this lens is the much-anticipated addition of Nikon’s Vibration Reduction (VR) image stabilization technology. With up to four stops of image stabilization*, the new 24-70mm f/2.8 VR is ready to tackle the challenging light of a wedding ceremony or on-the-spot news, while Tripod Mode helps to banish blur for landscape shooters. VR is also a huge benefit to filmmakers shooting handheld or on a rig who already appreciate the lens’ depth-of-field control and precise sharpness.
The new NIKKOR 24-70mm f/2.8 utilizes Nikon’s Electromagnetic Aperture control, which allows for consistent exposures during high speed bursts of shooting. This lens also improves upon image quality with new optical construction to provide clarity and consistently sharp images, and is ideal for capturing portraits, landscapes and weddings. For nearly any assignment in any kind of light, the combination of a fast f/2.8 constant maximum aperture and useful zoom range make this lens the choice of many professionals. A first for NIKKOR lenses, a new Aspherical Extra-Low Dispersion (ASP/ED) element is paired with traditional aspherical, ED and High-Refractive Index (HRI) elements for a thrilling new level of optical precision. Photos and videos take on a beautiful balance of sharpness and subtle blur effects, virtually free of flare, ghosting, coma and chromatic aberration throughout the frame. Nikon’s exclusive Nano Crystal Coat is also employed to further reduce instances of ghosting and flare.
The new lens construction enhances durability and image quality, while retaining the overall balance and handling that made this a favorite of photographers in the first place. The lens is sealed and gasketed against the elements, and now features a fluorine coating on the front and rear element to make it easier to remove dirt, moisture and smudges from the lens surface. The optical formula consists of 20 elements in 16 groups, while a 9-blade diaphragm helps to create a pleasing, natural out of focus area with beautiful bokeh. Additionally, the AF-S NIKKOR 24-70mm f/2.8E ED VR features a new filter diameter of 82mm and will accept the new Nikon CPL2 Circular Polarizer and 82mm NC (Neutral Color) filters.
                  Review
Contrasts and microcontrast are excellent, the quality of photos are at first glance, outstanding, detailed review, confirmed excellent tonal range that lens defines. Sharpness is excellent in normal ranges.
http://foto-info.si/review-of-nikon-af-s-24-70mm-f2-8e-ed-vr/
                  Lens is postponed till October.
The new Nikon AF-S 24-70mm f2.8 VR surpasses old lens with robustness of construction, built-in image stabilization VR, faster AF drive. The new Nikon AF-S 24-70mm f2.8 VR has much less chromatic aberration CA and is better suited for shooting in the opposite light, where ghosting and flare effect is less noticeable.
http://foto-info.si/primerjava-nikon-af-s-24-70mm-f2-8g-proti-nikon-af-s-24-70mm-f2-8vr-2/
                  Interview about lens in Japanese at
http://dc.watch.impress.co.jp/docs/news/interview/20151022_725581.html
Lens will be in stock later today - http://www.amazon.com/gp/product/B013D1BMFE/
At 24mm results are excellent from the start, peaking at f/8 and only really dropping significantly to very good levels at f/22. The edges do lag behind, but are already approaching very good levels wide open and peaking at around f/11. An overall very impressive performance.
35mm follows this with another impressive performance, excellent throughout and peaking at f/8. Sharpness does dip at f/22 but remains very good. The edges maintain a good to very good level of sharpness, except at f/16 and f/22 where performance falls off, reaching only fair levels at f/22. Nonetheless, still impressive, especially in the center.
At 70mm sharpness is lower at f/2.8, but still very good. This becomes excellent by f/5.6, peaks at f/8 and maintains this level well at f/11.
https://www.ephotozine.com/article/nikon-af-s-nikkor-24-70mm-f-2-8e-ed-vr-review-28783
The Nikon 24-70mm ƒ/2.8G VR provides excellent results for sharpness, even when used wide open at ƒ/2.8. Stopping down the lens provides slightly better performance, but not the night-and-day results we sometimes see from other lenses.
http://www.imaging-resource.com/lenses/nikon/24-70mm-f2.8e-ed-vr-af-s-nikkor/review/
