Canon XA35 XA30
  • Canon Australia today announces the addition of two handheld video cameras to its X-series, the XA35 and XA30. Designed for professionals and enthusiasts alike, the highly compact and lightweight models feature a newly developed HD CMOS Pro sensor which provides higher sensitivity and improved low-light performance. Both cameras also include new Wide Dynamic Range (DR) and Highlight Priority settings, making them suitable for shooting everything from news and documentaries, to weddings and corporate films.
    First-class image quality and video processing performance
    Utilising Canon’s heritage in optical expertise and advanced technologies, the newly designed 1/2.84-type 2.91 megapixel HD CMOS Pro sensor has enhanced sensitivity with improved signal-to-noise ratio. As a result, images are crisp and clear, even in low-light environments. Low-light shooting opportunities are further boosted by improved infrared performance, ideal for users capturing nocturnal wildlife or night-time documentaries.
    The 20x zoom wide-angle lens offers a 26.8-576mm (35mm equivalent) focal range and employs Canon’s intelligent 5-axis Optical Image Stabilization System with Dynamic IS. The lens also features an 8 blade circular aperture to give enhanced ‘bokeh’.
    The XA35 and XA30 features two new settings – Wide DR and Highlight Priority. In Wide DR mode, the cameras are able to achieve 600% dynamic range, resulting in bright images with high contrast that retain detail in both highlight and shadow areas, without the need for post-production. When using the High Priority settings, users are able to produce footage with more natural tones and richer colours, particularly in areas of high brightness1, perfect for scenes with bright skies and reflective surfaces.
    Both models also feature slow and fast recording modes, supporting a range of shooting scenarios with interval recording options up to a maximum of 1200x normal speed.
    Discreet and portable, ideal for on the move
    Compact and lightweight, the XA35 and XA30 are perfect for journalists who often need to record discreetly whilst on the move but don’t want to compromise on quality. The cameras are also exceptionally easy to use, featuring extensive automatic functions, ideal for corporate and education environments.
    The XA35 and XA30 have the same popular ergonomic design as seen in their predecessors, the XA25 and XA20. Easily attached or removed to suit the shooting situation, the removable handle with professional audio XLR terminals provides maximum flexibility for users.
    Integration and connectivity
    Featuring a HD/SD-SDI terminal, the XA35 will integrate with existing equipment for onward transfer or transmission, and includes embedded audio and timecode signals. Providing users with the ability to export uncompressed high resolution digital video in real time, it’s the perfect compact camera for live TV and news gathering environments, allowing users to complement footage from other broadcast cameras on-set.
    The cameras also support high quality AVCHD (up to 28Mbps) and MP4 (up to 35Mbps) file formats and include dual SD card slots, providing instant back-up through simultaneous recording or the option for relay recording at longer events, ideal for wedding videographers.
    Both the XA35 and XA30 are dual-band Wi-Fi enabled which allow remote control of the camera, wireless file transfer/upload and browser preview, all with the use of a smartphone, tablet or computer. The cameras are also compatible with Canon’s GP-E2 GPS receiver, meaning GPS data can be embedded in the metadata of video footage. This feature allows accurate recording of the location where footage was captured, ideal for both journalists and documentary purposes.
    Availability
    The XA35 and XA30 will be available from December 2015.
  • 4 Replies sorted by
  • @davedv
    It happens because firms now can not allow development of new LSI due to low sales of camcorders and compacts.
  • Seems like a pretty minor upgrade over the XA20 and XA25. Same 1080p resolution, relatively low 35 Mbps bitrate. Supposedly the sensor has slightly better low-light performance (+3dB increase in sensitivity according to Canon) and the Wide DR mode sounds interesting, although we'll see how well it works.
    Can't help but wondering what the point of this upgrade is. Sony PXW-X70 is $500 less than the XA35 but the X70 has a larger 1" sensor and shoots higher bitrate 4:2:2 10-bit in 1080p. Or get the 4K upgrade and you're still at the same price as the XA35 which is 1080p only.
    Almost as if Canon pretends they don't have any competition.
