I am looking for a bigger (but not $3k+) mattebox as well.
As my biggest lens is 111mm outer diameter and has wide angle with a field of view width of 100mm +16mm for each 10mm distance from lens (I hope you understand what I mean: a filter at 20mm from the lens will need to be at least132mm width). I would like to get a mattebox to use with two polarizers (variND) as it is not possible to screw a filter to the front of the big lens. As far as I understand I will need a mattebox that facilitate at least one 5,65x5.65" filters (rotating stage) plus one or two fixed stages of at least 4x5,65. Are there any on the market except for the very expensive Vocas MB450 or Arri MB20?
Maybe @o2x could change this topic title to matteboxes for bigger and/or wide-angle lenses > 4x4" or 105mm)?
Well, post-NAB things haven't changed too much with regard to matte boxes - but there are a a couple of additions:
This one is 4x4, but at least it has 3 rotating stages... http://swedishchameleon.se/?page_id=1976
This looks great, 3 stages of 4x5.65 PLUS a 138mm round. Alas, looks like the 138mm round is the only stage that rotates http://www.letusdirect.com/cart/letus-matte-box.html
And a new Vocas model which looks excellent. Only problem is buying flags and extra trays as accessories can quickly mount up http://www.vocas.com/news/new-mb-430-matte-box-launched-at-nab
I still think there's room at the lower end of the market for a well designed and priced matte box that actually works that way a matte box should. Until then, I have to agree with SMSJR above, you get what you pay for.
