MJPEG FPS setting for Timelapse on GH2
  • 128 Replies sorted by
  • @ricker, the settings in MJPEG are completely separate from AVCHD. I am using Nick's SpanMyBitchUp and the settings for MJPEG from Low Light. I get pretty good bit rates from MJPEG if I don't set the 2fps. But as soon as I set the 2fps, I get only 6 to 7 Mbps for mjpeg. The AVCHD is unaffected though.
    Do a search for 100mbps MJPEG Low Light by LPowell and you will find the setting. Put the settings in and then set the 2fps for timelapse.
  • I still use this tool, very easy to use, here is the video i done with, shot on gf2.
  • Some great cloud shots there - thanks for sharing!
