The dealer in Kyle, TX is closest to me....it's 3:00am as I type this....assuming he has some in stock, and he lets me come down and video it, the soonest I could have a video up is around 30hrs...IF I had a c mount adapter. So, realistic best case is 3-4 days... after ordering a c-mount adapter off Amazon.
if it is a rebranded Kowa lens then it is from the new XC line... but there 12mm isnt that fast rated at f/2 from kowa... but then again perhaps it isnt seeing as how the Kowa XC is a 4/3 designed lens, and the new 12mm hyperprime still has some vignetting
That's an 8mm "Machine Lens" and it almost covers the whole sensor. That lens is for 1", a lot of the other CCTV lenses posted are for 1/2 -2/3". The thrid link I posted has model numbers for 8mm-75mm but the 75mm is f1.8, all the others are f1.4.
yeah that lens nowhere near covers... that vignette is BEYOND unacceptable... the only lenses I would EVER buy from kowa are the XC series because I know they have greater than 23mm image circle... but they are also slow at f/2... seing as how I have my LOMO prime set from 28-135 all f/2 (actually f/1.8) I wouldnt buy slower cctv lenses
Ugh...I'm not talking about 4/3", I'm talking ONE INCH! That lens doesn't cover and it's 8MM - ONE INCH!! They have 12.5 and 16mm, up to 75mm.
If the 12.5mm is the same as the Noktor 12.5mm then that means you could order a Kowa for $254 instead of a Noktor for $500. If only somebody lived near a Kowa dealer that had these lenses in stock. I already called two places near me and nobody has one.
@Vitaliy_Kiselev I'm not that dedicated or rich. If I'm going to spend that much I'm going to keep it and I want a sure thing. I also emailed a Goyo dealer to see how much they sell the F0.95 that the Noktor is supposed to be based on, but so far nothing.
That's why I'm asking if anybody in Cali that lives near the Kowa headquarters, if they can do it.
your basing your information on the rantings of another user... I doubt that the slr magic lens is a 1 inch kowa... because the 1 inch kowa 12.5 is NOT going to cover the GH line sensor
The video I reposted above shows that at 8mm, it covers a lot. That video is a 12.5mm Computar on a GH2, pic below of it's crop..
That 8mm has less vingetting than the 12.5mm no? Why? One inch lens vs smaller cctv lens. Also the 1" lens is a machine lens for industry not a CCTV lens for surveillance. That's why this topic is titled "road trip" so if someone lives close to Torrance, CA or another Kowa dealer, they might be able to attach a 1" lense or two to a gh1/2 and get some REAL evidence or sample footage. My local dealers don't have them in stock for me to test.
f2 is slow... when you are used to shooting with RPP and MasterPrimes also Lomos that act EXACTLY like masterprimes... I agree that the XC line should be tested but they are just WAY too much...
i understood what you were getting at by comparing the computar 8mm and 12mm (which everybody else couldn't seem to comprehend) but they're probably made for different size sensors.
sorry to disappoint but the slr magic lens isn't a kowa.
@RandyCatanach That is not the current Kowa 12.5mm lens. Its an older version from a vidicon camera. That about 30-40 years old. Look at the posters comments. The new version of the 12.5mm lens - which has been discontinued too, may still cover the sensor.
@CRFilms hmm i think on a gh2 it wouldn't be as tall but would be wider. so that particular lens would still vignette but yeah, as @zcream pointed out i guess it's actually a different lens. might want to pursue the newer model lens still.
@RandyCatanach Yeah, but with the GH2 you can do the crop, the GH1 can't that's why I'm interested in this. Even if somebody did the test and the 16mm=35mm worked, I probably wouldn't get one new. You can get a Canon FD 1.4 for around $80-90.
Or I'd try and shoot the moon and go for a Goyo F0.95 lens(what they say the Noktor 50mm is a rebadged version of). The 50mm is around $700 and the 25mm is under $400, but don't know if it will cover since it's also a 1" lens.
The Kowa 4/3" XC lenses are around $1000....so for that money, just go for a real Nokton. Under a certain $, I just want the cheapest that's good enough, but if I have to spend serious cash, then I'll go for the best.
@TheMonk I have no Idea what adapter because I have no C Mount lenses. I'd like to see the F0.95 lenses. If they fit or can be made to fit, those would be the cheapest lenses of that speed.
@CRFilm Buy the cheapest c-mount adapter off ebay. It will screw on over at least a couple of threads but not all the way. Dont worry, it will only affect focusing distance, not the sensor coverage. Take a pic of anything and post it here so we can check coverage.
