These rumors based on inactivity - no new cameras - seem unaware of all the firmware updates to the existing cameras. The NX1 with the latest firmware could have been named NX1 II (following Sony marketing) it is so improved over the original offering.
Most of such posts originate on some forum, later post in another site and reposted :-)
But Samsung cameras distribution state is in horrible shape now. Mostly due to their management structure and egos, as camera branch do not want to have anything in common with smartphone one. And do not use existing distribution network.
I hope it's just a dumb rumor... http://photorumors.com/2015/09/18/is-samsung-shutting-down-their-camera-business/
With: Samsung 45mm f1.8 Rokinon 12mm f2.0
@geoffcbassett Now all we need is a video card that fully handles the H.265 codec.
a fine example of 16-50 premium lens usage and some nice cinematography
Finally!
http://blogs.adobe.com/premierepro/2015/09/premiere-pro-cc-ibc.html
H265 support coming to Premiere in the next update! Waaahooo!
NX system has one issue - too small :-) So manufacturers have little interest.
I hope we'll have a NX-EOS fast AF adapter soon :)
Proper lens for cheap.
http://www.bhphotovideo.com/c/product/1024768-REG/samsung_ex_w16anp_us_16mm_f_2_4_ultra_wide.html
                  New NX1 review from HD GURU (of Sept. 4th, 2015)
Conclusion:
The NX1 delivers both professional quality stills and spectacular pro-quality video.
As a still camera the 90 JPEG@1/8,000th second continuous image burst at 15fps surpasses cameras three times the price. With that kind of latitude the need for neutral density filters disappears.
The SRW RAW files contain a spectacular amount of image data that can be easily and creatively adjusted in Lightroom and Photoshop, or enjoyed straight from the camera. This is where the built-in creativity of the Smart Shot, Picture Wizard and Smart Filters come into play. And the built-in Wi-Fi allows emailing an image directly from the camera or a connected smartphone.
The video performance is stunning. Having tested it in low light on a night shoot of a Hollywood movie and in the overpowering brightness of a sunset, the camera consistently outperformed expectations.
There has been a lot of attention given lately to RAW and flat S-LOG file shooting, much of which has been overblown and misleading. While the NX1 does not offer a super flat image, a properly exposed shot can be adjusted in post to do everything that a flat profile can offer. Indeed, on the set of “Kickboxer Vengeance” the consensus was that the Samsung NX1 could be used side by side with the Red Epic footage in post production. You simply can’t expect better than that for a sub $2,000 camera.
Although there are adjustments for Luminance Levels and Master Black Levels these are not designed to expand the dynamic range but rather to match other cameras in given shooting environments. The base settings in combination with the Gamma DR setting grants the widest latitude in true dynamic range.
I found it very easy to use the Touch AF for set up of focus during those hectic points in shooting behind the scenes on a stunt-filled action movie. In fact, I was even able to pull off rack focus using the Touch AF and the AF Responsiveness adjustment in the menu. The results were as smooth as using the lens control but without needing a second-person focus puller.
When I had the time, the 1280×720 viewfinder was sharp and spectacular and the manual focus switch on the lens barrel was easy to access.
Where the NX1 could be improved is stepping up to 10-bit color depth, 4:2:2 color sampling and 4k 60p frame rates. Enabling 10-bit, 4:2:2 instead of 8-bit 4:2:2 from the HDMI port would bring the ability to use an Atomos Shogun, or similar video recorder, to its fullest potential in external video recording.
Audio has always been a weak link in all mirrorless cameras but the newest firmware upgrade has taken the first step in improving the external audio capture. But still more needs to be done.
The use of H.265 is a definite long-term advantage enabling storing twice as much as H.264 while maintaining professional quality standards, and as an added bonus there is no need for ultra-fast SDHC cards, which are prone to overheating issues and failure.
For serious amateur or pro-level photography and videography, there is no other camera in this price range that delivers the bang for the buck that the Samsung NX1 camera does.
http://hdguru.com/review-samsung-nx1-4k-mirrorless-compact-system-camera/
@JFKa It's really a beautiful video regarding the picture quality, so good! I'd definately go for the NX1, but since I have two voigtlander noktron micro4/3 prime lenses..
This superb video made by my mate Macgregor was made fully with a NX1.
What this all mean? You need long lens?
What's happening, Samsung???
                  @markr041: Simply stunning! All your videos are very inspiring. Keep them coming!
I did my own tests yesterday evening and found that the DIS + OIS (16-50mm S lens) tears on most non-quasi static shots - as it's to be expected. But for hand-held static takes, and even limited (slow) paining in FHD, it works pretty nice.
Here is an example of why DIS is such an important breakthrough. This is a video of close-ups of insect life on flowers, shot with a 90mm (35mm-equivalent) macro lens handheld. You cannot efficiently shoot dragonflies, butterflies and bees at work with tripods - these insects move around and you have to "capture" them opportunistically - you have to be able to move after them with camera and shoot while they are in place. Without stabilization, the close-up video would be unwatchable - jitter and shaky. Well, here is what you can get using the NX1 with DIS and OIS combined:
DIS test with lens that has no OIS - the NX 45mm f1.8.
The first clip in each scene has DIS turned off.This handheld 4K video consists of clips shot without and with NIS turned on of stationary objects to assess the effects of NIS when the subjects have no motion. The NX 16-50mm S lens was used at the long end:
My 10-24mm Tamron has a Pentax mount with Fotasy Pentax PK Manual lens to Samsung NX Mirrorless Camera adapter (Amazon). I just shot a short handheld clip with DIS on with my Pentax mount 15mm F2.8 Sigma of a Bee at minimum 5.9" focus.
