I have a Panasonic v770 Camcorder.
It ouputs mov/mp4 files.
With QT Pro on Windows I can Trim and save without encoding. I'm looking for a similar workflow on Linux(Ubuntu/Mint).
Some of the linux apps such as Openshot do have mov/mp4 output but restricted to 40 Mb/s.
Format : MPEG-4 Format profile : Base Media / Version 2 Codec ID : mp42 File size : 850 MiB Duration : 2mn 37s Overall bit rate mode : Variable Overall bit rate : 45.2 Mbps
Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.2 Format settings, CABAC : Yes Format settings, ReFrames : 2 frames Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 2mn 37s Bit rate mode : Variable Bit rate : 45.0 Mbps Maximum bit rate : 49.2 Mbps Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 59.940 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.362 Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709
Audio ID : 2 Format : AAC Format/Info : Advanced Audio Codec Format profile : LC Codec ID : 40 Duration : 2mn 37s Source duration : 2mn 37s Bit rate mode : Constant Bit rate : 256 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Compression mode : Lossy Stream size : 4.76 MiB (1%) Source stream size : 4.76 MiB (1%) Language : English Encoded date : UTC 2015-08-15 23:12:14 Tagged date
if you really want to edit, you can try blender VSE, it takes many formats as they are, too!
Depending on your preferences for GUI or command line, try avidemux or mpv with the excerpt plugin.
