Hobbyists, photo enthusiasts and professionals alike will be captivated by the M.ZUIKO DIGITAL ED 8mm f/1.8 PRO Fisheye lens' 180-degree diagonal angle of view. Like the M.ZUIKO DIGITAL ED 7-14mm f/2.8 PRO, this lens includes dustproof and splashproof construction, for unlimited wide-angle adventure. The lens is also compatible with a custom dome port for use with an Olympus underwater housing.
The M.ZUIKO DIGITAL ED 8mm f/1.8 PRO Fisheye lens is constructed of 17 elements in 15 groups and can capture high resolution at the very edges of an image, even at the maximum aperture of f/1.8. ZERO Coating minimizes optical flares and ghosting. The lens also comes with a fixed lens hood and a pinch-style lens cap LC-62.
From under the sea to the night sky, the record-breaking new M.ZUIKO DIGITAL ED 8mm Fisheye 1:1.8 PRO is an unprecedented opportunity to add stand-out creativity and a uniquely dynamic and abstract look to extremely wide-angle shots of the natural world. Unprecedented, because – in this category – the Fisheye PRO is the world’s brightest fisheye lens*. The super-large aperture ensures photographers top-notch optical performance in any conditions, especially in low light. The 2.5-cm minimum focusing distance (measured from end of the lens) and maximum magnification of x0.2 make it a logical choice for nature photographers with a passion for quirky perspectives and eye-catching bokeh.
But the Fisheye PRO is also ideal for fast-action sports photography; landscape, nightscape and sky panoramas; as well as crowds, interiors or architecture. For underwater specialists, it likewise opens up exciting new opportunities – it’s compatible with a range of accessories via the new underwater lens port PPO-EP02.
Like the other lenses in the M.ZUIKO PRO family, it’s extremely compact and lightweight, especially compared to equivalent D-SLR rivals. The build quality is top notch. In pre-launch tests, professional photographers were quick to praise the blur-free performance of the Fisheye PRO at both ends of the f stop scale. Light fall-off at the edges is negligible, as are both chromatic and comatic aberrations, particularly when compared to equivalent rival lenses.
New firmware v1.1
https://cs.olympus-imaging.jp/en/support/imsg/digicamera/download/software/fourthirds_olylens.cfm
Lots of fisheyes have no rear filter :-)
Fisheye has no rear filter?
Olympus has created something unique. Not only will the fast aperture allow for shooting in low light conditions with the expansive field of view you'd expect of a fisheye, but it also delivers outstanding sharpness and robust build.
http://www.ephotozine.com/article/olympus-m--zuiko-digital-8mm-f-1-8-fisheye-pro-review--27780
