In usable lower iso Gh1 grade a way better and look like has more DR (For me) Same may say GM1 is more "cinematic":) but not for me. I compere them 2 cos M1 has low bitrate AVC but newer. GH1 miss just better iso performance:) but/and is wider! Both the same f1.7 500 iso200 standard all -2 straight from camera snaps from timeline
In my researches about GH1 previous patches, seeing streamparser screenshots, and comparing to the GH2 behavior, I perceived that in GH1 the I frames size can be very big and P frames size can be very small in size.
So, when increasing the datarate in GH1, the I frames size can become a problem for the frame buffer and frame limits, because they become too big. Also the GH1 options in PTool do not provide complete settings to tweak the frame limits and frame buffer as we can do in GH2.
The solution for this would be to tweak the GOP TABLES to keep the I frames size within something about 5:1 compression ratio which is pretty good quality for an I frame and this would keep the I frames size to be not too much big and the camera limits and buffer could work ok even with higher datarates. The GOP TABLES shares the data among the I and P frames and can make the I frames size bigger or smaller, when it increase I frame size it decrease P frame size, and when it decrease the I frame size it increase P frames size.
In my math calculations I perceived that 32Mbps with Overall 34 can probably be the maximum stable for the camera, after I found some informations about the maximum frame size which is possible for the GH1 to handle.
So finding the GOP TABLES in GH1 firmware and allow to tweak it in PTool can be very useful to achieve higher stable datarates. Also useful to get better noise and texture avoiding mud because bigger P frames are welcome to do this.
@humpman thanks for the streamparser screenshot. it shows and confirms what I was wondering to see: the average I frames size is about 8x the P frames size. This is useful information to create a patch which keeps the frames size under camera limits.
I developed a patch which has the gop and datarate tweaked to keep the I frames size under the constant values considering this 8x ratio between I and P. This patch is tweaked for 720p and 1080p, pal and ntsc, with custom matrix.
please give it a try, and remember to record more than 20 seconds in each take to get a better streamparser file reading:
@konjow keep user.ini file in same folder of ptool, it will enable the user patches for matrix and qp. If you can, please try the patch inside the "i-p_8x.zip" in my previous post, it should be stable and good quality.
@humpman I saw the patch and user, in the user there are new things after scalling tables for p frames (E2, E3, E4, E5, E6, E7, with new arrays) what are these for?
your screenshot shows the I frames very big and P frames very low size. decrease I frames size is important for stability, but just the GOP TABLES can do this, is there a chance for you to find it?
thanks
@humpman @apefos I did quick test for spanning. And the results are:
setd: motion error quite often unless camera steady like rock on sandisk extrim 45mbs 32gb pictures attached
ip8x atrefacts over the place unless camera steady like rock 2 pictures attached -files can't be play by QT(black screen)
@humpman little lower please :)
the patches and user file below are revised and correct. if they do not work, so I will need the GH1 body to do tests...
@humpman, please, can you confirm if the user ini file below is correct? are the offset values correct for both interlaced and progressive? are all typo correct? thanks.
