I just keep thinking, (Canon did it back in the day with the xl2) I suppose the larger sensor makes a big difference and they want to keep the size down...oh well, maybe it will pair well with the gh4, or gh5 whenever it comes out...
Here's another video:
@matticusmaximus As you zoom in and that lens needs to stop down, these camcorders (generally) gain up to compensate. They can also offer a reasonable smooth servo zoom, built in.
So what kind of "Extra Control" do they get with the lens by having it built in? They mention it in that last video, but it makes no sense to me...
I can see those people still use EX123/P2 cams (I still see them used at weddings too!) can upgrade to this one, the quality is much more improved.
It does . . . Leica Dicomar 4K F2.8~F4.5 zoom lens (4K/24p: 29.5 mm ~ 384.9 mm, HD: 28 mm ~ 365.3mm, 35 mm equivalent),
But a 14-180 2.8 4.5 lens is pretty good for Weddings!
Not too much info @ Panasonic's site. I am sure this f2.8 lens stops down when zoomed in. http://pro-av.panasonic.net/en/dvx4k/index.html
Yep, sure, this must be something that I do all the time with GH4 and other m4/3 cameras, continously just adjusting the flange back distance. :D
I have spent more time than you can imagine adjusting flange back distances on many different lenses, and I wouldn't have it any other way. :) Love me those interchangeable lenses.
Panasonics way of looking forward is looking back (but even further).
Surely it is 8bit 4:2:0 AVCHD only too?
@matticusmaximus Lets hope that after they realize that the disturbance/shockwaves they expected this thing to create will likely be equal or smaller than what the AF100b "update" created - they do remove that lens.
Panasonic: give us a version without the lens please! (and make the one attached a removable one before launching the thing)
They have really tried their best to find any and all excuses for the fixed lens :) so they do realize that its a bad idea...
"...there is no need to perform the flange back adjustments or shading corrections when changing lenses."
Why in the world did they not just make the camera have a detachable servo lens that it comes with?!...like an xl2 for example? So Limiting!
DVX100 sold very good many years ago. DVX200 must sell even better. (c) Panasonic logic
PR
Panasonic has announced the AG-DVX200 4K large-sensor, 4/3” handheld camcorder here at NAB 2015. The DVX200 will offer many top-end features including 4K/60p* recording, a 13X optical zoom and a V-Log L gamma curve (12 stops of latitude, target).
Delivering a shallow depth of field and a wide field of view, the DVX200 is the ideal companion camera to the company’s groundbreaking VariCam 35 4K camera/recorder. With an integrated lens design, the DVX200 will excel in independent film and documentary production, as well as event videography.
The DVX200 will be optimized for 4K/HD production, and shares the esteemed VariCam family characteristics of filmic tonality and colorimetry, with natural, subtle rendering of skin flesh tones, and a V-Log curve emulating the natural grey-scale rendition of the VariCam 35. The camcorder will incorporate a newly-developed 4/3” large-format MOS sensor and offer variable frame rate recording up to 120fps in FHD mode, enhancing the DVX200’s utility in sports and VFX production.
The new handheld 4K camcorder will offer an array of professional features including a newly-designed Leica Dicomar 4K F2.8~F4.5 zoom lens (4K/24p: 29.5 mm ~ 384.9 mm, HD: 28 mm ~ 365.3mm, 35 mm equivalent), time-code in/out, 3G HD-SDI and HDMI 2.0 (4K) video outs, easy focus and zooming, and programmable user buttons.
The DVX200 will record 4K (4096 × 2160) / 24p, UHD (3840 × 2160) / HD (1920 × 1080) 60p / 50p / 30p / 25p / 24p in either MP4 / MOV file formats. There are two SD card** slots, facilitating backup and relay recording. For professionals working worldwide, the camera’s master frame rate is selectable between 59.94Hz (23.98Hz) / 50.00Hz / 24.00Hz.
The DVX200’s three manual operation lens rings—13x zoom (Cam driven), focus and iris—will provide a comfortable manual control similar to an interchangeable lens camera, but without the need for actual lens changes. The zoom ring's solid feel and smooth action allow delicate ultra-slow zooming. In addition, the camera’s multi-step zoom control provides fast response and smooth zoom action, yielding the creative freedom every camera operator desires. The zoom control on the handle enables variable speed zoom, allowing fine zoom control even for low angle shots. The DVX200 also features an enhanced Image Stabilizer, including a five-axis Hybrid Image Stabilizer and 4x correction-area Image Stabilizer that produces clear images without blurring, and a micro-drive focus unit that improves focus speed, tracking and capture performance, facilitating 4K focusing and shallow focus shooting.
The new Leica Dicomar 4K zoom lens with F2.8 aperture is an optimal choice for 4K video, with the ability to produce elegant imagery and subtle “bokeh” Also, Leica’s exacting quality standards serve to suppress the occurrence of ghosting and flare to a minimum. Since the DVX200 is an integrated-lens camcorder, there is no need to perform the flange back adjustments or shading corrections when changing lenses. Even with a large diameter lens, the DVX200’s weight and balance have been optimized to facilitate agile, mobile 4K acquisition. With superb center-of-gravity balance, the camcorder will be ideal for such flexible shooting applications as mounting on today’s popular stabilized camera rigs.
The AG-DVX200 utilizes a front element lens / filter diameter of 72mm, a very common size. It is expected that many third party lens accessory manufacturers will announce items such as close-up lenses and other desired options.
The AG-DVX200 will feature next-generation ergonomics, with the battery positioned in the rear so as not to interfere during handheld shooting. The DVX200 comes with a rugged woven carbon,fiber-like finish, and the recording section is distinctively styled with crimson shading.
The AG-DVX200 will be available in Fall 2015 with a suggested list price under $5000.
It's Panasonic! (c)
Il sure this will be a cool camera but I was really hoping for basically the same camera with an interchangeable lens.. Jvc only option at this range it seems..
Sad if true, they've just given up the ILC market space to everyone else. Perhaps a GH5 is just around the corner with amazing specs?
So no interchangeable lens 4k MFT camera / camcorder from Panasonic?
It is not poem, it is song by ABBA :-)
good poem! ;-)
vitaly
do you know what will be the F stop on the zoom of this new 4k camera? lets hope not 3.5 -5.6. would be grate if the put something like the 12-120 f2
they have zeizz tech either way.
For this use GH4 topic :-)
Chiquitita, tell me what's wrong
You're enchained by your own sorrow
In your eyes there is no hope for tomorrow
How I hate to see you like this
There is no way you can deny it
I can see that you're oh so sad, so quiet
How disapointing will be if GH4 doesnt bring V-Log and better codec implementation.
