As you can see the pins on the HDMI port are damaged... any ideas on how to repair this?
Unfortunately, I think (looking at the GH2 service manual) that the mini-HDMI port is soldered to the Main PCB Board (rather than being 'just' a daughterboard). So..I guess your options are: Follow the info you can find on the net for fixing HDMI ports (OK..they all seem to be for full sized ports) with bent pins. Open up your GH2 and replace the mini-HDMI...soldering a new one on the Main PCB Or....replace the Main PCB. Or...finally...just see the HDMI output as not working and work around it.
