Available at:
PR
Canon U.S.A., a leader in digital imaging solutions, today announced the highly anticipated Canon EF 100-400mm f/4.5-5.6L II USM lens, a second generation compact super-telephoto zoom lens featuring significant advancements in optical quality, image stabilization performance up-to-four steps, and rotating-zoom-ring design. This new L-series super- telephoto zoom lens features Canon L-series weather resistance and rugged magnesium housing to meet the needs of wildlife and sports photographers or photojournalists working out in the elements. Fully compatible with all EOS cameras, the EF 100-400mm f/4.5-5.6L II USM features a completely redesigned optical formula containing one Fluorite and one Super UD lens element ─ a combination unique to lenses in this focal range ─ to help deliver sharp images with high resolution and contrast. This combination of elements helps thoroughly suppress chromatic aberration throughout the entire zoom range.
"The Canon EF 100-400mm f/4.5-5.6L II USM is the logical evolution of the very popular EF 100-400mm f/4.5-5.6L IS USM introduced 16 years ago," said Yuichi Ishizuka, President and COO of Canon U.S.A., Inc., "This long awaited, next generation lens was developed to be a highly portable and adaptable telephoto zoom lens for today's modern professional and advanced amateur photographers."
For photographers who want to work as closely as possible to their subjects, the minimum focusing distance of the lens has been reduced to just 3.2 ft. (0.98m), resulting in maximum magnification of 0.31x. The original EF 100-400mm f/4.5-5.6L IS USM was well known for its push-pull zoom adjustment, but the EF 100-400mm f/4.5-5.6L II USM uses a rotation-type zoom ring similar to the one found on the EF 70-300mm f/4-5.6L IS USM lens that allows for more precise adjustments, easier handling, and consistently excellent weight balance during handheld photography. In addition, the lens features an improved zoom torque adjustment ring that allows for the easy setting of zoom tension based on personal shooting preferences. The Canon EF 100-400mm f/4.5-5.6L II USM also features an inner focusing system, a powerful yet quiet Ring USM, a high-speed CPU and optimized auto focus (AF) algorithms for fast and accurate autofocusing in various shooting situations.
The Canon EF 100-400mm f/4.5-5.6L II USM features three Image Stabilization (IS) modes ─ standard, panning, and during exposure only. Each IS mode is individually engineered to help provide outstanding results in a wide variety of shooting situations, and all serve to satisfy the personal preferences of photographers based on the type of IS they desire. The optical IS provides up to four shutter speed steps of correction, increased from 1.5 steps in the previous model*. In addition, the EF 100-400mm f/4.5-5.6L II USM features Canon's newly developed Air Sphere Coating (ASC) which helps to reduce backlit flaring and ghosting significantly, as well as a 9-bladed circular aperture Electro-Magnetic Diaphragm that helps to enhance beautiful, softly blurred backgrounds.
As with all L-series lenses, the Canon EF 100-400mm f/4.5-5.6L II USM is highly resistant to dust and water, with excellent durability in even harsh conditions, ideal for wildlife photographers even in rainforest environments, or sports photographers on the sideline grabbing action shots of the big game. Fluorine coating on the front and rear surfaces of the lens can repel dust particles and water droplets. It also makes smears and fingerprints easy to remove without the use of lens cleaning fluid. Included with the lens is the new ET-83D lens hood, that features a cleverly placed and convenient side window allowing the user to easily adjust specialty filters while the lens hood remains in place. In addition, the EF 100-400mm f/4.5-5.6L II USM is equipped with a newly designed detachable tripod mount which can be removed to reduce weight during handheld operation.
Canon EF 400mm f4 DO IS II USM is an outstanding super telephoto lens. Its use of cutting edge optical technology provides superb image quality with minimal light fall-off, no noticeable distortion and very high corner to corner sharpness.
http://www.photographyblog.com/reviews/canon_ef_400mm_f_4_do_is_ii_usm_review/
The Canon 100-400mm Mk II is sharper than the Mk I, particularly at low F-numbers where it's most beneficial, and towards the edges of the frame. Stopping down doesn't drastically improve sharpness, other than to increase depth of field. Image stabilization is much improved, now state of the art, build quality includes a full set of weather-resistant seals, and there's a standard of mechanical durability not seen before in this type of lens. AF is fast, positive, and consistently accurate (some may find the need to microadjust, though, depending on their particular lens / body copy), and the minimum focusing distance has been dramatically reduced, increasing versatility by a surprising amount, we found.
http://www.dpreview.com/reviews/upgrading-a-classic-canon-100-400mm-f4-5-5-6l-is-usm-mark-ii-review/
The Canon 100-400L II finds a very good balance between build quality and portability.
http://www.canonrumors.com/reviews/review-canon-ef-100-400mm-f4-5-5-6l-is-ii/
Canon EF 100-400mm f/4.5-5.6L IS vs EF 70-200mm f/2.8L IS
Nice improvements. Too bad the GH4 won't really benefit from the IS etc without a costly adapter. The first version was a surprisingly useful lens for wildlife and very sharp.
