Specs:
PR
Canon U.S.A., a leader in digital imaging solutions, is proud to introduce the superb new Canon EF 11-24mm f/4L USM ultra wide-angle zoom lens designed to deliver high quality, minimally distorted images throughout the entire zoom range. Featuring the widest angle of view (126º05’ diagonal) ever achieved for a rectilinear full-frame Digital SLR lens*, and a minimum focusing distance of 11 inches (at 24mm), this new lens is ideal for professionals who want the ultimate in creative image expression with sharp, crisp detail whether shooting entire buildings from a close position, entire stadium shots from a high-vantage point, large group photos at a scenic wedding or even astrophotography. Cinematographers will be equally as impressed with the lens’ ability to retain straight lines.
Fully compatible with all EOS cameras, but particularly effective with full-frame cameras such as the new Canon EOS 5DS and EOS 5DS R Digital SLR cameras also announced today, this new L-series lens features newly developed optics comprised of 16 elements in 11 groups with a three group zoom system and rear focus. The new optical design utilizes four aspherical lens elements to help minimize distortion from the center of the image to the periphery, across the entire zoom range. This new optical array provides straight lines with minimal curve throughout the zoom range, ideal for architectural, event, and forensic photography. The lens also features one Super UD element and one UD lens element to help significantly reduce chromatic aberration and deliver sharp images with high resolution. Canon’s advanced lens coating technologies are also liberally employed to help minimize ghosting and flare, while simultaneously enhancing accurate color balance and maximum light transmission efficiency.
“Canon is very proud of its optical heritage. The creation of this new lens continues our tradition of providing photographers with unique image-making solutions that are not only thoughtfully designed but precisely engineered and manufactured,” said Yuichi Ishizuka, president and COO of Canon U.S.A., Inc. “The new Canon EF 11-24mm f/4L USM ultra wide-angle zoom lens features newly developed optics and an unprecedented combination of Canon optical technologies. We are very eager to see the beautiful images that photographers will create using this new lens with Canon EOS DSLR and Cinema EOS cameras.”
The new Canon EF 11-24mm f/4L USM lens’ impressive 11mm starting focal length and 9-blade circular aperture help deliver beautiful, high-quality, detailed images. The new lens accurately reproduces straight lines in the subject with minimal distortion, ideal for architectural and landscape photographers looking to create images with tremendous depth and strong perspective.
Wide-angle lenses are especially prone to flare and ghosting. To help reduce these effects, the new Canon EF 11-24mm f/4L USM lens features Canon’s proprietary Sub-Wavelength Structure Coating (SWC) and Air Sphere Coating (ASC). SWC is applied to the rear surface of the first and second aspheric lens elements, while ASC is used on the front of the fourth element. The SWC coatings are particularly effective for combatting flare and ghosting caused by light rays entering the lens at a large angle of incidence, while the ASC coating helps mitigate the same problems for light rays entering the center of the lens. The new lens also employs Canon’s Super Spectra Coating (SSC) to enhance light transmission while at the same time optimizing color reproduction accuracy.
The Canon EF 11-24mm f/4L USM lens features a meticulously designed inner focusing system and zoom ring, as well as a built-in petal type lens hood with light-shielding grooves. Along with a high-speed CPU and optimized AF algorithms, this lens enables fast and accurate autofocusing, while its full-time manual focus feature allows manual focus adjustment even in AF mode. As with all L-series lenses, this durable new lens is highly resistant to dust and water -- ideal for outdoor photography even when conditions are harsh. In addition, a fluorine coating on the front and rear surfaces of the lens helps reduce smears and fingerprints and makes the lens easier to clean.
Pricing and Availability
The Canon EF 11-24mm f/4L USM ultra wide-angle zoom lens joins the robust line up of Canon f/4L USM zoom lenses including 16-35mm, 17-40mm, 24-70mm, 24-105mm, 70-200mm, and 200-400mm + 1.4X Extender models. It is scheduled to be available in late February 2015 for an estimated retail price of $2,999.00.
The center quality is nothing short of outstanding straight from f/4 and throughout the focal length range. However, the outer image region isn't all that hot at 11mm and especially at max. aperture and the high level of lateral CAs doesn't help either here. Moving on the 14mm and 18mm the results are much improved with good results even in the extreme corners.
With both full-frame and sub-frame cameras, the Canon 11-24mm produces very sharp images.
Image quality is outstanding. Chromatic aberrations are very well controlled, bokeh is pretty impressive despite the slow f/4 aperture and the wide-angle nature of the lens, and the Super Spectra coatings successfully prevent contrast loss attributable to flare.
http://www.photographyblog.com/reviews/canon_ef_11_24mm_f_4_l_usm_review/
Canon has produced a lens that’s as sharp or sharper than its prime counterparts. Although slower (F stop wise). It has chromatic aberration and distortion well under control. Vignetting is probably its biggest fault. But, that’s probably the easiest thing to have fixed in post, so I’m not shaken by that.
