4K footage from the Sony A7S looks absolutely stunning. If you're used to viewing a lot of 1080p footage, as I am, the jump to 4K resolution is amazing. I had the brief opportunity to borrow a Blackmagic Hyperdeck Studio Pro recorder to capture some 4K footage with the A7S, which allowed me to record video at a much higher bitrate than the typical internally-recorded videos from other cameras.
http://www.imaging-resource.com/PRODS/sony-a7s/sony-a7s-shooters-report-part-ii.htm
The video by Wolfcrow is actually pretty good advice for any RAW or Log camera. Well done!
Some pretty interesting info about exposure for the A7S...
V 1.10 Firmware update for the 7s
http://esupport.sony.com/US/p/swu-download.pl?mdl=ILCE7S&upd_id=10065&os_group_id=23
Nothing to exciting here. It does boot up a bit faster but nothing else has been addressed that I can see
My first music video with the A7s.... this was an interesting shoot, to say the least!
Sony A7S 30 Second Shutter 24-70mm f4 at f8.0 70mm
S-Log2 SGamut 3200 ISO test with Canon 35mm , 50mm
music video with a7s - video is not mine, for info contact the author ;)
@balazer Nice skin tones. However has anyone noticed that sometimes whites and light blues change to purple on the a7s i'm seeing it quite a few times especially if a little over exposed... If you look at the screenshot i attached you will see that in one portion of the sky it is a very weird blue, then in the middle of the frame it is regular blue, then on the right it is almost purple...
I did this grade in 30 minutes using the ACES workflow in Sony Vegas Pro 13:
The source video is vimeo.com/99411494
That's an average of about 90 seconds per shot. It was just a little exercise to see if I could get decent results quickly, and to demonstrate how a video recorded with S-Log2 gamma and S-Gamut color can look when processed properly. Actually I can't say that the video wasn't mangled somehow between the camera and the original Vimeo upload that I used, but it seems pretty good to me. The DNxHD upload is not correct: it has levels mapped improperly and looks like it may have used a bt.601 Y'CbCr color difference encoding matrix instead of bt.709. I used Vimeo's compressed MP4 instead.
I'm by no means an experienced color grader, but still, I spent just 30 minutes start to finish on my first attempt, including the time to split between shots. (but not including rendering time, which was another 20 minutes or so) I just did basic color correction: exposure compensation and color balance on every shot, and contrast tweaks on a few. It's just a matter of dragging a few sliders until the image looks good and matches the other shots well. I certainly could have spent more time tweaking and matching, but I didn't want to spend too much time.
Some of the original shots were badly underexposed - especially the talking head shots. Exposure compensation does what it's supposed to, but still those shots look worse, with some noticeable color precision errors and noise. Though after Vimeo's and YouTube's compression, you can hardly see those problems anymore.
@TATZU you mean exposure influences the way colors are interpreted by the LUT? I tried on these files
@flablo you have to make sure the exposure is perfect to get the correct lut output.
I tried using Sony's S-Log2 LUTs, the image looks better but honestly it still feels weird to me. Guess it is just a matter of taste, at this point
@balazer Thank for your suggestions about S-Gamut colors, they are very very useful!
