Sony KW1 or KW11 - proper pink camera for fascists, sorry, fashionistas
    Must have.
    • Sensor - 1/2.3" Exmor RS CMOS sensor
    • 19.2Mp
    • F2.0 bright lens
    • 3.3" OLED 1.230k dots screen with touch support
    http://www.sonystyle.com.cn/products/cyber-shot/dsc_kw1.htm
  • 4 Replies sorted by
  • PR
    With the sophisticated and trend-conscious fashionista on the street in mind, Sony is introducing the luxurious and sleek Cyber-shot DSC-KW11 digital still camera, designed to help capture their perfect selfie or their OOTD (Outfit of the Day) shot for sharing on their social networks. With an unprecedented design and a rich array of features, the Cyber-shotTM DSC-KW11 is both functional and complementary to one’s lifestyle needs and wants.
    The Cyber-shot DSC-KW11 has a high-sensitivity 19.2 effective megapixels Exmor RSTM CMOS sensor to capture the finer details of your shot, while its F2 maximum aperture lens ensures that there is less noise on images, even when using the camera indoors or in other low-light environments. Mounted on a 180-degree swivel, the 21mm1 wide angle lens also helps to give users the illusion of a slender body and a slimmer face for convenient and easy selfie shots.
    The Cyber-shot DSC-KW11 also flaunts a large high-definition, high-contrast, 3.3 Type OLED screen with approximately 1,299k dots equivalent for the brilliant display of images, which allows you to see in vivid detail the different effects applied to present your best self to the world.
    To complement the lifestyles of trendy fashionistas, Sony has given the camera an elegant and unconventional design that is reminiscent of a bottle of perfume with a silky pearl finish, sparkled with Swarovski® elements. Fitting nicely in the user’s hands, the Cyber-shotTM DSC-KW11 is small and handy for everyone to carry it anywhere, all day.
    The Beauty Effect mode of the Cyber-shot DSC-KW11 provides users with a multitude of options that can be applied before and after you take your photo to achieve your desired look. While shooting, Skin Toning and Skin Smoothing effects can be individually adjusted. After making your selection, you can further refine your look with the five available effects to be applied in playback mode. The options of Skin Toning, Skin Smoothing, Eye Widening, Face Slimming, and Shine Removal are also adjustable to allow you the flexibility to present a different side of you.
    Flick Touch Shutter is a new feature that lets users effortlessly set up a self-timer by just tapping and flicking their finger towards the wanted delay timing and number of images on the screen. With no cumbersome buttons and extra panels that require more time to set, users can easily set the features they want with just their thumb.
  • Rumours are that this sexis...ops, fashionist camera is the first with the new Sony's curved sensor.
  • @MarcioK
    It is all curved, Sony must have come to idea that true fashionista will demand inside to be match for outer look.
