I have had problems in setting 44M (720 34M, Gop24. AQ2) yesterday again, but I've formatted my card on the computer and everything works again.
After formatting the card 38 Mb are working. But on very complex scenes GH2 dies, such as trees in full screen. I made myself are settings: 38 Mbps - for SH mode, 30 Mbps for the H mode. Gop 24, AQ2
In the beginning, ther was much talk about the possibility of putting B-frames in the 720 mode. As far as I remember it also worked. Now in the last weeks there was nothing to read about tis. Not important any more?
I know. Has that to do with the B-frames? And thanks for your testing. It is great that there are peopel like you, who know what they are doing when they test and then share their results with the group. Thank you.
@AKED dunno if youre up and about but could you test something for me. Can you put Encoder Setting 1 720p = 1 and Encoder Setting 2 720p = 1 (I know it sounds odd) and load the firmware. Record a 1080i FSH recording and tell me if its 25p or 25p in a 50 wrapper. thnks
@AKED@Botvinic This is probably a false positive, but run this test very quickly for me and check it out. Read the instructions within the settings. ignore the 720p stuff for now and other settings. Test 1080 FSH and see what happens! Make sure you test at 50, 100, 125, 200 shutter, then do other shutter tests. Keep iso down low for now. NOTE: this is nowhere near a final setting, Im much further down the line but just want you guys to check this earlier setting. UPDATE: Now run another test and uncheck the encoder 720p settings. It appears its all about the video buffer being 3000000 :-)
