Varavon BirdyCam gimbal
  • 106 Replies sorted by
  • have you used it? The side material on the sled looks thin. Believe me, I want to like it.
  • when he puts it together in the video, it looks fragile in places to me
    It is not fragile. You do not even know how much tests and redesign and test again they made.
  • when he puts it together in the video, it looks fragile in places to me. I'm torn between this and the ronin. The ronin is so heavy though.
    Still no in depth review.
  • @DancingCamera
    Gimbal will be added to deals later today or tomorrow.
  • @Vitaliy
    Thanks. If they came down 400-500 (aim for $2k) and got their production line in order, they could sell a lot of these quickly, but they are losing their window. Varavon has done a good job, but this one is confusing.
  • @DancingCamera
    I'll see that we can do, as status of this thing is so uncertain.
  • Looking forward to a pv deal on this product. Thanks as usual, Vitaliy.
  • load weight is 3KG.
  • any info about maximum payload? Ronin is set at an incredible 7.5Kg!
  • Sweet @Vitaliy_Kiselev ....and maybe some of the other gimbals that have been in the 3-axis thread (besteady,came,allsteady)?... :D
  • @kingmixer
    I'll let you know as it'll be available as I am keeping in touch with them, we'll have special deals.
  • I don't know about other retailers, but the availability on BHphoto recently went from August 1st to August 31st. I'm also looking alternatives.
  • @3Kids, I concur. I was waiting for this gimbal as I understand it was gonna be $2000, then I heard $2300 then now $2550. At this price point, I might as well just get the DJI Ronin which seems much more reliable.
  • @3Kids
    If you ask me, Varavon is completely confused with their product. And can't make any rational decision now.
  • Although I had on pre-order the Ronin, I cancelled it thinking I would get the lighter Varavon despite the loss I would take in rentals (the Ronin is much more "rentable"). At this price though, both are so close that it just doesn't make sense to get the Varavon right now. Especially since they've announced that they will be making a larger version as well for bigger cameras. The Birdycam should have been priced below $2000. At $1700-1900 it would be ideal (which I think will be their price once the dust shuttles off)
  • wow...$500 increase. Reckon I have to wait out for a special price, if it ever going to happen. I think this birdycam will sell quite a lot after all the good reviews.
  • @SeekingHeartwood thanks for posting those videos! The stabilization looks phenomenal - no jitter, shake and it seemed very level with the horizon for the most part. I noticed in one of your videos that you were using an external monitor on the top of the gimbal, but is it possible to keep the GH4's external display extended while using the Birdycam? I ask because the OLED display on the GH4 is excellent and it will keep both costs and weight down when using it. Thanks.
  • two quick videos i threw together last night after a couple trial runs with the gimbal
    first impressions? love it! it's the perfect gimbal for me. i shoot with a GH4 and like to keep things as light and small as possible.
    i still need to work on my technique, i was really rough with the gimbal in those videos, and I'm still fine tuning it, but it's just going to get better and better
  • @killagram I'm not precisely sure what follow mode is myself since I'm fairly new to these type of gimbals but I figured it is when you pan the camera the gimbal will slide toward the direction of your pan instead of being in a fixed position when the motor is on.
    I have my GH4 toward the center right of the stage for near perfect balance so extending the screen out all the way won't work.
  • +1 @cinemasteve87 thanks for the info. So what exactly is a follow mode on this gymbal? Also can you use the birdycam with the GH4's attached monitor extended 180 degrees?
  • I've already booked a high profile client and told them about the Birdycam and they loved it, so no one really gives a s***? If you're so worried about the name then that means your pitch for your services and your equipment is not convincing enough to your clients.
    @killagram So far the camera has been a dream to balance. It took me a while the first time to get used to it but now I'm able to get this balanced within 5 minutes. I've been flying this with the GH4 and Lumix 12-35mm 2.8 and it works so well. I need to somehow download the software onto my Macbook to make the default follow mode faster. It's a bit slow coming out of the package but it works well. The joystick is absolutely awesome and feels really natural while moving around with the Birdycam. You can use the camera's monitor but it'll be very tricky checking your focus. I wouldn't use the monitor extended but it's still possible. It would just be harder to balance. So I'd use an external monitor just to be safe.
    I also tried this with a steadicam vest and I would NOT use that combo again. You lose the dynamic movement going low or high with the gimbal and I'm not sure if the extra weight on your body will be an even tradeoff for your arms. I rather beef up my arms in the long haul :)
  • Does it really matter what the name is - who f'n cares?! More so how does it perform with various lens and the GH4? Can you use it with the monitor extended? How long does it take to balance?
    PS if the name really irks you that much then just call it a "base cam". If you watch the video above the mobile app refers to it as that.
