720p 60p GH2 hack: an attempt to improve the quality, stability and reliability.
  • 36 Replies sorted by
  • When I test stability and reliability I shoot a green grass under sunlight with high speed shutter and I do movements with the camera, pan, rotate, zoom, to stress the codec. the shutter above 1/1000 is important to avoid motion blur and keep everything sharp when moving the camera, this way the codec will get stressed. The green grass under sunlight is the image which makes the Flow Motion 720p 60p GOP6 to stop recording and sometimes it freezes the camera, needs to remove and insert battery again. 720p with GOP 9 and other tweaks I did in FM202 solves this. The green grass is an image good for test settings in PTools because it strees the codec a lot and keep bitrate very high. If the camera can record the green grass for more than one minute with high shutter and movements, then the settings are ok for other images.
    To test texture, noise and macroblocking I use to shoot a dark low light scene with different colors in image and some black things over light surfaces like inside walls, a room interior shoot. Also increasing the iso to 3200 helps to perceive how the codec handles the noise, texture and macroblocking. FM202 with GOP9 for 720p is working great for this with the tweaks I did. 1080p 24p also working ok.
    It is amazing how FM202 shows the textures and noise, makes GH2 a new camera. Textures, noise, grain, low light, image details and high iso performance improves a lot. No macroblocking and the horizontal lines pattern in high iso is much less disturbing. Also there is no quality changing over time, same performance for I, B and P frames. Spatial and temporal homogeneous image for 720p and 1080p.
    @LPowell did a great job in PTools advanced settings for Testers to improve the encoding performance. I am willing keep Flow Motion tweaked version in GH2 all the time. My tweaks are not optimized for spanning, just for stability, so I hope he can develop a balanced version between the original FM202 and the tweaks I did to make 720p stable and spanning at same time. But maybe spanning in 1080p is enough, because 720p is more usefull for short scenes with slowmotion in post production. So merging the 1080p 24p settings from the original FM202 version with the 720p 60p settings from the tweaked version can be a good mix.
    1280 x 720 - 565K
  • @LPowell about my revisions:
    If boosting the 24H and 24L can compromise the spanning and 30Mbps card performance, just go back to 95000000 bitrate and 32500000. The 128000000 and 64000000 are working ok for me with the Sandisk 32GB SDHC 45Mbps card, but I did not test spanning because I do not need it.
    GOP 9 makes the 720p 60p more stable, GOP 6 stops recording all the time in my tests. The noise, texture and no macroblocking results are ok with GOP 9, it is good quality and stable. I think GOP 9 will be no problem for spanning because in each 3 seconds recording (each 180 frames) the GOP 9 close togheter with GOP 6 in same point of time. Also 2xGOP9 = 3xGOP6 in time.
    The other changes are working for me with the Sandisk 32GB SDHC 45Mbps card. I do not need spanning, so my settings are not optimized for it, my settings are optimized for stable recording and quallity without spanning.
    Maybe you can find a best balance between my settings and your settings to keep it stable and make spanning to work properly, just keep GOP 9 in 720p because it is a must for stability. Quantization 18 helps 720p stability also and no hurt in quality, but maybe 17 also works. The bitrate settings for 720p are also important for stability (72000000 and 56000000), increase or decreasing it hurts stability. For the 1080p settings, if spanning in 1080p 24p is a must, go back to FM202 1080p 24p default settings.
    The important thing is to tweak it to make the 720p to be stable in FM202.
    Thanks.
  • @apefos Thanks for taking a detailed look at FM2 and providing your modified settings for review. I'm busy with a project deadline this week, but will try to find time to test and compare your revisions with FM 2.02. A few initial observations:
    • 1080p24 Low Top Setting & 1080p24 Low Bottom Setting - these FM2 settings are correct, they are involved in optimizing FM2's 24L 4GB file-spanning reliability at 60Mbps. Your boosted Video Bitrate 24L setting will probably have an adverse effect on this.
    • Video Bitrate 24H & 1080p24 Frame Limit - Boosting these higher than FM2 settings may provoke reliability issues with 140Mbps Turbo mode and 30Mbps SD cards. If this is what required an Initial Quantizer setting of 18 in your revision, I'd consider that an undesirable compromise.
    • 720p GOP Size 9 - FM2 uses a GOP size of 6 for 720p modes to maintain a keyframe rate of at least 8 per second in all video modes. Others may find lower keyframe rates acceptable, but this was an important motion-tracking optimization issue for me. In my testing, I was unable to find GOP-9 settings that produced 720p results verifiably more reliable than FM 2.02's GOP-6 patch.
  • Thanks @LPowell
    Flow Motion is amazing quality for both 720p and 1080p !!!
    I did more tests and it is stable with the tweaks I did.
    Great work!
  • I loaded FM2.02 to the camera and did initial tests. It was stoping recording in SH and H so I did some changes and now it is working stable for me with amazing quality for 720p in low light and sun light. I tweaked the Flow Motion 2.02 to make it more stable in 720p 60p recording in my Sandisk 32GB SDHC 45Mbps card, no more stop recording until now, needs more tests. Texture is homogeneous and no macroblocking. I tweaked the 1080p 24p also. If you want to try it:
    fm202_gop3_gop9.zip
    9K
  • @LPowell @Ralph_B many thanks! I got the set ini files of FM202 setf and S51 seta
    I found something in the FM202 ini file which can be wrong (the top is lower than the bottom):
    1080p24 Low Top Setting=52500
    1080p24 Low Bottom Setting=55000
    Also the 24L bitrate is 32500000 so maybe the top would be 32500 and botom 25000 ???
    I have two questions:
    can I update firmware to change from FM202 to S51 and from S51 to FM202 ?
    can I go back to panasonic original version 1.1 ?
  • I went through all this a long time ago. There's no need to re-invent the wheel. Check out the 720 60P in Sanity 5.1. The dirty work has already been done.
  • As @karl pointed out, the diagonal rain effect is not burned into the recording. It is due to a flaw in the MainConcept H.264 decoder, which is bundled with Adobe CS6 and CC.
    I experimented with 720p GOP-3 patches in early unreleased versions of Flow Motion v2. It performed much like the 720p GOP-6 patch in FM 2.02, but GOP-3 was not quite as stable as GOP-6 at 100Mbps. Due to shared patch settings between HBR 1080p and 720p video modes, it was very difficult to achieve reliability at high bitrates in all modes simultaneously.
    Due to the way the H.264 encoder alternates between B-frames and I/P frames, IBP GOP-length must be evenly divisible by 3. A GOP-8 patch would only work properly with B-frames disabled, but that would require a higher bitrate to maintain the same quality level. If you're looking to optimize 720p modes without concern for HBR mode, I'd suggest starting with the FM2 720p GOP-6 settings, and alter it to work in GOP-3 mode.
  • So these are the new tests for 720p 60p
    GOP 6 camera frezzes sometimes, recording stops sometimes, no matter the bitrate.
    GOP 12 was stable in the first tests, but macroblocking starts to show in the shadows and there are texture lost in dark scenes, frame rate seems to become different, lower, in dark regions. Not pleasant to the eye.
    GOP 8 seems to be the sweet spot, no significant macroblock in dark scenes, no significant texture lost, stable in first tests, needs more tests. Only issue I found in 3200 iso is near the objects edges the noise is more fine grain and in flat surfaces noise is more gross, but it is not anoying, not disturbing, and cleans ok with neatvideo, it is gone after denoise. In 3200 iso the texture is more fine near the I frames and more gross near the P frames, but this also goes away after denoise. (just I and P frames in GOP 8).
    GOP 6 would be better, but I could not find a way to make it work, so GOP 8 is the best solution. I have the Sandisk 32GB SDHC 45MBps, I would like to try GOP 6 with the Sandisk 95MBps card... but for now I will do more tests with GOP 8.
    5dtoRGB works ok for transcoding and I did not see diagonal pattern (rain) yet after transcoding.
    I was thinking I would need to keep GOP number to close in each second, 60 frames have 10 GOP6, 5 GOP12, but there is 7,5 GOP8 inside a second of 60p, but this is no problem yet in the first tests.
    SH was set to 128Mbps, H was set to 64Mbps, both worked ok until now.
    It seems GOP 8 will be ok for 720p 60p, needs more tests... in different light situations, different objects textures and different motions, camera motion and objects motion...
  • thanks for the tip.
    also I found a tip here in pv to transcode the original mts file using 5dtorgb and it seems to solve the problem, after conversion I did not see the diagonal pattern (rain) problem anymore, needs more plays to trust the solution.
    so now I can try to improve the GOP 6 for 720p...
  • AFAIR this "rain" symptom is not at all the camera's fault, but a mis-interpretation of the H.264 encoded video by some playback software. Try replaying your raw .MTS files with a different software (e.g. a recent VLC) and see whether the symptom doesn't vanish.
Start New Topic
Howdy, Stranger!
Sign In Register as New User
Tags in Topic
Top Posters
