@Mistas Here on Dave Satz's blog there is a lot of explanations which may help you.
He's a Gaffer I know from working in Switzerland. Very techy and helpful guy. Just keep in mind he's in PAL land: http://www.davidsatz.com/aboutflicker_en.html
From a google search: https://www.google.com/search?client=safari&rls=en&q=60+cycle+flicker+in+photos&ie=UTF-8&oe=UTF-8
@Mista "I thought synchro scan was for video??? The banding I experienced was much more obvious at faster shutter speeds 1/1000+"
The electronic shutter can produce prominent banding similar to your examples when used under neon or fluorescent lighting. For stills images the mechanical shutter is always the better option in such conditions. However you still need to select an appropriate shutter speed to avoid the flicker issue mentioned above.
From the manual:
Taking Pictures with No Shutter Sound (Electronic Shutter): * Under fluorescent or LED lighting, etc., horizontal stripes may appear on recorded pictures. In such cases, lowering the shutter speed may reduce the effect of the horizontal stripes.
Just had an issue where the GH4 would freeze about 3-4 secs after turning on. It made a noise in the camera body like a quiet shutter sound and a black horizontal line appeared on the LCD screen. It would continue to do this every 3-4 secs. It required the battery to be removed to power off & reset. I only cleared the problem after removing some photo's and video from the SD card. It seems to be related to having less than 4.3 GB available on the card.
I think there might be an issue with the way Exposure Compensation works while recording in Creative Movie mode when AEL is engaged. Can someone try to reproduce?
I can adjust Exposure, Exposure Compensation and Focus after AEL/AFL lock, during recording. But the way Exposure Compensation behaves while recording seems different than before recording - and kind of strange.
To reproduce...
Set AEL/AFL Lock = On (to set AEL/AFL button in toggle mode)
Set Creative Movie on Mode Dial
Set Exposure Mode = A
Set ISO = AutoISO
Set Aperture
Set Exposure Compensation (+/-)
Press AE/AF Lock button, watch screen for green focus indicator at focus area, AEL (lower left), green dot and AFL (upper right)
At this point the exposure and focus are "locked," but you can manually adjust them.
My observations...including some guess-work:
Manual Adjustments once AEL/AFL engaged, before recording starts...
Manipulating the Exposure Compensation value will change the exposure using AutoISO and Shutter values until you reach the limits of either. The effect on the image is obvious and intuitive.
Begin recording.
Manual Adjustments once AEL/AFL engaged, during recording..
If you adjust Aperture, the behavior of the camera is the same as it was before recording. The exposure will remain constant within the limits of Auto ISO/Shutter.
If you adjust Exposure Compensation setting during recording and the exposure will change, but the behavior not the same as if you change Exposure Compensation before recording began. I don't know why this would be - perhaps it's a bug or just the particular conditions I'm recording in. Can someone test and see if they see a difference and post?
Has anyone experienced any vertical banding on the GH4? I just got mine a few days ago and have noticed there is VERY visible vertical lines on all modes and on all shutter speeds. I thought it was the lcd at first but it is on the clip when played back on the computer as well. I think I may have a dud :( I better get it back to the store asap!
Wow so never buy a camera from Henry's in Canada! No returns or exchanges on items over $1499! How the hell is that even allowed and not announced at the time of purchase!? They said you should rent before purchasing an item of that amount. I said even if it's defective?
It's all good I spoke to a manager and they informed me the proper terms. No returns or exchanges on Non-defective items. So they said I just have to reproduce the problem in-store and they will do a straight swap thank god!
Besides that the camera has been working great!
@tylerknight Sorry to hear about the GH4 giving you problems. Do you live in the GTA (Toronto area)? I own a GH4 also & prehaps I can help. I'll PM you my contact info.
Password: gh4band
This is the raw video compressed to upload at 50mbps I won't mention where the banding is so it is unbiased. Please download to get the full quality as vimeo smooths over the lines.
This is the same clip with lumetri looks "day for night" put on as it compressed and made the line more obvious
again please download the original clip to see (lots of colour banding which is expected from an 8bit codec.I am uploading the raw file from the camera with no compression as we speak and will post after.
Raw file straight from the camera. Please download to see the banding as vimeo compresses the hell out of it>
password:gh4band
This is the lcd screen on the gh4 with permanent vertical lines on all modes including photo which leads me to believe it is the sensor itself.
password: gh4band
Something I noticed when I was first shooting with this camera, was that my files would corrupt easily. Corruption came in the form of a few frames of video or stills with some tearing. I am using a uhs speed 3 card for this. The video files on the sd card were not corrupt. Maybe I'm using the wrong terminology by calling the files corrupted
I tried multiple different methods of getting my files on the computer today. And, what I had noticed was that the file corruption happened at some point during transfers.
The usb cable transfer to my PC was fine. which was surprising since it was the only one I had used so far.
The sd card reader on my laptop corrupted the files.
A usb sd card reader connected to my PC worked just fine.
I'm going to be doing more tests in the future which will include the firmware released today.
@Soupertrooper what format are you using mp3 or mov? The mp3 UHD format seems not to be supported by Win media player. I am using mov for everything shot with the Gh4. I have no problems copying the files to my 6 years old Dell XPS laptop, even using the built in card reader. I use Sandisk Extreme 95 cards
@Tomaso I'm using mov files and I'm watching them with VLC media player. Give VLC a try, chances are you'll come to love it.
Here is an example of the screen tearing issue I was talking about
It happens a couple of times throughout the video. I'm glad I'm not the only one experiencing this.
