Which hack can do span in HBR mode?
  • Hi, I have tried several stable hacks, Like flow motion, santiy 5.1/x. It does not span in HBR mode with native m4/3 lens. They all span with 24p mode. But I want one can span in 30p mode. What hack should I use then??
  • 6 Replies sorted by
  • Hi, I just did a test using Cake 2.3 in HBR mode using native m4/3 lens. Recorded 1 hour footage, span well.
  • ok, I will try cake 2.3 then. Thanks.
  • I am use sandisk 95mb/s 64GB. But in Sanity 5.1 description it says span work only with manual focus lens in HBR mode. So my native m4/3 lens does not span makes sense.
  • Cake 2.3 spans in HBR mode. But get a fast memory card anyway.
  • I can use a cheap class 10 card with Sanity 5.1 and get 100% reliable spanning in HBR mode.
    Which card are you using?
  • Maybe only factory setting?
