The Metz do.
marcus, do any of those support high speed shutter sync? I ended up getting an oly fl-50R because i needed that function. be nice to get a second cheaper flash
The Metz 58-AF2 is just great. Had the 48-AF1 before (one generation older). For some reason the TTL meassurements with the 58 produce way more consistent and correct lighting then on the 48. You should try to find it used if it's too expensive.
For second and third flashes the YN460II on cheap RF-triggers work great and are easy to adapt to mains power for an improvised studio setup. Want to give the YN560II with focus a try and am currently selling both my modified YN460II.
is the nissin flash ttl?
