Cinema gear deals, direct from factories - CatchIt deals and Gear deals section. Also check Cameras, lenses, software, gear deals.
Donations are going to project support costs and work (hosting, etc).
contribution size
GH2 High Quality GOP3 Settings, Series 2: 'AN' Valkyrie, GOLGOP3-13, GOP3ZILLA, Duke, natural :-)
  • 670 Replies sorted by
  • GOP3ZILLA4_BETA2 is under tuning now. :-)
    1296 x 634 - 507K
    1297 x 633 - 538K
  • @ GOP3ZILLA lovers :-)
    GOP3ZILLA4_BETA2
    bkmcwd GOP3ZILLA4_BETA2 - setg.ini - Released 31/05/2014
    I release the new version of "GOP3ZILLA" setting.
    In this version, the GOP tables are adjusted more appropriately. I think that this is further stable from previous GOP3ZILLA settings in HBR or 720p.
    Please try it! And many thanks for your feedbacks!
    If this is also still unstable, I will further adjust.
    Special thanks to all silent users of my settings! :-)
    Of course, many thanks to @cbrandin and KING @driftwood!
    • Superb-looking modified stock matrix is adopted in all the modes
    • Upto 110M for Top Quality 1080p24 at Q15
    • Upto 140M(110x1.25=137.5M) for Top Quality 1080p30 at Q15 in 24H mode with 80% Slow-Motion Mode (No Sound)
    • Upto 48M for Top Quality HBR/FSH modes
    • Upto 48M for Top Quality 720p modes
    • Extremely reliable top performance in AVCHD 24H and 24L
    • 80% Slow-Motion is available in 24H and 24L both with
    • Fully working iA and iDynamic range modes if you require them (Take care only in 720/60p)
    • Beautiful 3 GOP bringing short GOP style detail & movement-rendition in 24p and 1080i/HBR modes
    • Beautiful 6 GOP bringing short GOP style detail & movement-rendition in 720p modes
    • Bush of Death / Death chart tested.
    • Wonderful Pasadena Pulse Audio Patch V2 B2, by Per Lichtman
    • Top quality 2K mjpeg Mode in HD by Nick Driftwood
    • In camera playback is available in all rec modes,
    *Supposing you use "SH" mode safely in 60p, please turn OFF iA and i dynamic range control. On the other hand, in other rec modes, it is satisfactory with iA or i dynamic range control at all.
    *Although I have received the report that it was able to be used also with the slower card, I especially recommend you use with SanDisk 95MB/s 64GB SDXC card.
    bkmcwd GOP3ZILLA4_BETA2.zip
    949B
  • wait, does this mean "Upto 48M for Top Quality HBR/FSH modes" ...this will work on classic Class10 card?...because i am looking for a HBR hack than can work with cheapo Class10 card.
  • @dado023 Hi,
    Since the test in a slower card is endless, I myself am not carrying out. And I am glad if the results are fed back to me. :-)
    GOP3ZILLA4_BETA2.1
    bkmcwd GOP3ZILLA4_BETA2.1 - setg.ini - Released 11/06/2014
    In this BETA version, the FB settings are adjusted more appropriately. I think that this is further stable from previous GOP3ZILLA settings in HBR or 720p.
    bkmcwd GOP3ZILLA4_BETA2.1.zip
    988B
  • @bkmcwd hack is really reliable tested on a standard A-Data 16 GB Class 10 SDHC Card and no hiccups especially against my bush of death. in 24p I received average speeds up to 84mbs, and 720p 60p speeds up to 44mbs.
  • Sorry, I was referring to the GOP3ZILLA4_BETA2.1 Hack.
  • @satudiomans
    did you have a chance to use it on Class 10 card you mentioned for a longer time, for example 20minutes of constant recording.......because 85mbs sounds really high for a Class10 sd card
  • @studiomans
    Many thanks for feedback and so sorry for my reply delayed.
  • GOLGOP3-13-A2_BETA13
    bkmcwd "GOLGOP3-13-A2_BETA13" - setj.ini - Released 07/07/2014
    This A2 is the version in which spanning is possible in all the rec modes.
    I think that the freezing issue at the moment of the focusing and zooming was solved nearly perfectly also in Panny lens use.
    Also on towi's Death Movie, span is possible for all the rec modes.
    Cautions are required to use iDRC or iA only in 720p.
    Please try it! And I am very glad if I can get feedbacks from you.
    *If this is also still unstable, I will further adjust.
    • The original matrix is adopted in the newest GOLGOP3-13. It is the middle of a Sedna matrix and a stock character. If I say plainly, it will be the Sedna matrix optimized in 3GOP structure.
    • Upto 110M for Top Quality 1080p24 at Q13
    • Upto 140M(110x1.25=137.5M) for Top Quality 1080p30 at Q13 in 24H mode with 80% Slow-Motion Mode (No Sound)
    • Upto 50M for Top Quality HBR/FSH modes
    • Upto 50M for Top Quality 720/50p modes
    • Upto 50M for Top Quality 720/60p modes
    • Fully working iA and iDynamic range modes if you require them (Take care only in 720p)
    • Beautiful 6 GOP bringing short GOP style detail & movement-rendition in in 720p modes
    *Supposing you use "SH" mode safely, please turn OFF iA and i dynamic range control. On the other hand, in other rec modes, it is satisfactory with iA or i dynamic range control at all.
    bkmcwd GOLGOP3-13-A2_BETA13.zip
    1K
    1296 x 630 - 531K
  • @bkmcwd fantastic! is it the 12mm slr?
  • @AlbertZ
    THX! :-)
    is the 12mm slr?
    No, it is Panny 12-35mm.
  • GOLGOP3-13-A2 24p
  • I tried the latest hack during some day shots.
  • Hi, I'm using GOP3ZILLA4_BETA2.1, and have just tested all the video modes, but in FCP X, both FSH and HBR mode at 1080p show up as being recorded at 25i. 24p cinema and slow motion at 80% both show up at 23.98 so are ok... is there something I've done wrong or is it to do with PAL NTSC differences?
  • Testing DaVinci's intergration with Edius. Shot with the latest settings. Excellent result so far. @24p. Sorry for the Greek HipHop lyrics, but I liked the beat so much.
  • It's been a long time. :-)
    @dlzn @sakattaq76
    Many thanks for nice footage!
    Although I do not have time to test or shoot these days, I have shot after a long time.
    *No grading both
    GOLGOP3-13-A2 24p
    Valkyrie 444 TYPE-ZERO3 24p
  • Valkyrie 444 TYPE-ZERO4 BETA5
    bkmcwd "Valkyrie 444 TYPE-ZERO4 BETA5" - seta.ini - Released 20/08/2014
    *All modes were changed from BETA4.5. :-)
    *The problem that BETA4.5 cannot often be spaned in 24H is solved.
    This TYPE-ZERO4 is also the version as which "balance of gradation and resolving" was considered in all the modes.
    Although towi's Death Movie is cleared in all the modes, there is no telling whether spanning is possible in other than 24p.
    *Probably, spanning is possible in all the rec modes.
    Cautions are required to use iDRC or iA only in 60p.
    • Superb-looking Pure Original 444 matrix from @cbrandin is adopted in 24p mode
    • Modified 444 matrix from my BETA Team in Japan is adopted in HBR/1080i and 720p modes
    • Upto 140M for Top Quality 1080p24 at Q18
    • Upto 140M for Top Quality 1080p30 at Q18 in 24L mode with 80% Slow-Motion Mode (No Sound)
    • Upto 50M for Top Quality 720p modes
    • 80% Slow-Motion is available in 24L only
    • Bush of Death / Death chart tested with Panny lens.
    • In camera playback is sometimes not available in 24p. In other mode, Sometimes available after reboot the camera.
    *Supposing you use "SH" mode safely in 60p, please turn OFF iA and i dynamic range control. On the other hand, in other rec modes, it is satisfactory at all.
    bkmcwd Valkyrie 444 TYPE-ZERO4 BETA5.zip
    1K
    1298 x 633 - 510K
    1295 x 630 - 527K
  • GOLGOP3-13-MAX_BETA11
    bkmcwd "GOLGOP3-13-MAX_BETA11" - seth.ini - Released 21/08/2014
    This MAX is the version in which maximum size of I-frame is used in 24p rec mode.
    • Upto 140M for Top Quality 1080p24 at Q13
    • Upto 140M(110x1.25=137.5M) for Top Quality 1080p30 at Q13 in 24L mode with 80% Slow-Motion Mode (No Sound)
    • 80% Slow-Motion is available only in 24L
    bkmcwd GOLGOP3-13-MAX2_BETA11.zip
    1K
    1294 x 632 - 506K
    1298 x 631 - 484K
  • @dlzn
    Thanks mate! :-)
  • Had installed Valkyrie 444 TYPE-ZERO4 BETA5. I found it's having outstanding low light ability.
    I will use it for shooting a musical in HK.
    Thank you so much!
  • GOLGOP3-13-MAX_BETA11 24p ISO3200 No color grading
    @frogfrog
    Thanks for comment, mate! :-)
    1296 x 632 - 528K
    1298 x 632 - 534K
