GH4 4K Panasonic video camera, User reviews and opinions
  • 1273 Replies sorted by
  • great review thanks for link i never knew about the shutter angle setting.
  • As I stated before, GH4 has about 11 stops of usable DR in 4K:
    "Dynamic Range
    Panasonic has you covered from a color grading and DR standpoint. The Cinelike D color mode is designed to be a flat color profile, and should help you get the most out of each frame. With this color mode selected, we ran our typical dynamic range test. We were able to eke out around 10.5 to 11 stops from the GH4 at base ISO. Furthermore, that was a number that didn't waver much even at higher sensitivities (the video ISO scale stops at ISO 6400). In HD, we found that you could get a little bit more DR from the GH4. We ran this test with the 200 Mbps ALL-i video, so it's understandable that you might see a little bit less clipping, but not enough useful range to make it worth the tradeoff in resolution."
    http://camcorders.reviewed.com/content/panasonic-lumix-gh4-video-shooting-review
    There is no need to effectively destroy the files with master pedestal, contrast dialed to minimum etc. You just simply use the Cine D setting to get that wonderful DR. To get the best results form GH4, you not to search for maximum DR always, but to search for the needed contrast in you scene. If you do this with care, GH4 is quite good at high ISO. I calculated about roughly 1 stops worse High ISO performance than 1Dc in 4K, until ISO 6400, but Gh4 is so much more detailed in comparison. 1Dc looks like a 3K camera when compared, even in good light. Also Canon 1Dc has a lower DR in good light compared to GH4, but nobody ever complained about it.
    It is like syndrome, the first thing most of the users do, is dial minimum contrast, play with curves, etc and completely destroy the files. This is wrong, so don't blame the camera is you get bad results. Cine D setting is a flat profile, but it is no LOG, so this camera must be treated differently. And there is the another thing, when you shoot flat and grade, in 8 bit there will always be artifacts and banding. For this type of work you must use an external recorder with 10 bits.
    Best regards, I hope I was helpful and not offended anybody.
  • Hi guys! suggestions for post production workflow? best settings on premiere? thanks!
  • Short film we just shot with the GH4. Feel free to let me know any feedback and if you have any questions, I'll be happy to answer.
    Password is eek2014
  • I am thinking I need to exchange the GH4 quickly before the exchange period expires, but I wanted to find out if anyone else has experienced this and can offer any advice. Going thru the exchange process just to get another GH4 that does this wouldn't be ideal. Has anyone experienced similar issues or have useful advice on this?
    No. Go to service center. And this have this for such - http://www.personal-view.com/talks/discussion/10349/gh4-issues-topic#Item_27
  • My just arrived GH4 has a continuous squeal in all the audio recorded with the internal mic that sometimes sounds like the whistle of a boiling teapot in the distance. The whistling teapot like sound occurs after recording for a half minute or so and changes in pitch. I am using the 14-140 lens from my GH2 and I never had this issue on the GH2. It seems to occur in all settings I have tried so far, in A, P ,S ,M modes.
    I have a Rode shoe mounted microphone and when I use it the squeal disappears. I tested for the squeal with the camera stationary and the lens cap on, with internal mic (present), with external Rode mic on (none), with external Rode mic plugged in but turned off (none). I tried this test with OIS on and auto-focus on and with OIS off and auto-focus off. There was no difference. In these 25 second tests I did not get the varying high pitched squeal, but I did get the constant squeal that was lower pitched, not exactly white noise like, but perhaps like a jet in the far distance.
  • Video I shot in Toronto. used the 14-140mm and the 20mm lumix 1.7
  • @seakingheartwood I would go with 1/4. 1/8 is so subtle its hard to notice.
  • @aaronchicago fantastic, i was wondering about that filter with 4k, thanks for the comparison. i think i'll pick one up now. the filter seems to take a very slight edge off the image that is great for close up interviews.
    i was debating between this and the 1/8, but from your pic the effect is very subtle with the 1/4, so the effect of a 1/8 might be imperceptible. what do you think?
  • Here is a comparison that I made of GH4 UHD with/without a Tiffen Black Pro Mist filter. Thoughts?
    http://tinypic.com/r/5kppgy/8
    3840 x 4320 - 2M
  • @AdamT Thanks, man. Just tried it again with Pixel Motion and it didn't really make that much of a difference. I think the in camera 96fps is still the way to go.
  • @SuperSet turn on Layer>Frame Blending>Pixel Motion. Not as good as Twixtor but it should help.
  • I'm looking to use an external recorder with my GH4 to capture 10bit 1080p. As long as I have 10bit HDMI out selected, presumably it doesn't matter what capture format I have selected on the camera?
  • You might want to use twixtor. The subject matter being so fast (not the movement of the targets, but the bullets and sparks) is going to be hard for any interpolation though.
  • @AdamT I did a quick comparison between 96fps and 1080/60 with time stretch and did not get really smooth motion using time stretch. Did you do anything in AE to get it smoother?
  • So far I'm quite impressed with the improved dynamic range and resolution over my GH2. The GH2 is still a workhorse and I plan on keeping it as a B cam for a long time, but holy crap that 4K resolution looks incredible. Also I noticed that the Cinema D curve with the master pedestal lifted fully gives a super flat image, much flatter than I had expected. Here's a concert I filmed just earlier this week. Shot in the Cinema 4K setting, white balance 3800K I believe, ISO800, Zuiko 45mm f/1.8 wide open. The youtube compression doesn't do any justice to the original, there is far less banding in the original MOV file, and the fricken dust particles are razor sharp lol! All I did in post was throw Premiere Pro's cineon converter in to add contrast back into the image, and reduced noise very lightly using Neat Video with almost no sharpening.
  • What is with these crazy reviews that continue to punch the GH4 for noisy video at 1600 ISO?
    The GH2 is no where near as good and it could be lit to perform great in dark scenes. If it an a7s? of course not it has a sensor 1/4th the size.
    On my recent shooting I found it not just great in low light but exceeded my expectations with the 20mm 1.7 lens. It is very very good. Some of my shots were at ISO 2000 and 2500 and were pretty clean. Much cleaner than the 7D could ever do.
    We have unrealistic expectations for what a clean image might be, the camera is clean as a whistle compared to ISO 1600 film and cleans up very well in post.
    I would love to see a comparison with the GH4, 5D Mk III and a7s and fast lenses. GH4 speedbooster to boot just for kicks. And see the amount of detail they retain, my guess is the GH4 even with NeatVideo on top will look more detailed.
