home made rig to acomodate 2 oly epl1 in housings, 14-42 lenses, premiere pro cs5 editted for anaglyph red/cyan, doble image in some moments not removed as i wanted to show limitations.
Suggestions for improvements: Next time try to correct horizontal and vertical misalignments, first (set stereo window mainly in front of the objects). Try using larger distance to the closest subjects as well (some scenes have exaggerated depth). You can also get better results by using more rigid construction (horizontal and vertical alignments are changing due to camera movements). And, yes, use parallel format when uploading to YouTube. In this case anybody could choose his/her favourite viewing option (including anaglyph).
Looking forward to watching your next video.
What did you mean by "doble (double) image"? You mean that some clips were not synchronised well or you wanted to show anaglyph limitations?
thanks for your comments, Im now working on new rig, more stable and with adjustments, this was beta testing and wanted to show limits in actual system.
After apearing on spanish tv many people are now developing different rigs to accomodate 2 cams.
Will post photos of new rig as soon as we finnish. As you can imagine we have problems with distance between lenses due to underwater housings dimensions.
