Here is some MMM on 1080i and some HBR slowed down using Moon T7
@paulo. Nope, thats the biggest issue with the GH2 IMO - color and contrast is far too 'baked in' out-of-camera
A Tiffen low contrast 3 filter works wonders for AVCHD (and the GH2 in particular): not only does it reduce contrast, it does this by lifting the blacks so you are far less likely to see macro blocking. For the GH2, it can also remove some of the bad effects of over-sharpness and roll-off the highlights (to give you a more analog feel). Have a look at http://howgreenisyourgarden.wordpress.com/2013/12/18/dslr-video-lens-filters-for-video/ Scroll down to the section 'Low Contrast filter' as the first bit talks about variable ND filters, which I assume everyone here knows about :)
The example video is LX7 AVCHD, 28Mbit/s, so the main reason to use a Low contrast filter for that camera is avoiding macro blocking (because of the reduced bandwidth). For the GH2 its more about getting your out-of-camera footage flatter by lifting the blacks, rolling off the highs and reducing the digital sharpness a bit.
I generally shoot DSLR video with both a variable ND and LC3 on the lens.
HTH
Another Moms clip.. Had a few card errors (I still have the 45MB/s Sandisk cards) in SH mode with the Panny 45-200 zooming in and recording. Other than that, smooth as ever.
@gardener. Yes, I believe the filter is essentially diffusing the ambient (thus averaging it) and using it to pull up the frame uniformly... so the more light you have hitting the filter, the greater the effect. You've got to shield the filter to control the effect sometimes, as a bright sun whose angle is changing as you shoot causes more problems than it solves :)
Seriously, wtf?
@powderbanks I LOVE future islands. They put on an incredible performance live.
Nice video there!
Hey Guys Check out my new video that I shot with my GH2 moon t7. Thanks @driftwood :) Pretty Happy with the results.
Used mainly 14-140 and glide cam 2000.
Let me know what you think.
Used Magic Bullet looks and Film convert to colour correct and also did some tweaking in PP.
