Remember that you need to check Version Increment patch(as you use older firmware) and use proper value for this patch (10 will do fine). It is also good idea to check Prevent Version Compare :-)
I have not been able to get lucky. In response to Vitaliy on the previous thread. I tried checking all three patches and changing the version number to 10, even 20. Still not workin' :(
You are just doing something wrong. You are using GH1 with proper serial number (unhackable, I mean)? This patches had been tested not on one unhackable GH1 body, and all is working.
Technically I am not. My GH1 is an older one that WAS hackable. But then it broke, I had to send it in for repair. I put the factory firmware back when I did this. When the camera was returned to me they had installed the version 1.34 firmware and I have not been able to hack it since.
Are you sure about v1.34? As no one knows firmware that had been used in your case. May be they have completely different firmware for service centers, I do not know.
I'm not sure what I could be doing wrong. Is there a certain naming convention I have to follow for the files or something? I've been trying GH1_132.bin (I think there's actually 2 underscores) and variations thereof, changing the version numbers.
Ok...thanks, didn't get version increment and that you had to put something in the ptool MENU not just rename the file. When you click "version increment" a menu appears at the bottom with green dot text, it says at the top "Enter Version Iincriment" in yellow/white dot letters and underneath it says "1". I didn't even see that the first time. This time I put 10.
So...original file name as in firmware "GH1__132.bin"? Or since these are the unhackable, do we lable it 134?
My battery was full, formatted the card in camera, then put to the card reader and in Windows I added the file to the root (while leaving all other folders intact). As for the file - I checked all three patches and entered 10 in Version Increment. Saved it as GF1__123.bin (original filename was GF1__122.bin). Put it in the camera, pressed slideshow button and it worked :)
btw...there was some mix up in my accounts, both JMF and JFK is me.
