Removing the Corrupted Start-up GH2 AVCHD Frames.
  • 28 Replies sorted by
  • @mpgxsvcd
    "The easiest lossless cutter and joiner out there is AVS Video remaker. It will do a lossless cut and join for the MTS files. It is about $60 and comes with the very full features AVS video editor. "
    Have you looked at the output though? It's not very good. I took a non-hacked mts file and cut a few seconds out of it. Lots of artifacting when the scene changes with AVS Video Remaker.
  • @Shield
    Yea I played with it a little more and you are right. If you don't cut on an I-Frame it has a lot of corruption. I guess the search is still on.
  • Can somebody please explain the workflow to fix my MTS files in Smart Cutter ?
