I installed the latest flow motion hack the other day and when I try to revert back to factory settings the camera does not recognize the new file when I insert my memory card into the camera
The camera does not recognize the file that is installed on the memory card so I can not upgrade the camera
Figured it out... The file name has to have a higher number that the last one installed then it works eg... GH2_V11.bin is the update file from Lumix... the hack that was installed was called GH2_V14.bin... If you want to revert back to the Lumix update file rename it GH2_V15.bin and it will work... It did for me anyways. :)
