Setting a very low Q value doesn't work with real time codecs. You might be able to do that if you don't care how long encoding takes, but that's not the case with a camera. The possible Q values has to be limited because there simply isn't enough processing bandwidth available to actually try all possible values, and strange fallback things will happen.
@neveraholiday I use the same cards (though only a 16Gb and an 8Gb), and Cbrandins 66M setting is what I use everyday and I've never had a single problem. I've also used driftwoods 132M GOP3 with no problems too. Are you sure your card is genuine ? I also used these settings on slower Extreme SDHCs with no issues too.
@cbrandin Did you ever try IQ=0 and Q=0 and what is its AQ equivalent? I only mention this cus other codecs when QP is set to 0 allows the encoder to go off and get the best possible Q. My tests show very high frame sizes but it needs harnasssing.
I use Sandisk SDHC Extreme Pro 32 Gig with 45MB/s. Fastest you can get. As for Streamparser, I didn't install that yet cause I don't have much time. And it will take time until I find time to install it. So you'll have to wait, sorry. Anybody else who crashes on 66?
Although I have not spent much time with other modes, Chris's 24H (1080 24P) 66M AQ2 setting has never failed for me. You are the first person to mention Chis's 24H 66M AQ2 setting failed. What SDHC card are you using? Sounds like a card issue to me.
I've been casually following along and it seems things are getting a bit convoluted. Who's got a good set of settings covering all the various modes with some decent bitrates and image quality tests to back them up?
@neveraholiday can you show us some streamparser graphs of the 44M running at AQ3 and GOP6 of shots around a couple of minutes long. Would really like to see if the stream cadence issue happens. If it doesn't I, and quite a few other people probably, would be very keen to have such a low bitrate GOP 6 setting.
To come back to the talk of which settings work best for you, I come to the following conclusion:
cbrandin's setting 66 (in all different versions (i50 and p24)) crash on my gh2. A message states that the cam ran out of bandwidth and I have to remove the battery to shut it down.
stable, and visually best results (IMHO) I get with cbrandin's 44/32-settings, modified to AQ3 and GOP6. I just have a feeling GOP6 produces less blocks than GOP12, though I don't have software to proof that. Just visual comparing.
Picture Profile I found the best as: Nostalgic Contrast +2 Sharpness -2 Saturation +2 NR: 0 (with -2 I think I had much more noise – fine grain – but it is better for me with 0)
@Vitaliy_Kiselev IDK if this is a good idea or not, but I thought it could be useful if there was a spot on each forum member's page where they could put their personal settings. This way, if I want to see what settings Chris or Kae or myself or anyone else is currently using, I can just go to their page and see (as long as they keep it up to date, of course)
This may be an annoying question, but here goes: Chris, I was away from personal-view for a while, and so lost track of this thread; I don't feel like digging through the whole thing to find the most up to date max-image quality settings you propose, so, I was wondering if you could put this on the first post of the thread? Maybe that way, it will be easy for people to see what is up to date without having to read through everything? Just a thought. Thanks for ALL your hard work!!!!!!!!!!
@sam_stickland (possibly later in the chain or perhaps from some interaction with lighting) ok, but I saw FPN with sunlight. Testing its a good idea, I will be happy to read your conclusions from the tests in the banding thread. :)
@Mihuel - because when you use ExTele mode you read off a different smaller section of the CMOS sensor. If the FPN noise was the same in ExTele mode it would suggest it's being generated by something else (possibly later in the chain or perhaps from some interaction with lighting). I'm going to test this and post the response in the banding thread.
@cbrandin Higher bitrate reveals, unfortunately, sensor failures that are masked by the technique of pixel binning. It makes sense for me. @sam_stickland Why weird ? Do not kid yourself, we pull out of this machine more than predicted by its designers as we pulled away imperfections assembly line. Nothing is perfect, and even more GH2 :-)
@cosimo_bullo Unfortunately, I also noticed this ailment. I thought that just seems to me, but in the mode ExTele, banding is more visible even at ISO160.
One interesting effect from the higher bitrate settings... the Ex teleconverter looks worse and worse to us, the more data thrown at it. I think the stock bitrate helped blur/smooth it before, and now we're seeing the warts and all. Other have a similar experience?
