My RJ M42 arrived. Looks really good. Well built, easy to put on my Takumar M42 lenses. I tried it with the 24/3.5 and the 35/2.0. Without any further precise tests, looks like they keep the great sharpness, contrast and colours of the Taks, giving more light and focal length. So I am happy so far with the performance, hopefully next days I can post some pictures.
@gh2hacked I got one on the way, should be able to report soon
It is good to understand that optically they are same with other RJ adapters. So, you can just check them.
Anybody got the RJ's EOS to MFT speedboost? Can you please post some review. I have been waiting on the metabone one for a while. Seem like it is not happening anytime soon.
My bad
I think all of such things had been discussed in long Metabones topic.
@gameb It will behave like f/2, but keep the reduced focal length in mind. Focal length is a great factor in the shallowness of the Depth of Field. It's pretty easy to get actually - the f-stop is the relation between Focal Length and the size of the entry-pupil. Therefore, when the focal length gets changed by the adapter (because it becomes a unit with the lens), the entry-pupil stays the same. And therefore, the f-stop has to be increased, it's logic.
I have a simple basic doubt about lens turbos/speedbooster: When I use them with a lens that has lets say a max aperture of 2.8. The result will be a 2.0. But what about the DOF? Will the setup be a DOF that corresponds to a 2.8 lens or to a 2.0 lens?
@tetakpatak doesn't 720 mode on the GH2 have worse moire/ailiasing than 1080 mode? Doesn't that skew the results?
I could see the ailiasing in the side-by-side video from the GH2 while the NEX-7 had none of that problem.
It would be great if someone who owns the adapter could make just a 3-4 static video scenery shots this way:
Each of that 3-4 double shots that way, each with different scenery (like trees/grass or buildings or so) and afterwards crop in the video editing software shot 1 to 720p and display them side by side in the final, rendered video file in 720p, one half of the screen for each shot.
Maybe it sounds confusing, I mean just the same thing like I did here:
By watching the same crop it would make us very easy to see how is the optical performance of the adapter compared to without adapter. Oh yes, it should be also the same camera, not like in the video comparison, where I've used different cameras and lenses.....
I might pick up one of these cheap M42 boosters for my cheap vintage russian lenses. They are soft anyway and used for specific soft looks anyway. I went with the Metabones for my higher quality Nikon lenses.
We live in a great day and age when there are so many options to suit every different need.
@zigizigi Sorry, but I really don't understand your test - not in terms of aperture, but in terms of sharpness.
My Tokina is for sure not the most sharp lens out there, but my own short tests produced much more sharp images as yours with a test chart and on a tripod (I assume).
What is that blur with open aperture - even in the centre? Is it possible that the test chart is out of focus? (Did you focus with closed aperture and then only opened up the iris, without readjusting focus?
That was my misconception, sorry, folks. I'm still in the process of figuring out how it works. What the ring on the adapter actually does is pulling the lever on the lens that gradually opens the aperture blades from wide-open to user set value. So it's just another way to control lens's aperture.
I turned the ring, saw aperture blades inside, heard them clicking... me, monkey, was fooled by perception.
I've edited the above post to leave only the relevant part of my test. Just to avoid further confusion.
@zigizigi yes, quite strange. If anything, the ring on the RJ adapter should simply be adjusting the lens' own aperture (for aperture control on G lenses without aperture ring). Can you post a picture of the adapter that shows its own aperture?
It sounds very weird. No such things as two apertures exist.
What is adapter aperture and that is lens aperture in your terms?
As for G lenses you need to use adapter ring only. And for all else you need to use lenses ring leaving adapter one open.
I don't get it. Why does the RJ booster works perfectly with some lenses and with others it doesn't? I am waiting for my M42 one to use with my Takumars. So if I am lucky it will work. And what if I am unlucky? I mean, these kind of things shouldn't be like this. At least if @zigizigi hasn't done some basic error, which doesn't look like it at all. I hope they have a good return policy.
I re-calibrated back focus on RJ adapter and redid the tests more comprehensively, at different aperture settings.
The same Nikon f/1.4 50mm lens.
RJ adapter. Lens @ f/4 Shutter 1/250
Lens @ f/2.8 Shutter 1/200
Lens @ f/2 Shutter 1/400
Lens @ f/1.4. Shutter 1/640
Regular adapter.
Lens @ f/4 Shutter 1/60
Lens @ f/2.8 Shutter 1/125
Lens @ f/2 Shutter 1/250
Lens @ f/1.4 Shutter 1/400
In none of my tests I was able to replicate the situation where lens+adapter outperformed the sharpness of the lens itself, at least in the center which is reported by the testers of Metabones adpater here or Mitakon's here.
i've got the Nikon version on my BMPCC, tight fit but it works. i think for shallow DOF shots it works ok. i also have the Canon mount on order. when Metabones gets stock on the BMPCC Nikon speedbooster, i'll throw this one on Craigslist:)
Has anyone tried one on a BMPCC yet? I'm very interested in getting the EF - MFT one if it does.
@Adam_Mercier "...the lens seems quite unsharp". Thats strange. The Nikon lens is definitely not unsharp. And the Nikon RJ booster is also not unsharp as you can appreciate in this post: http://www.dpreview.com/forums/thread/3489623#forum-post-51476898 when you look at his second test. I would rather say, in @zigizigi 's test, the combination of this precise Nikon lens with the Nikon RJ booster is unsharp. But this should be adjustable, I guess.
@zigizigi Thanks for the info! the lens seems quite unsharp... we'll see real life, I oredred the EF version..
@Psyco Got it,. makes sense then.
@vicharris sorry I only have the Tokina 11-16mm with Nikon mount, my other lenses beeing 4/3 Oly 14-35mm and 35-100mm f2.0 - so I have a set from 8mm to 100mm with constant f2.0 aperture ;-)
Thats why an expensive MB speed booster doesn't make much sense for me - it would only be used with the Tok 11-16.
There's no crop whatsoever. I moved tripod to compensate the difference.
@zigizigi did you crop on the image from the speed booster or change the distance between the chart and the camera for your resolution test?
