DIY Gear Videos, look inside
  • Videos of different things, i try ed to get the best ones i like in there, if anyone got others, please do share i can then update the tread.
    Diy DSLR Shoulder Rig
    The "Sphere Arm" tripod arm for filming Insects / i would use more robust materials, and maby rollerblade ball bearings or a spring , in the top and side joints to make i shake less, its a great idea.
    DIY Car Mounts for Small Camcorders
    Make your own camera car mount
    Cheap follow focus DIY
    DSLR Follow Focus - Homemade Focus Assist
    DIY Steadicam - Flying Camera Support
    Camera Shoulder Rig Tutorial - DSLR PVC Stabilizer
    DSLR Micro Cage Prototype + PVC Camera Rig
    DIY Gyro-Stabilized Camera Rig http://videopia.org/index.php/read/shorts-mainmenu-235/680-template.html
    Part 1 DIY on how to build a Spider Trax Dolly
    Part 2 DIY Spider Trax Dolly Tracks
    DIY - Rig Handles
    How to make a DSLR Stabilizer
    Part 1How to build a DSLR Cage
    part 2
    DIY Camera Slider Dolly (the sequel)
    DIY Camera Slider Dolly (the sequel) small udate at the end of the video he explains an updated weel axel and looks like bigger washers some places too
    CAMERA SLIDER DIY TUTORIAL http://www.friedhelm-fischer.de/the-ff-tutorials/camera-slider-diy-tutorial
    DIY Filming Dolly With 10' Track
    Making Remyyy's Shoebox
    . Bon voyage ! Sample video of the shoebox, by Remyy, 4 years old by good.
    Homemade Flexible Clamps 3 for the price of one.
    Part 2 sample video $15.00 DIY Body DSLR Camera Stabilizer Sample
    DIY high quality camera stabilizer for iphone 3GS blackberry miniDV under $10
    just found this wonderful DIY, its a Stedycam arm and Vest that you use whit you Glidecam 2000-4000/stedycam
    Heres how it Looks when operating the steadicam flyer and zephyr¨ . [url]
    i like the arm from this tread http://www.microfilmmaker.com/tipstrick/Issue33/DIYSVest_1.html
    and the vest from this build he got a older video where he shows how he made that vest, before he upgraded it
    DIY Indie Air Cannon Not showing it all sadly, but it might be enough for ppl to make it.
  • 13 Replies sorted by
  • Learn how to make a portable variable speed linear dolly / slider motor for shooting timelapse videos that can be used on any slider rig for about $55 AUD. For about $85 AUD you can have a deluxe version with two motors, one for timelapse and another for regular speed shots, USB power and a dedicated 12v battery and charger. Here's a little day trip I did to test the unit out. It rained the entire day, so it wasn't ideal, but you can see that it works!
    For the full parts list, including links, see askdesign.it/weblog/slider. The slider used is an 80cm Konova K2. you'll need an intervalometer - I use Magic Lantern on my 6D, a hack which allows you to do intervalometer shots in-camera, but you can buy a unit off eBay for c. $30. Be sure to get one that can take an infinite number of photographs, many timeout at 99 (4 seconds of footage).
    Shoutout to Style43 (vimeo.com/12120373) and Joakim Fjeldli.
    // Shooting Advice
    1. Have fun!
    2. Put a bit of tension on your sliders bearings and you'll get silky smooth motion, and use fishing line (or any string for that matter) that doesn't have any elasticity or give.
  • Here are a few I'm looking into doing:
    RotoRig. Probably not a great shoulder rig, but looks like an excellent jib. Professional looking, too!
    Instructions:
    Best DIY Mattebox I've ever seen:
    Instructions for building can be found here: http://www.ramasolaproductions.com/5.html (Along with a few other DIY projects, including a gearless follow focus, and rail system).
  • It's a bit old, almost 3 years, but nevertheless a nice assembly BTS video
  • I'm not sure if this belongs here, but here is a project 'Stainless' by Adam Magyar, who took a 1D line-scan camera, modified it, and used it to take pictures of moving things or of stationary things from a moving subway train. Here is rather a fancy description of the project http://medium.com/matter/88aa8a185898 while more examples are in his homepage http://www.magyaradam.com/
  • @vicharris +1 Ah-men: no pie here, or here:
    (did you want to use a mattebox? lol!)
  • Holy crap that is noisy as hell!!!! I guess any of these budget wireless FF systems will use cheap servos. No pie and eating it apparently :)
  • The Senna All Recall Follow Focus system with a DIY HDMI Wireless Remote Video Stream on the GH3 camera:
  • Nice DIY collection. In the (4th) car-mount video be sure to use water or something along those lines in the Windex bottle, NOT stuff like Windex to apply the suction cups. Using some of these cleaning spray products on your car's bodywork could damage de paint.
  • updated the titel
    dont be shy post videos in here if you got any good ones.
  • can you change the title to > How To : DIY Videos series, 10+
  • added some more, again if you got some great DIY videos do post them so i can update the tread, to make it better, do share.
  • yea i tried to fix it, think i got it now as i used codes, dident know they where written into the postbox :)
  • Please, make topic in proper format.
