As the old saying goes, it ... depends. In many ways for complicated moving masks the key-framing in AeFx is more reliable. Current masks in Sg can work great for this, but might kinda muss around in a slightly different use on the next sequence. When they work, they're quick & seem easier to me to do than in PrPro & Ae. That's probably just because for what little I've needed, Sg has normally worked and I've not had time to experiment in the other programs. In do know a lot of the professional work by others with these oft use PrPro or Ae for their heavy-lift masking jobs.
I also know from discussions with the staffers who've posted on Adobe's Sg forum that they realize that the masking with Sg isn't always as robust or stable as it needs to be, and is a huge project for them to get the masking down better. They've made some nice upgrades in the most recent release, including somewhat better reliability in their masking operations. I'm wondering how soon they may get a better-masked release out.
Do you think masks are better in Speedgrade or Premiere? (Are they best in After Effects?)
I'm starting to work in two new features of Speedgrade, the shot-matcher (which has been revamped from the older method) and the "Master Clip" option.
The revamped shot-matching procedure does seem to work a lot better. Not always perfectly natch but definitely much closer results than before. I'm able to come close enough for my work to get quite a few "matches" good enough as to be no matter. Some still need a bit of tweaking, maybe a bit less than half, and when needed is a pretty small change.
"Master Clip" use is in setting a master clip for a camera in a particular scene/lighting and having Speedgrade recognize other timeline occurrences or subclips of that bit of footage. You can then simply correct/modify the master clip itself and Speedgrade automatically updates all other instances of that group of footage accordingly.
And both of these are simpler to use with the new scopes and scope-utilization choices. Much better "scoping" now. Masks ... somewhat better, but that is still an area that needs more improvement. Often my masks are now working as expected ... but ... still occasionally key-framing seems to glitch. Maybe next iteration/update that will be ironed out.
Still, for my uses, shot-matching & master clip are big timesavers. My brain is still wrapping around master clip application, but that's not unusual. Sigh ... ;-)
Neil
Different strokes for the reviewer & me ... I got that "Expert Mouse" and though the build quality isn't the highest, both within Speedgrade and in general computer work I love the thing. Within Sg, using the ball for the inside of the color-wheels (chroma correction) and the outer wheel for the luma corrections is spiffy. Scrolling with the wheel is great, and having all four buttons set for various actions it's a dream to use ... for me.
As to the comment about a Wacom pad, I'm a lefty ... the Wacom is on my left, pen in hand ... the track-wheel mouse thing on my right ... and occasionally I'll even use the keyboard in the middle. Poor man's surface? ;-)
@MikeLinn ... as one of the people who's howling about the old scopes (both on Adobe forums and in wishform requests) got me some interesting and direct comments back from the development team .. I'm thrilled with both the general quality/usability of the new scopes as they appear ... especially the vectorscope getting GOOD graticules ... and the ability to clamp/unclamp the signal shown on the scopes. That alone made this program far more "native" to my brain. I got to see it at NAB, and while watching one of 'the team' demo it to someone else, commented how wondrous the new scopes were. He ... um ... glanced at my name-tag, and even though NAB had put my first name rather than my middle name on it ... the guy knew who I must be immediately. Squeaky wheels & all? But still, those scopes are nice. Was THRILLED when they finally released the new version ...
Well, it was nice getting to NAB ... what a huge trade show! I even sat in for one of the Adobe staffer's demo-ing Speedgrade for a few minutes. The discussions with a few users of Resolve was ... interesting. Or should I say, they were very interested in the Sg process, and particularly how well the interface worked with "looks", LUT's, and custom profiles. As it was the first time I've ever actually worked a dual-display system with Speedgrade ... oh my lands ... do I want another BIG monitor ...
@madddog15 ...
Interesting to have you pop up on the Adobe Speedgrade forum. Speedgrade's a love/irritant program. Some things so wonderful & cool/easy, many things that are quick & easy not actually documented or shown someplace so you either just push buttons to see what happens for several hours or watch tons of other people doing things ... and some obvious things that aren't easy or perhaps possible.
Adobe's been dealing with issues on the multiple-card problem for sometime, and they're slowly getting it better. It's actually been easier on the PC side, especially as that last Mac OS switch through some real and unexpected nasty curveballs at Adobe & Blackmagic/Kona cards and all.
I'd note ... one thing Adobe is trying to do that no other company is attempting ... is create a multi-program "native" workflow ingetion/subclipping/transcoding(Prelude) to NLE (PrPro) to grading (Sg) to titling/Fx (Ae) to render-out (AME). From what I can tell, trying to moosh the software from all those different programs together to work one basic project format back & forth ... is quite a mountain to move. Some parts they've done quite well, some ... um ... no.
Still, for my little projects, the PrPro/Sg Direct Link process is a wondrous time-saver. Hope they get the multiple cards issue solved soon in Sg ... I'll "soon" be getting a new box designed ground-up for video processing which will be multi-carded.
Interesting. I'll look at more of it tomorrow.
Neil
Another overview tutorial on Speedgrade workflow.
Cool thanks - figured it was something simple like that.
I'm on CC and in general totally caught into the direct-to-Sg link. I'll create a sequence in PPro just to put a few clips onto, then take that direct to Sg to grade. The initial dialog box in Sg will allow me to choose the sequence "highlighted" before I "jumped", or one of the others in that project.
Remember if in CC, you can't change the project's timeline on a direct-link move. So if you're going to need grading layers above your timeline, make adjustment layers in PPro, then use them for grading layers in Sg. Of course, you can have about as many layers on your footage as you can imagine without using separate grading layers, but they can be awfully handy to "tie" corrections to other similar footage.
Neil
@rneil This sounds great - will check it out. Thanks for posting. We're editing in premiere now and have a few scenes that will need some "heavy lifitng" with masks so this will be great. Wonder if it's possible to open just a portion of a sequence in Speedgrade? My initial dabbling with it seemed to open whole sequence if I remember correctly.
http://lynda.com has a new series of tutorials up, "Up and running with Speedgrade CC", that is the best one I've seen yet for practical demos of how to get into Sg, do primaries and secondaries, masks & all, and get back to PPro. NO wasted time, yet he does show every step needed in each bit. And when to use the "direct" send from PPro and when to use Speedgrade as a separate program on the material involved.
Good stuff.
Neil
Patrick Palmer just commented in a thread of mine over on the Adobe forums, useful stuff to know. Why do the Adobe Speedgrade scopes resize both the data and the 'dark' or "real" area of the scopes as you work? Because they use full floating-point calculations, and are designed to show the full amount of data at all times rather than allowing 'clipped' data to just thin-line. Some people actually like this, and find it intuitive to use scopes with a perhaps greyed-out but visible bottom-section of the scope showing where you've crushed your blacks without distorting the total shape of the data. (This does mean then the scale of the scope needs to be compressed, however.)
Nice to understand ... but he gave a work-around if you want to have a static scope scale/size, preferring your 'clipped' data to just thin-line on top and bottom. It's pretty easy to do.
1) Create a grading layer on top of all other layers on the timeline. (Note that in a direct-to-Speedgrade link from Premiere Pro CC you'll need to add an adjustment layer in P-Pro on top of your timeline BEFORE going to Sg.)
2) Select that layer and add a " + " to the layer's palette dialog box from the bottom menu, choosing LUT from the long pop-up list.
3) Go to the Lut selection pop-up, and choose " Clip_0_to_1.ilut ".
Now, your scopes will give a static (standard-style) display. Takes far longer to describe than to do. He's also suggesting to their software engineers to add this into the scopes window as a simple switchable view, same as say seeing chroma or luma data.
Now if we could just get graticules in the vector-scope.
neil
For the roundtrippin' undertakers: Moving Looks from Resolve to SpeedGrade • Complementary • And just 4 fun
New suggested workflow if using Speedgrade on a direct-send from Premiere Pro ...
Either way, in P-Pro, you can then open your latest version and take right off working. Still it's a HECK of a lot faster than exporting/importing and all that ...
Neil
I did. Though, unfortunately, I wasn't thinking about saving the blame thing for a postmortem, I was just trying to get work done by deadline. So ... I didn't save-as the blown copy, just went back to P-Pro and started again.
There's another thing to be aware of that I learned in a p-m from an Adobe staffer ... Speedgrade does NOT do auto-saves, you have to save manually. Which is odd, because every five minutes or so a box pops-up to notify of auto-saving going on. Apparently, it's from P-Pro running in the background, but as I'd not saved what I was doing in Speedgrade, P-Pro didn't actually see anything to save ... so for all those "autosaved" dialog boxes, there wasn't one additional save for P-Pro past when I'd initially sent the project over to Speedgrade.
I've been p-m'd that they're considering changing that behavior ... yes, please! Or at least, TELL us that though it says it's auto-saving it isn't actually if you're currently in Speedgrade!
So ... the p-m from Adobe wanted the project, but it sounded like ... the blown one, that I didn't save-as. I can send them the current state of the project if they'd like, and have offered. The staff has been quite helpful on it.
Neil
@rNeil Maybe try posting this issue as a topic on the adobe forums both in Premiere section and Speedgrade section. Maybe also email and call Adobe for help, if they have help lines.
Sucks - sorry to hear of this trouble you're having. Hope you recover work and solve issue.
That's another odd thing ... it's currently set for 15 minute auto-saves, and yes, whilst working I had the little pop-up that another auto-save had occurred. However, after this blip ... when I went to the auto-save folder ... the LAST auto-save showing had been almost two hours earlier, right after first looking at a new folder of "b roll" stuff for this project. After going through the clips from media browser and choosing what I wanted to actually use, I imported clips and still into the project, set another sequence to hold b-roll clips, one for stills, set rough in/out for all the possible b-clips into that sequence, and sent them over to Speedgrade ... for an hour-plus of work there.
None of that was in an auto-save. Around two hours of continuous work, not actually saved. Since Speedgrade was working a P-Pro "proj" file, it supposedly saves back to that file ... just ... weird. All of it.
Neil
@rNeil Did you look for the files that were autosaved? Maybe your grading work was saved there.
Wow ... I've been getting better at this whole NLE/grading thing ... using the CC versions of Adobe's stuff. Still no speed demon, but betting better results and learning how to work the system better.
Took a 'b' roll sequence direct send-to-Sg, about 15 clips. Five adjustment layers between the several sets of clips, working through the whole thing ... next to last clip, putting a static mask in to lighten a face a bit, went to click off the mask to check my work, about the 4th time ... gone.
Everything I'd done was simply GONE. The workspace went from the 4-scopes to the left, monitor to the right layout to a single mid-upper-screen monitor. The "view" was WAY yellow-green, and yet ... all controls showed centered ... as if untouched. Anywhere I scrubbed in the timeline, no matter whether I clicked on a clip or adjustment layer ... all controls zeroed but the monitor image way yellow-green.
Tried a few "undo" Ctrl-Z's, nothing. Clicked the undo icon on the bar ... nothing. I'd seen I don't know how many auto-saves, so ... I closed without saving, re-opened ... well, the funny yellow-green was gone, but the monitor still "solo'd" without scopes ... and the footage was back to original un-varnished anything.
Closed, went back to P-Pro ... no grading showing. Direct send to Speedgrade again ... still no scopes in view, and ... "naked" footage.
I am a little bummed at the moment.
Neil
The new release of the Adobe CC software (ver. 7.1) contains some vastly improved workflows betwixt P-Pro and Speedgrade. All in all, a wondrous up-take in capability/ease of use. Not, mind you, a perfected one ... but as this article from Adobe points out, the first "generation?" of the new linked workflow.
http://blogs.adobe.com/movingcolors/2013/11/07/getting-to-know-direct-link/
For much of my work, the new workflow is stunning in both ease and time-saving. Work something in P-Pro, 'send' to Sg for a bit, save ... right back to P-Pro with the grades right there. I've sent in a few feature requests because of either different choices by the developers than I'd make ... or STOOPID ones, like ... still no skin-line or color boxes in the vectorscopes. Dumb.
Still, it's vastly easier and quicker to work in now.
Neil
