New Korg Kronos and Kronos X
  • The Kronos X doubles the PCM RAM capacity to approximately 2GB and the SSD capacity to 62GB, enabling musicians to take full advantage of all the Kronos Sound Libraries. In addition, Kronos X contains Korg's EXs 10-13 expansion sample series of Kronos Sound Libraries pre-installed in its demo mode. Users can obtain full versions, plus additional Sound Libraries, by simply purchasing a license key from the Web Shop.
    Along with Kronos X, Korg announces Kronos OS v2.0, coming soon for all Kronos and Kronos X models. For models that do not already have OS v2.0 installed (visible during boot), users can download it for free, then easily install it via USB.
    New to OS v2.0 are user Sample Banks for creating high-capacity, custom sample libraries. Players can load and play many gigabytes of their custom or converted samples at once, using the internal Kronos SSD. Improved disk and memory enable the creation of User Sample Bank subsets, as well as mixing and matching parts from different banks, without duplicating samples on disk. Programs, Wave Sequences, and Drum Kits maintain links to the User Sample Banks even when samples are moved on disk or loaded onto a different Kronos instrument, making it easy to share sounds with friends and collaborators. Players can also create their own samples or import Akai and SoundFont 2.0 libraries using new, improved conversion features.
    Additional things:
    • A second internal SSD can be added to support massive sound library expansions, including Korg and third-party Sound Libraries
    • USB Ethernet support enables high-speed data communication between Kronos and a computer
    Available at:
  • 9 Replies sorted by
  • Katsunori UJIIE
  • Updated Kronos
    “The new Kronos features the unrivaled 9-engine structure from previous versions, with numerous improvements to both sound capability and overall functionality,” said Korg Brand Manager James Sajeva. “Truly, this is the most powerful synthesizer on the planet.”
  • Would be nice if it allowed for third party sampling apps and VSTs to load on it
  • Korg released KRONOS new firmware version 2.1.
    • Improved CX engine
    • Fixed bugs
    • real-time indication of the Rotary Speaker speed in all performance modes;
    • a polyphony-saving option for Timbre/Track Mute; and
    • Aability to assign external MIDI CCs (from a pedal controller, for instance) to a number of special functions.
    http://www.korg.com/kronosx
  • Two other demos
