Driftwood Cluster X series 3:│moon T7│ЅріzZ T6│Nebula T7│Drewnet T9│
  • 1811 Replies sorted by
  • @sam great job fixing that footage. quite impressive.
  • @Lenkoff, that is great news, the new footage was fantastic. I'm guessing the ending proposal part was just so poorly lit that the 5DM2 was the best choice to use there, and it still had a hard time.
  • cbm32221 All shot with the GH2 MoonT7. Ending proposal shot with 5DM2.
  • my new short movie! I call it: awful footage fixed in post :) Thanks to the "force" of Moon T7...
  • Some still shots pulled directly from video clips in Premiere. No CC at all, just very mild noise reduction and sharpening via NeatVideo. All the footage I captured was at ISO640 f/1.4 using a Nikkor AiS 50mm. The noise honesty had a very pleasant grain, and looking back I think I'd rather bump it up to ISO1250 and drop the aperture to F/2.0 to improve sharpness (lots of flare and abberations wide open on that vintage lens) but none the less, VERY impressed with the DrewNet patch. Can't wait to get some Sandisk Extreme Pros to try out Moon.
    1920 x 1080 - 490K
    1920 x 1080 - 717K
    1920 x 1080 - 728K
  • @Tjabo Thanks! :) Yes, only the 25mm..no money for different lenses ;)
  • Drewnet T9
  • @kn3 good idea ! But, I get even slower write speeds shown from my ssd to the SD card, 15 mb/s , oh well as long as moon t7 works I guess the true speed of the card does not really matter. ( I just feel a bit ripped off).
  • @tak Activity Monitor shows disk transfer rates under the Disk tab. I'd have Finder and Activity Monitor open and start copying large movie files to/from the SD card. The speed of course depends on speeds of the card reader/hard disk. Some internal hard drives are slow (<80MB/s).
  • @3Kids Thanks for that info. I know this is not the thread, but what can you use as a card speed test? The BlackMagic speed test app shows the same as the 5D3. By the way (and to get back on topic, I also tested Moon T7 in HBR on the Komputerbay card without any problems.
  • @danielortegajan, I LOVE your video!!! Did you only use the 25mm lens for the whole thing? Shot in 24H?
  • @tak The 5D3 SD card buffer tops at 18MB/s, that's why it's only used to host the ML files and not record raw, you shouldn't use it for benchmarking.
  • I have been testing Moon T7 on a Komputerbay 64 Go SDXC class 10 (UHS-I 600X) and have had no problems at all on different setting I have thrown at it. The only think is that long clips dont play back in the camera (4GB) but they are fine on the computer. The strange thing about the card is that even though it is rated at 40mbs write, when I test it using black magic disk speed tester it shows about 18 mbs as a write speed. I have used the Magic Lantern in camera benchmark test with the same card in a 5D3 to double check and got the same results. (sandisk extreme pro 95 shows about the same, weird), anyway, moon T7 works fine for me with these less expensive Komputerbay cards.
  • @powderbanks It's quite normal you can't stop them from flickering – lots of LED lights are frequency modulated. We're gonna have fun with these in the future…
  • Hey Guys;
    Not sure if this is a problem with the hack (I doubt it, because the footage plays back fine in VLC and Windows Media Player Classic)... I'm having issues with the audio from the DREWnet "24H" setting. When importing into Premiere Pro, for takes longer than 1 minute the sound seems to speed up and skip through like a scratched CD. I record audio from a mic straight into my GH2 for wedding work, so this is kind of a bummer.
    I'm almost fully certain that it isn't a hack problem, but a Premiere Pro problem. This is CS6, latest version (not CC).
    Any help/way to fix it? I hazard a guess it had to do with the conforming of footage when imported into the project but I'm not entirely sure.
    EDIT: I managed to figure that issue out. Turns out it was Adobe's fault. Fix is found here (in case someone else has this problem): http://forums.creativecow.net/thread/3/940953
  • @Lenkoff Was the whole thing T7 or just certain parts, like the ending proposal?
  • @Gardner Did you notice any of the new LED Christmas lights flickering in some of your footage? I went to a local garden that has a bunch and it seemed like no matter what shutter speed I tried, certain strings of lights would just be epileptic.
  • my first short film with gh2 Moon T7, panaleica 25mm, filmconvert and davinci. Hope you like it?
  • @filmrebel Looks great. Cool film.
  • Here's a short film shot with Panasonic GH2 w/14-42mm lens. Moon T7 Hack. Amazing hack. The best footage I've ever worked with. Period.
  • @FrankPisolo Driftwood Moon T7 E - since D 24p is not recognized as 24p with fcpx, 5dtorgb, clipwrap and so on anyway. dont know why.
  • Drewnet T9
  • @sam Moon T7 set E(23.98p) or D(24p)
Start New Topic
Howdy, Stranger!
Sign In Register as New User
Tags in Topic
Top Posters
