Hi guys. I need some help. I have the lens and it's fantastic!
I gave someone this lens and he accidentally turned the adapter opposite the normal rotation, resulting breaking the last contact little metal plate on the mount (electronic contact). Unfortunateley this contact is responsible for giving power to the lens. So now when I connect the lens to the GH2 it goes black with the message "check the lens". On the GH1 it shows the image through the lens but I don't have any manual control.
My question is if it's possible to replace the contacts plate with another 4/3 lens (like the cheap olympus 14-42mm). I opened the back mount of the lens and it is very difficult to solder the connection (the plastic will melt).
I love that lens and I always use it manually (focus, aperure) but without power this can't be done. I am very dissapointed because it is a very good and expansive lens and in my country there is no repair service for panasonic (Greece). Do you have any ideas to help me?
From now on . . . only spend money on mechanical lens!
Hi, if you set focus to manual with your GH2 and the manaul-focus ring does not work, this could mean your lens has a problem. I had the same problem and returned the lens to the seller.
I also have this lens and a GH2 and it will autofocus(slowly) but cannot get it to manual focus. Any suggestions? I use the DMW-MA1 adaptor.
Thanks a million for the quick info.
Can't get manual focussing to work. Any idea how to do this? :-)
OIS noise from the 14-50 2.8 is normal.
Hi,
just bought one of these lenses used. Looks really good. Autofocus + GH3 works (I am using the Panasonic MA1 adapter), albeit slow.
However I am experiencing a continuous sound from the image stabilization motor, if IS is turned on. Have a look here:
It is that continuous rattling sound, not the auto focus sound. Anybody else experiencing this. Is this normal?
Karsten
@IvanUskokovic How is this lens and manual focusing? I see all the problems with auto.
Please excuse my last post. Seems Panasonic never updated the firmware of the aforementioned 14-50mm lens. I will look in to my problem further as a potential issue with the Panasonic GH3.
Hey guys, I need some help.
I picked up this lens today (L-ES014050) Panasonic 14-50mm f/2.8-3.5 Vario-Elmarit Aspherical MEGA O.I.S.... I also have the DMW-MA1 Four Thirds to Micro Four Thirds adapter. I am using the lens on the Panasonic GH3. Both camera and lens have firmware version 1.0. Autofocus will not work. I am under the impression the lens needs a firmware update. However, I can not find where the update is located on the internet. Help?
