Couldn't find enough interesting opinions about this lens... what do you think?
Get the 25mm f2
But you are referring to ZE/ZF then, right?
The 25mm 2.8 in Contax version was not the greatest glass they made. The 28mm is far better, the 25 has soft corners WO. That doens't matter too much if you put it just on the GH2, but it matters when you use a SpeedBooster with it.
