@tonalt. A few questions: Are we supposed to hear the person in the background? Do you have the footage that goes with the audio available for downlaod? It's an interview for what kind of format, documentary, reality show, short film, corporate web video, etc.?
I don't really hear big echoes, so maybe you should check your playback system There is an electrical hum for which I recommend the waves plugin x hum. If you add compression, it will boost the hum, so you will need a noise gate, or remove the hum, then add compression. It doesn't need a lot of compression. When there is another voice that is farther away, you can certainly cut the file into clips and process those clips independently to make them closer in sound, but they won't ever sound the same. You can EQ out the low frequencies below 100 Hz for starters.
