Nobody has tested Pentax auto 110 lenses on the BMPCC? The 18mm 2.8 (fixed iris) is not too bad on my GH2..it would be interesting to test it, they are very cheap and incredible small lenses :)
These are nice lenses, but they are pretty large and don't come in very wide versions.
Rather go for the Tevidon series from Zeiss Jena, they were made for one inch sensors (or tubes) and start at 10mm. Excellent for the small camera.
For both series keep in mind that production from the communist era has massive sample variation. They were capable of making very good glass, but end control was sloppy (even if Lenin said something like "trust is good, control is better").
Zeiss Jena lenses should work on the pocket, right? Like these: http://www.ebay.com/sch/i.html?_trksid=p2047675.m570.l1313.TR12.TRC2.A0.Xzeiss+jena&_nkw=zeiss+jena&_sacat=0&_from=R40
These little primes from Canon in the TV-16 line are really special, even the 13mm 1:1.5 covers.
I tested the Canon against the Cosmicar 12.5 and the Lumix 12-35mm @12mm now, and it is definitely softer. It has funky distortion, even more than the uncorrected Lumix and the light-weigt and cheap Cosmicar has less distortion than both. The Cosmicar is sharper from the start than the Canon and has less CA (but still some).
At 2.8 the Cosmicar is at least as sharp in the center as the Lumix! It's always a bit more greenish than the others. it has about the same viewing angle as the Lumix set to 12mm, so either the Cosmicar is wider than 12.5 or the Lumix isn't as wide as it claims.
The Canon never get's too sharp in the corners, but it has "character". It's warmer, has some soft haloes WO and very nice bokeh with it's 10 blades. Very good build quality too, the Cosmicar with it's thin aluminum tube can't stand a bump, the Canon sure does.
We have an adapter for PL to MFT from ciecio7, and it's worth every cent, really pro-grade.
Just ordered an adapter from Ciecio7. Communication over ebay messages as been good. The product looks great from the ebay pictures and description/specifications. Though it was not overly expensive (definitely not cheap) it was priced as a professional product. From that standpoint I am expecting a lifetime of quality use.
As far as c-mount to micro 4/3's adapters go, the Metabones looks to be top of the line based on the materials used, not sure about the ramifications of the design. I might try one in the future when the Aluminum ones I have wear in threads. Right now I have been using the one from the Hawk's Factory which allows as much depth as possible to seat the c-mount lens, though it is not a flat/slim adapter. On that note sometimes you have to grind the lens to get it to seat far enough towards the sensor to get focus to infinity, so if you are grinding the lens anyway the Metabones adapter will "most likely" not be a problem, but one will need to test for one's self.
My bad, it does work, indeed! (you learn something new every day) :) Good times!
What do you mean by "punch in" ? Quick double-click on "OK" doesn't help ?
Having done a couple of shoots with the bmpcc, I can say the 17.5mm voigtländer is really sweet on the cam. Speedbooster + c/y zeiss combo works OK, though I would not use any other lenses than the 28mm f2 and the 60mm macro from what I´ve seen so far. Peaking works so-so. (A punch in function would be fantastic)
I´ll be up with some footage as soon as there editing / grading / compositing is done and dusted.
@nomad sorry, I just found it on ebay ;o)
@nomad Ok, thanks again. Ciecio7 is a PV member?
Well, my experience with the Fotga is the same, quite tight, no play. All adapters sit a bit looser on the GH2 and some cheap Chinese ones, which fit the GH2, don't fit the BMPCC.
You can either buy a few cheap ones and keep the best or pay considerably more for something like the Metabones or those from ciecio7 (Poland), who has very good adapters of all kinds.
But it seems that all allow to screw the lens in a bit past infinity, so you can go cheap, since shimming is always needed.
@nomad, @peaceonearth : Thanks, guys. So it seems better not to spend much money on those adapters, right?
I've tried Kipon which had a backlash and fotga which was almost too tight for the camera mount.
I've tried Fotga (quite cheap), Kiwi and Metabones (the most expensive one).
They all need shimming to meet the markings on primes or to make zooms parfocal.
For who is using vintage 16mm cine glass (Schneider non RF for example) with the pocket: which c-mount to m43 are you guys using that works better? Thanks.
@vicharris is that the SLR Magic anamorphic lens? :) can't wait to see the footage and your opinion on it
Hopefully I'll get some footage up soon from this little baby :)
                  depends what you want. I dont know the Oly but own the tokina. It's a great lens, but for my taste too big for the pocket camera. Why not choose the Lumix 12-35? With 35mm it's more versatile and it's covering a 90% focal range
Olympus 11-22mm 2.8-3.5 is ok for the bmpcc??
http://www.lenstip.com/215.1-Lens_review-Olympus_Zuiko_Digital_11-22_mm_f_2.8-3.5_Introduction.html
or tokina 11-16 ?? Thanks
Thanks
@Renovatio
It seems that matt was not the shooter either.
From what I've seen in the compressed Vimeo samples, it seems to have decent center sharpness, almost tolerable distortion and very blurry corners like almost all toy lenses.
Not an alternative to the 12mm 1.6 for me, but if you can live with its drawbacks, it's less than half the price though.
