Zoom lenses are parfocal, by definition. The back focus just needs to be adjusted precisely to ensure parfocal operation. (something which can be difficult to do, depending on the lens and the adapter)
Those are old lenses. They're fine, but they'll be a bit hazy at their widest aperture settings. At f/5.6 they'll be pretty good. Just don't expect miracles from old zoom lenses. Most of them are flare-prone. You need to shade them from the sun.
As a rule, constant aperture two-touch zoom lenses do not extend while zooming. I'm pretty sure the Soligor and the Tokina don't extend while zooming by the looks of them. Not so sure about the Angenieux, but probably, since it's so long.
Was wondering if anybody on here could help me out:
I'm looking for an affordable tele-zoom (pref. 70-210ish) that matches my current contax-zeiss set. It needs to be f4 or faster constant aperture and two touch (!), parfocal and non-extending barrels, contax mount if possible. Any suggestions?
My research brought up a 70-210/f3.5 angenieux that's apparently quite good, but too pricey and seemingly can't be found in contax mount. Apart from that there's the Soligor MC C/D 70-210/f3.5 and the Tokina RMC 70-210/f3.5, both in contax mount and constant f3.5. Any infos on the two? Are they fixed barrels vs. extending? Parfocal? Edit: Are they any good at all?
Thanks in advance!
disregard my entry as under a more detailed analysis (monkey with sugar spoon dancing the moonlight) the low end of the range showed focus deviation; so not consistently parfocal throughout the range. Sorry for any inconvenience, coffins' not for free :P
So many times I've started (oh excuses... hell is mostly full of them... and layers and church ministers)... but as I never have time nor patience enough to finish a proper shootout, just the first minute and the half is a very loose and inconsistent comparison of the following manual PP zooms (nikon mount):
Soundtrack
Reggie Watts @ TED
gashô
A nikkor still sample forba bay developed with BCS_HP-64 LUT =)
Jezus de mi alma y mi corazón!!! That last photo of the moon was developed by I retarded blind bat :P
Very interesting lens, the Vivitar 28-200 f3.5-5.3, lot of pros and cons... still need further acquaintance.
3 pics, ranging from the "wide" side, to 200mm, and macro. All handheld, settings I really can't remember.
BTW, considering how cheap they sell - 2 for each donut - would the experienced board of the elderly (:P) say
minolta MD 50mm f2 (49 filter thread) is a hidden gem? + lot's of samples WO, mounted on a nex though - here
This mouth to mouth trusted info it's very nice... nevertheless to me some details /extra info and personalized experience is missing.
Starting with the very first lens: Vivitar 28-200 f3.5-5.3 serials beggining with 77 aka Kobori motherfucka.
The sample I have is nikon mount:
When I have the time I promise to test it further, probably even making a mega orgy comparisson thingie.
VIDEO - GH3, mov 24p long GOP / shutter 25 / ISO 200 / WB daylight / Natural -5 -2 -5 -5
1 Shot at 200mm f-stop around 5.6 and the other 200mm + ETC same settings
No colour tinkering other than a LOG to Rec709 LUT and adjusted levels.
A sweep of NR and a pinch of sharpening =)
Here's the lens manual - vv28-200 / Source: allphotolenses
gashô
PS
I forgot, something OT but interesting, crop made in AE with creative impatience free plug, totally worth checking their free stuff =)
An while I'm at it, SOC Vivitar 28-200 f3.5-5.3 / Nikon AI 80-200 f4.5 / Vivitar 70-210 f2.8-4 / Panasonic 14-140 f4-5.8 all in ETC mode, see if you guess which is which, actually it's quite easy =)
Moon photo 1:1 quick&dirty developed
@belfryman later I found that with that lens the minimum focus distance is quite big, more than 1m if I recall right.
Do you find an adapter which changed the minimum focal distance? That's peculiar. Does it focus to infinity?
BTW I bought another similar Vivitar, the 28-90 1:2.8-1:3.5 Series 1 which is really good as well. It also has a macro mode and you can get as close 2cm
Ah, put another adapter on and bingo, the vivitar 28-200 is working great! That's the end of my diversion!
@flablo the wider it is the longer the distance has to be to the subject to be able to focus on mine. About 55 mm is about 15' at about 30mm it's about 30'. Have you found a solution? Sorry, this is a bit off topic.
@flablo I have the same thing, under about 10' can't focus unless in macro, kind of makes sense with the marking on the focus ring that only has down to 10' on it, doesn't make it less frustrating though.
Hmm, looks like I got a bad one - the few test images I've taken are quite hazy and when you hold it up to the light, although the front & bck elements look clean enough, if you angle it slightly it's quite 'milky'. The adapter has a bit of radial play in it too, so all in all, not a great day's eBaying!
I think a lot of these Chinese parts are the same but branded under many different names
I couldn't agree more, +1
Thanks. I've ordered one on eBay that looks to be the same as the Bigis one - I think a lot of these Chinese parts are the same but branded under many different names - certainly if they're anything like Chinese motorcycle parts, they are! The Cosmicar 75mm I've got is f1.9 - see below. The one in the picture above is a Pentax branded 25mm, which is f1.4
@TheLoneRoger: I can recommend the "Bigis" one. It´s working like a charm. (And it´s also pushing the pin inside the lens ... Which is neede for "auto" lenses. They only work manually when the pin is pushed inside the lens.)
@TheLoneRoger
Just check eBay. It's full of the adapters. I've ordered often directly from Hong Kong for just a few $ and they were all really well-done.
Which 75mm Cosmicar is this? There are versions in 1.3, 1.4 and 1.8 floating around in the bay.
Just bought a Vivitar 28-200 (777) on eBay with M42 mount; can anyone recommend a suitable Micro 4/3 adapter? Cheers. Agree with the comments about the 25mm and 75mm Cosmicar lenses - great lenses for the price, even if the 25mm looks ridiculous on an AF101!
Does anybody know if Soligor 28-200 3.5-5.3 (no.99...) is the same construction as Vivitar/Kobori? Thanks!
No one knows it, I think. But it can be. If you can get it cheap you can test it yourself.
@Vitaliy_Kiselev thank you for lens suggestion and hacks, thank you for everyhting.
Cheers!
I've got a Soligor 35-70mm f2.5~3.5, declicked w/ 8 aperture blades, and does macro pretty well.
@apefos - yes, I see the same thing. The crop factor really classes up the FD lenses by removing their soft corners.
@tetakpatak - Thanks for the comments about the FD 50mm F/3.5 macro. I would buy one but I have the Panasonic/Leica 45mm macro which is just a phenomenal lens. (It sounds like we have very similar FD lens kits except for the 50mm macro.)
@apefos yes, I have it, it is correct behavior, as FD 20mm f/2.8 just isn't top class lens. It is just good, nothing exceptional. It is not a gem and it is also not hidden :-)
@tetakpatak do you have the Canon FD 20mm 2.8 in your set? If yes I would like to ask if you have this same issue:
When I use it on the GH2 the image sharpness is ok in center and corner at 2.8 (wide open) because GH2 just uses the center of image circle due to the sensor crop factor.
But when I use it on the Canon FD A1 old full frame film camera, the corners are very soft and blurred at 2.8 and the lens becomes usable at f5.6 and above.
The FD 20mm 2.8 I tested was very good condition, looks like mint, so I supposed the corner softness in full frame is normal from this lens at wide open f-stops.
I wonder why nobody has mentioned the KMZ TAIR 11A 2.8/135mm (M42) yet. 20 Aperture Blades: can you spell BOKEHHHH ! ;) Rare to get one in very good condition, needs a good tripod but absolutly beautiful in terms of IQ/color rendition and the creamiest bokeh of all russian glass.
Still looking for a good one myself, only had the chance to borrow it from a friend of mine till now (he got a rare one with a leading zero in the serial no. ) :(
