The super wide view is a complete gimmick. It stretches 4:3 to 16:9.
The low light mode sounds good but it only works in 30p and 48p modes because the lowest it can go is 24 FPS.
The old camera should be able to use the new batteries.
It really looks like the only thing they have changed is the lens, and added faster wifi. I would love the new lens but the wifi doesn't bother me that much.
This is the first GoPro release where they really were not high fiving each other. Maybe patting themselves on the back but they aren't going to get many people to upgrade until they put the A9 chip in a GoPro 4.
..they're gonna need the ambarella chip, and what's even more important, use all of its' attributes !
Is it shipping with pal frame rates?
ALL GoPro models have selectable Pal/NTSC frame rates.
I'd buy a gopro off her. but im gonna wait out for next years gopro and give these ones a miss.
You guys with Hero 3 Blacks upgrading? I initially wanted to do it but having second thoughts now.
I have two basically new Hero 3 that I bought for a project that didn't turn out. Bought the 3+ to try out...yes the IQ improvement is worth it to me. Should fit the old cases meaning my Cobalt cages would still work...
Hmm...what am I going to do with my two hero 3s....
I am waiting for a GoPro 4. I shot a bunch of video with the regular 3 this weekend and the 3+ wouldn't have helped at all. I am still not convinced that it always improves the image quality. I have seen some comparisons where I liked the 3 better.
What I really want is 1080p @ 120 FPS. The 720p @ 120 FPS mode is garbage. 2.7K @ 60 FPS would be great as well.
@mpgxsvcd Why do you say the 720-120 is garbage?
Because it is garbage at 720p @ 120 FPS indoors which is all I use it for. I shot the video below with the GH3 and the GoPro 3 mounted on top this past weekend. You can see a few clips in the beginning from the GoPro 3. However, those were 1080p @ 60 FPS clips.
I have the GH3 for the tight shots with low motion. What I really need is a wide angle camera that has very deep depth of field that I can get really close to the action shots with. The GoPro can get decent indoor quality at 1080p and especially at 2.7K. However, the frame rates are not quite what I wanted with those resolutions.
I had several GoPro 3 720p @ 120 FPS clips of the dynos that the kids were doing. Trust me they were unwatchable mush because of the compression and poor lighting. Instead I had to use my 25mm F1.4 lens wide open to get those shots with the GH3. That lens was not quite wide enough and it had too shallow of a depth of field to maintain focus the entire time.
I tried the 14mm F2.5 lens but it could not get enough light in so I had to try to make the 25mm work in very close quarters.
Mpgxsvcd >Because it is garbage at 720p @ 120 FPS indoors
That sounds more like an issue of using the wrong mode on the camera or even the choosing the wrong camera if your expecting good quality indoors at that frame rate. Not the cameras fault.
There is a lot more noise on Narrow and Medium than on Wide for the 1920x1080 modes (IMHO). I don't use them. I only use full-wide at 1920x1080 24fps, Protune. That is the sweet-spot for me, along with 2.7K Cine Wide 24fps Protune.
I understand that I am asking a lot for the 120 FPS mode to work in low light with such a small sensor. However, it isn't that great outdoors either.
There is such a HUGE jump in quality from 720p to 1080p on the GoPro 3 that I just wish 1080p could do 120 FPS.
Honestly, if I could get 2.7K @ 60 FPS I would probably be completely satisfied. Isn't the A9 capable of that?
HERO3+ Black Edition – update 2.0
HERO3+ Silver Edition – update 2.0
All HERO3 cameras – update 3.0
Blog post about ProTune 2.0
VK, you might want to note that the "All HERO3 cameras – update 3.0" was an earlier update from July 2013, there are no new updates for the Hero3 cameras only the 3+
Got it. It is from GoPro PR.
Yep, by including the old Hero3 update on the press release, GoPro have pissed off many Hero3 owners you thought the new features also applied to that camera...they ain't happy :-)
There is also this from the yet to be updated Hero3+ manual about Protune.
With the latest HERO3+ Black firmware update (March 6, 2014), Protune has four new controls for more flexibility.
I know there has been some concern expressed here that the need to color correct in post is too much burden for some, especially those not using Studio, but you still want the higher data rate or less-sharp image. Also, our broadcast customers often don't have time to correct before airing, but want the higher data rate too.
Now you can use the normal GoPro Color development AND still have control over sharpness and utilize the higher bitrate!
Here's the language from the updated manual:
PROTUNE SETTINGS Protune enables advanced control of White Balance, Color, ISO Limit, Sharpness and Exposure.
PRO TIP: Making adjustments to your Protune settings will not affect your non-Protune video modes. You can reset your Protune settings to their default states by selecting RESET in the Protune menu.
[list][b]White Balance[/b] - White Balance adjusts the overall color tone of videos. Standard video records in AUTO White Balance only. Advanced users can make adjustments to the White Balance settings when in Protune mode.
White Balance Setting Recommended Lighting Conditions 3000K (Default) Warm light (incandescent or sunrise/sunset lighting) 5500K Slightly cool light (cool fluorescent, average daylight) 6500K Cool light (overcast conditions) Cam RAW Industry standardized optimized color
PRO TIP: Cam RAW mode yields a minimally processed data file direct from the image sensor that allows for more precise adjustments to be made in post-production. Recording in this mode takes full advantage of the image sensor’s capabilities.
[b]Color[/b] - Color allows you to adjust the color profile of your video footage. There are two Color options: GoPro Color (default) and Flat. GoPro Color delivers the same great color you get when Protune is turned OFF. Flat results in a neutral color profile that can be color-corrected to better match footage captured with other equipment, offering more flexibility in post-production. Due to its log curve, Flat captures more details in shadows and highlights.
[b]Color Setting Resulting Color Profile[/b] GoPro Color (Default) - GoPro color-corrected profile Flat - Flat, neutral color profile
[b]ISO Limit[/b] - ISO Limit adjusts the camera’s sensitivity in low-light environments, and creates a balance between brightness and resulting image noise. A higher ISO Limit will result in brighter footage, but you may experience more noise. A lower ISO Limit will result in darker footage, but will deliver reduced noise.
ISO Limit Setting Resulting Video Quality 6400 (Default) Brighter video in low light, increased image noise 1600 Moderately bright video in low light, moderate image noise 400 Darker video in low light, reduced image noise [b] Sharpness[/b] - Sharpness controls the sharpness of your video footage. There are three Sharpness options: Low, Medium and High.
Sharpness Setting Resulting Video Quality High (Default) Ultra-sharp video Medium Moderately sharp video Low Softer video that allows for more flexibility in post-production
[b]Exposure[/b] - Exposure compensation affects the brightness of your video. Adjusting Exposure can improve image quality when shooting in environments with contrasting lighting conditions.
Exposure Settings +2.0 +1.5 +1.0 +0.5 0 (Default) -0.5 -1.0 -1.5 -2.0 [/list] Pro Tip: Exposure compensation adjusts brightness within the existing ISO Limit. If brightness has already reached the ISO Limit in a low-light environment, increasing your Exposure compensation will not have any effect.
And yes, Studio 2.0.1 supports all the new features, too.
