  • 4493 Replies sorted by
  • @Mirrorkisser
    Either would work. I think the Nikon mount would be more universal, though, because it should have an aperture lever on the back and would only require an adapter that can utilize that. EF version needs electronics. =T
    I'm probably going to switch to Nikon as well pretty soon, caveat's the barrel rotation direction.
  • @kholi thanks a lot m8! i am looking at the sigma aswell and am undecided whether i should pick the nikon or canon version, i guess both should work with an mft adapter on the pocket?
  • If you get yours let me know I am through with B&H and their BS.
  • @No_SuRReNDeR, I thought the same thing about Adorama... I was really just putting in an order somewhere because I figured it would ship at some point, whatever. I've got a tracking number and my card's been charged though - so I assume Adorama's being honest about it.
    About the workflow, I'm aware - been using Resolve to grade my stuff for a while, and I've also been shooting RAW video on my 5dmk3, etc. A big draw for me here over the mk3 actually is getting prores straight out of the camera rather than the massive RAW files the mk3 shoots (which just leads to a lot of extra data wrangling I'd rather not spend time on for smaller projects). Heck I might even shoot video gamma in some cases, I guess I'll have to test it and see if I'm happy with the results versus log.
  • @Oedipax
    I called B&H and the rather irritated guy on the phone told me they were still shipping April orders ....... FACEPALM!!!!!!!!!!!!!!! I do however find it hard to believe that Adorama has a stack of cameras ready to ship, it does appear that way on thier website though....but I have a feeling they leave it like that so people will be lured into ordering. Also if you haven't worked with film or cinema cameras in narative work....you may be disappointed with this camera and its appropriate workflow.
  • Right now I've got a regular cheap EF to MFT adapter and a Kipon EF to MFT iris adapter. I don't really recommend the Kipon, only because I have no idea what it's actually doing to the image when you stop down but it is an alternative if you aren't too critical about your footage.
    It also doesn't' vignette on the 2.5K or Pocket, because the sensors are smaller than standard MFT.
  • @kholi which sigma (18-35) with which adapter did you use? thanks!
  • For you guys still waiting on cameras, I ordered a BMPCC from Adorama on Saturday and it shipped today, I should receive it tomorrow (paid extra for overnight).
    Even though I've been aware of this camera since word of it first leaked out, it was still kind of an impulse buy for me. I initially intended to get the 4K cinema cam instead. What it's come down to for me is ultimately I prefer a camera with SD cards, removable batteries, a smaller form factor, and some extra dynamic range. I can more or less treat it like a souped-up GH2 (at least, that's my hope).
  • The 2.5K preset in Film Convert likely wouldn't work very well, the LOG from both cameras are slightly different, but slight is enough to produce vastly different results.
  • Anyone know which FilmConvert preset is best for Pocket footage? I have been using the BMCC film preset but I don't really like it, perhaps it looks like "film" but I would prefer a cleaner image. Maybe my problem is just with FilmConvert itself... Resolve Lite does not work on my computer for some reason ("QuickTime decoder initialization failed")... What are my options?
  • @spacewig
    Preface: I'm pretty new to color (operating) and will start working in a DI theater for the first time this coming week, and from there on. So bare with.
    So log footage does need a curve. And not all Log footage's created equal: Alexa LOG C, in my experience, is different than Sony's S-Log, Canon's Log or C-Log, and Blackmagic's LOG which is BMD Film (I believe that's what they're calling it unofficially).
    Each needs a different curve, and that's where a lot of the learning at. I think Sony actually released their curve with the F55, but a lot of people weren't digging it.
    My knowledge is pretty limited (clearly) but I believe REC709 is considered a tonal curve, so in R9/R10, you look under the LUTs and you've got a Blackmagic to REC709 LUT that pre-applies the REC709 LUT specific to BMD FILM (LOG) to get it out of the log space.
    The issue is that REC709 is hyper-limiting, and almost defeats the purpose of shooting such a wide gamut. You have to fit all of it within this old spec that needs to be de-comissioned (and I think it will be soon, REC2020 is up for UHD right? Someone correct me).
    You can also use the Arri to Rec709 LUT as a starting point, but again it puts you into REC709 and you have to work around that.
    With the 2.5K, and shooting RAW (which will be the same with the Pocket Camera) you can choose between BMD FILM (which looks like the ProRes Log) or REC709 as the DNG color space option. We dug around in the footage for quite some time exploring the difference between the REC 709 option in the CinemaDNG tab, versus the REC709 LUT, and noticed that a lot of what we thought was gone or in-correctable with the DNG tab REC709 was actually just fine when using a LUT.
    Or better, when using the BMD Film setting.
    Right now, for Blackmagic footage (2.5K and Pocket) I'm using an INPUT LUT that I half-assed and a different combination of OUTPUT LUTS (Arri-to-709, Macrgregor's F35 S-Log LUT which looks to be a variation of the Arri-to-709, and the Kodak/Fuji to R709) as a starting point, and sometimes nothing at all.
    I'm also getting into an ACES workflow which is interesting, and exploring REC2020 IDT with sRGB or 709 ODTs for web delivery, to see how footage responds. Not completely sold on it because it's always changing (ACES is in development), and two, there's always a steady green spike on waves and scopes.
    Anyway, babbled enough, basically you just need to start with the right curve or make your own that looks great on your scopes.
    Edit here: I also think someone like Shian would be able to elaborate more on LOG if he's paying attention to the thread.
  • @kholi could you elaborate a little on how to pull the footage out of a Log space?
    Cheers
  • To be honest, I don't think most of the owners/users are apply a curve, they're just fidgeting until they can figure things out. Taking a look at the examples posted, you can see strange magenta/blue casts in mids etc., that's a sign of not exactly knowing where you're going or how to get there.
    I don't think Film Convert works well, personally, until you've pulled the footage out of a Log space.
  • This S-Curve thing makes sense. People's first inclination from very flat footage on a DSLR is going to be to throw an S-curve on the thing, and it sounds like that will cause trouble here with the way the camera is distributing the mids. I would expect Film Covert to work better, however, as their LUTs are custom for each camera, correct?
  • It's a little more than " a few more stops and 10 bit" but to each his own :)
  • @oscillian Wow... wish B&H would send my damn camera I ordered in flipping June. Well I can see why for what you do it doesnt work, I however do both that an Narative/Theatrical work and for me ... having this PLUS a GH3/GH2 etc... is a home run since I can base the camera choice on the workflow I need and I dont have to reinvest lens wise.
  • Just got a call today from my dealer that my preorder camera was in. And I turned it down!
    The way I see it, neither Prores nor Raw will add anything useful to my line of work (Event shooting and personal projects) and I value the ease of use of the DSLRs over a few more stops of dynamic range and 10bit.
    I'm spending my money on the SpeedBooster/Sigma 18-35 combo instead once the Nikon version is out. For now the G6 does everything I need until Olympus gets their video act together or if the GH5 gets as good IBS as the OM-Ds.
  • Filmconvert does compress the highs and lows (and the mids, for that matter). But it's useful for previewing and editing, if the system can apply it real-time -- and without the need of baking it in from the start.
  • @kholi I think you're right about the FilmConvert stuff. Now that I think about it, all that footage is muddy. LUTs I use from the 2.5K work much better as starting points here.
  • @MRfanny
    Definitely the way that they're handling the footage. Similar to the grey-blue cast thing that existed on the 2.5K. Also, I see a number of people turning to film convert for the footage, so maybe that's it as well?
    Also, older glass/vintage glass. It's part of the look shooting with Kowa Anamorphics and Super Baltars, this like "muddy" haze. Something that you almost can't correct out in broad daylight.
  • Yes, everyone does understand you need to grade and possibly sharpen the footage right?
  • This is not the best example because there are no bright highlights in it, but it its what is infront of me right now, and it does show much must is contained in that bottom 25 percent. Luckily, they lift up easily.
    (1600ASA panny 25mm @f1.4)
  • Part of the reason it feels muddy is that I think many people are attempting to apply an S curve to it, which is not what you want to do with this footage. My sense from a few days of filming that 18 percent grey is falling really low, and the vast bulk of the stops — 8 or 9 would be my guess, are above 18 percent gray, so if you are exposing for highlights, you are actually pushing most of your mid-tones on down into the bottom 25 percent of your negative (which is fine because you can lift them). But if you apply a S curve to the footage, you are turning everything from midtones down into mush. Adding to that, even in really dark situations, when I look at the footage on a waveform, there is sometimes not a true black, which contributes to the muddy feeling because without a visual reference of true black on screen, it will feel muddy.
    I find I get very clear, non-muddy results by dropping the setup to legal or just below (usually -4 to -10) then raising highlights until they are just about to clip. Maybe lift gamma tiny bit (and then bring setup down again). But no S curve.
    I think a lot of shooters on this camera will be coming from DSLR where S-curves are great because 18 percent gray is falling in the middle of your 8 or so useable stops. As a consequence, I think you can expect to see some really poorly graded footage out there.
  • maybe "muddy" was abit overkill ha. yeah out of the cam maybe or off white balance, but it does go away to a degree after grading. I see it in some pocket clips posted up, could simply come down to people not realy noticing when grading or just wanting that look.
    That ouback clip for example, to me just has that slight brown haze to it.
    and this https://vimeo.com/groups/pocketcamera/videos/75815230
    this is interesting, i can see a slight cast in ungraded footage that becomes more obvious when its graded
    The greens in foliage doesn't look green enough to me. Like i said it could just be the grading or film grain applied. I mean I am no colourist so if you and vicchriss dont see it theres a good chance you guys just know how to correct it better.
  • Ohhh, so that's just how the Log looks out of the camera, the muted "muddy" cast. Doesn't look like it was touched at all so that's what it'll look like.
    Are you guys seeing it in footage after color or a curve? You kinda want to get it out of the Log space so you can work with it.
