GH2 High Quality GOP3 Settings, Series 2: 'AN' Valkyrie, GOLGOP3-13, GOP3ZILLA, Duke, natural :-)
  • 670 Replies sorted by
  • On the work in Spizz, Valkyrie was also further improved.
    As a result of getting @Azo to try HBR30p, it is clearly better than BETA4.3.
    Although I have repeated the test of Spizz, I plan to release it after that. :-)
  • Valkyrie 444 TYPE-ZERO4 BETA4.4
    bkmcwd "Valkyrie 444 TYPE-ZERO4 BETA4.4" - seta.ini - Released 04/09/2013
    *All the rec modes were changed from BETA4.3. :-)
    This TYPE-ZERO4 is also the version as which "balance of gradation and resolving" was considered in all the modes.
    I think that the freezing issue at the moment of the focusing and zooming was solved nearly perfectly also in Panny lens use.
    Although towi's Death Movie is cleared in all the modes, there is no telling whether span is possible in other than 24p.
    *Probably, other than 24p, it may be unable to span occasionally.
    Cautions are required to use iDRC or iA only in 60p.
    Please try it! And I am very glad if I can get feedbacks from you.
    *If this is also still unstable, I will further adjust.
    Special thanks to @Azo, @towi and all silent users of my settings! :-)
    Of course, many thanks to @cbrandin and KING @driftwood!
    • Superb-looking Pure Original 444 matrix from cbrandin is adopted in 24p mode
    • Modified 444 matrix from my BETA Team in Japan is adopted in HBR/1080i and 720p modes
    • Upto 140M for Top Quality 1080p24 at Q18
    • Upto 140M for Top Quality 1080p30 at Q18 in 24L mode with 80% Slow-Motion Mode (No Sound)
    • Upto 75M for Top Quality HBR/FSH modes
    • Upto 75M for Top Quality 720/50p modes
    • Upto 75M for Top Quality 720/60p modes
    • Extremely reliable top performance in AVCHD 24H and 24L
    • 80% Slow-Motion is available in 24L only
    • Fully working iA and iDynamic range modes if you require them (Take care only in 720/60p)
    • Beautiful 3 GOP bringing short GOP style detail & movement-rendition in all the modes
    • Bush of Death / Death chart tested.
    • Wonderful Pasadena Pulse Audio Patch V2 B2, by Per Lichtman
    • Top quality 2K mjpeg Mode in HD by Nick Driftwood
    • In camera playback is sometimes not available in 24p. (Standard) In other mode, Sometimes available after reboot the camera.
    *Supposing you use "SH" mode safely in 60p, please turn OFF iA and i dynamic range control. On the other hand, in other rec modes, it is satisfactory at all.
    bkmcwd Valkyrie 444 TYPE-ZERO4 BETA4.4.zip
    1K
    1297 x 632 - 544K
    1295 x 631 - 523K
    1297 x 633 - 523K
  • I am also preparing Valkyrie 444 TZ3 in which span is possible in all the rec modes. :-)
    About a "Lite version", it is due to be unified with TZ3.
  • Valkyrie 444 TYPE-ZERO3 2.0
    bkmcwd "Valkyrie 444 TYPE-ZERO3 2.1" - setb.ini - Released 09/09/2013
    bkmcwd "Valkyrie 444 TYPE-ZERO3 2.0" - setb.ini - Released 05/09/2013
    This TYPE-ZERO3 is the version in which spanning is possible in all the rec modes.
    Also on towi's Death Movie, span is possible for all the rec modes.
    • Superb-looking Modified 444 matrix from my BETA Team in Japan is adopted in all the modes
    • Upto 110M for Top Quality 1080p24 at Q18
    • Upto 140M(110x1.25=137.5M) for Top Quality 1080p30 at Q18 in 24H mode with 80% Slow-Motion Mode (No Sound)
    • Upto 65M for Top Quality HBR/FSH modes
    • Upto 60M for Top Quality 720/50p modes
    • Upto 60M for Top Quality 720/60p modes
    • 80% Slow-Motion is available in 24H and 24L both with
    • Beautiful 3 or 6 GOP bringing short GOP style detail & movement-rendition in all rec modes
    • In camera playback is available in all rec modes,
    *Although I have received the report that it was able to be used also with the slower card, I especially recommend you use with SanDisk 95MB/s 64GB SDXC card.
    bkmcwd Valkyrie 444 TYPE-ZERO3 2.0.zip
    1K
    bkmcwd Valkyrie 444 TYPE-ZERO3 2.1.zip
    1K
  • I gave explanation to TZ3.
    Spanning is thought as important in TZ3 of Valkyrie.
    Image quality is thought as important in TZ4.
    For the next, I would like to prepare GOP3ZILLA by which span was thought as important. :-)
  • Please, make Valkyrie 444 TYPE-ZERO3 2.0 with anamorphic modification of the latest MJPEG 2k settings.
  • @producer
    Hi mate,
    Honestly, since I do not use MJPEG mode, I am not detailed about it.
    If the setting containing the MJPEG mode which you have used regularly is shown to me, I will combine it. :-)
  • @bkmcwd:
    Actually I combined it time ago - the 100Mbps anamorphic patch. But since there are newest best called settings for MJPEG mode, I'd like to see a patch which consists of those latest best MJPEG settings with anamorphic resolutions. It's easy to change the resolutions in PTool, but I think that some other parameters must be modified in accordance with the best normal MJPEG settings. That's my point.
  • @producer
    OK, I also study about MJPEG mode. :-)
  • Now, I am working on new "natural" setting. With this, spanning is possible in all the modes.
    In this week, I will release it. :-)
  • Valkyrie 444 TYPE-ZERO4 BETA4.5
    bkmcwd "Valkyrie 444 TYPE-ZERO4 BETA4.5" - seta.ini - Released 12/09/2013
    *Only 720p modes were changed from BETA4.4. :-)
    Although towi's Death Movie is cleared in all the modes, there is no telling whether spanning is possible in other than 24p.
    *Probably, other than 24p or 720p, it may be unable to span occasionally.
    • Upto 145M for Top Quality 1080p24 at Q18
    • Upto 145M for Top Quality 1080p30 at Q18 in 24L mode with 80% Slow-Motion Mode (No Sound)
    • Beautiful 3 GOP bringing short GOP style detail & movement-rendition in 24p and 1080i/HBR modes
    • Beautiful 6 or 9 GOP bringing short GOP style detail & movement-rendition in 720p modes
    • Bush of Death / Death chart tested with Panny lens.
    • In camera playback is sometimes not available in 24p. In other mode, Sometimes available after reboot the camera.
    bkmcwd Valkyrie 444 TYPE-ZERO4 BETA4.5.zip
    1K
    1297 x 631 - 549K
    1295 x 632 - 563K
    1299 x 636 - 554K
    1295 x 634 - 575K
    1298 x 634 - 602K
    1296 x 631 - 568K
    1298 x 634 - 499K
  • In Valkyrie 444 TZ3 2.0, since there was a mistake type, TZ3 2.1 corrected is released. :-)
    http://personal-view.com/talks/discussion/comment/140542#Comment_140542
  • 6GOP and 9GOP are adopted in 720p of TZ4 BETA4.5,
    Image quality has been improved than 3GOP. :-)
  • Valkyrie 444 TYPE-ZERO3 2.2
    bkmcwd "Valkyrie 444 TYPE-ZERO3 2.2" - setb.ini - Released 13/09/2013
    *Only 720p modes were changed from 2.1. :-)
    bkmcwd Valkyrie 444 TYPE-ZERO3 2.2.zip
    1K
    1295 x 633 - 509K
    1295 x 633 - 508K
    1298 x 634 - 508K
    1296 x 633 - 558K
    1295 x 632 - 571K
    1298 x 633 - 547K
  • @zilk The dynamic range of the image looks impressive! How much does it improve from stock? Do you plan on releasing the settings of it?
  • @shirap
    Hi mate,
    Thanks for your beautiful footage! I'm looking forward to the completion of your movie. :-)
  • Hi, just a little question : Is the 444 Matrix the an improved version of the "Cinema Smooth Matrix", or is it complitely different? Thanks
  • @zsound
    Hi,
    These are different matrices. Please refer to explanation by @cbrandin in the link place. :-)
    http://personal-view.com/talks/discussion/comment/101633#Comment_101633
  • natural_3_BETA1
    bkmcwd "natural_3_BETA1" - setf.ini - Released 20/09/2013
    I release the new "natural_3" setting with stock matrix.
    This setting aims at spaning in all the rec modes.
    And, this is the optimal setting for enjoying 3GOP with small file size.
    *Please try this! And many thanks for feedbacks from you!
    Special thanks to @Azo. :-)
    NOTE:
    • Upto 110M for Top Quality 1080p30 at Q18 in 24L mode with 80% Slow-Motion Mode (No Sound)
    • Upto 70M for Top Quality HBR/FSH modes
    • Upto 65M for Top Quality 720/50p modes
    • Upto 65M for Top Quality 720/60p modes
    • Beautiful 3, 6, or 9 GOP bringing short GOP style detail & movement-rendition in all the modes
    • Spanning is available in all rec mode
    • In camera playback is available in all rec mode, at least available after reboot the camera
    bkmcwd natural_3_BETA1.zip
    1006B
    1293 x 1893 - 2M
    1296 x 1900 - 2M
  • @bkmcwd
    Thank you for making Valkyrie 444 TYPE-ZERO3 2.2/natural_3_BETA1 available to us . I sincerely appreciate your effort in making an extremely reliable patch that will span in all modes.
    Best Regards
    Azo
  • @Azo
    Thanks for comment, mate. :-)
    Since it is still slightly unstable about TZ3, I am adjusting it now. First of all, please try from natural3.
  • Valkyrie 444 TYPE-ZERO3 2.3
    bkmcwd "Valkyrie 444 TYPE-ZERO3 2.3" - setb.ini - Released 22/09/2013
    *Only 1080i/HBR modes were changed from 2.2. :-)
    bkmcwd Valkyrie 444 TYPE-ZERO3 2.3.zip
    1K
    1297 x 631 - 543K
    1297 x 634 - 460K
    1070 x 713 - 235K
  • @bkmcwd Do you sleep?-You are tireless creator of great settings and great improvements for settings. 3 cheers for @bkmcwd - hip hip hooray!
  • @matt_gh2
    Hi mate,
    Many thanks for your kind words. :-)
    I am testing simultaneously, working. Of course, I am sometimes sleeping. LOL
Start New Topic
Howdy, Stranger!
Sign In Register as New User
Tags in Topic
Top Posters
