IBC 2013 and upcoming new stuff
  • 39 Replies sorted by
  • Panasonic 4K VariCam
    AMSTERDAM. 13 SEPTEMBER 2013 -- In response to the growing worldwide demand for 4K production, Panasonic Professional Camera Solutions is prioritizing the development of the 4K VariCam camera recorder. The VariCam will be a highly practical camera, boasting features and performance suitable not only for 4K cinema, but also HDTV content production. The camera is set for launch in 2014. Panasonic has also unveiled the development of the new Ultra P2 cards at IBC.
    With the 4K VariCam, Panasonic is tending to businesses that are increasingly looking for suitable, and above all affordable, equipment to create 4K production environments. By using large-scale integration chip technology (LSI) boasting AVC-Ultra, the new extension of the AVC-Intra codec format used widely in HD recording, Panasonic will speed the development of its 4K VariCam.
    By integrating the latest 4K technology, the VariCam will support 4K shooting from 24p to 100/120p. To enable even better 4K video productions, Panasonic will fit the 4K VariCam with a newly developed Super35mm size high sensitivity image sensor with 4K resolution. The sensor will feature wide dynamic range, extended colour space, and support for Log.
    Moreover, in order to support highly reliable recording at high bit rates, new Ultra P2 cards will start shipping in conjunction with the 4K VariCam camera recorder. The form will be the same as traditional P2 cards, with a high speed PCIe interface adopted to enable high speed data transfer. Currently, 256GB Ultra P2 cards are planned for production.
    Shipment of the 4K VariCam and the new Ultra P2 cards will start in 2014
    Panasonic VariCam 4K Video at 24p to 100/120p, Super35mm sensor, 256GB Ultra P2 cards, release 2014
  • Matrox® Video today announced that Vizrt, the world's leading provider of real-time broadcast graphics, has chosen the Matrox DSX LE3 4K card to power the next generation of the Viz Engine rendering engine and compositor. Viz Engine is the heart of all Vizrt graphics and video solutions (CG, Virtual Set, Weather, and more). It renders animated 2D and 3D scenes in real time, producing high-end animations in SD, HD and 4K.
    A new addition to the Matrox DSX™ Developer Products family, the Matrox DSX LE3 4K card enables realtime monitoring and output of video footage at resolutions up to 4096 x 2160 at frame rates up to 60 fps. This new 4K output card, in conjunction with the industry-leading Matrox DSX Software Development Kit and 4K codec support for ProRes and XAVC, lets equipment manufacturers create graphics systems, editing solutions and playout servers in native 4K resolutions.
    Vizrt 4K solutions based on the Matrox card can be seen at IBC2013 (Amsterdam, September 13-17) on the Vizrt stand 7.A10, the Sony stand 12.A10 and the Snell stand 8.B70. Matrox DSX LE3 4K will be showcased on the Matrox stand 7.B29.
    Key features of Matrox DSX LE3 4K
    • 4K (4096 x 2160), QFHD (3840 x 2160), 2K (2048 x 1080), HD and SD output resolutions
    • 60 fps frame rate support, even at 4K resolutions
    • Provides full 4K output to drive a Sony PVM-X300 reference monitor
    • Can take advantage of the integrated NVIDIA GPUDirect™ SDK to offer low latency and high throughput data transfers at 4K resolution with the NVIDIA Quadro® GPU series
    • SD, HD and 3G-SDI connectivity per SMPTE 259, 292 and 424/425M Level A and Level B mapping
    • 8- and 10-bit YUV output at all resolutions and frames rates
    • 16 channels of SDI embedded audio support
    • Bi-level and tri-level genlock input
    • Five full-size BNC connectors directly on the card bracket
    • Support for 4K ProRes and XAVC software codecs
    • Extensive native codec support in HD and SD
    • Cross platform file format support — MXF, MOV, AVI and MPG
    Whether you’re working in an SDI-based workflow, utilizing cost-effective HDMI equipment or both, Io 4K has you covered with a complete set of full-sized connections for video and audio as well as Reference, LTC and RS-422 control, making Io 4K the choice for working professionals.
    Take portable production and post to the next level with Io 4K. Small enough to fit in a backpack but powerful enough for even the most demanding projects, Io 4K can work with resolutions from SD up to 4K. Get the performance you need for current HD projects and move to UHD or 4K instantly when needed.
    http://www.aja.com/en/products/io-4k/
    559 x 299 - 38K
    AMIRA features the same sensor and exceptional image quality as the ARRI ALEXA, recording superior HD 1080 or 2K pictures that are suitable for any distribution format. With a dynamic range of more than 14 stops, low noise levels, subtle highlight handling, natural color rendering, breathtaking skin tones and speeds of up to 200 fps, AMIRA will deliver beautiful, life-like images in any situation.
    AMIRA records Rec 709 or Log C images using ProRes LT, 422, 422HQ or 444 codecs. By recording to in-camera CFast 2.0 flash memory cards with super-quick data rates, the route into postproduction is made as simple as possible. CFast 2.0 is an open format, easily accessible to anyone and delivering a fantastic price-performance ratio through incredible transfer speeds, long recording times and compatibility with standard IT tools. Costs per GB are brought right down and higher-than-broadcast-quality image pipelines are made available even to low budget productions.
    552 x 389 - 68K
  • Arri also will introduce some new cam.
  • Aputure HDMI Extra scope
    Allow to add advanced functions to your monitor (including large ones) with build in battery.
    • Peaking
    • False colors
    • Zebra with selectable level
    • Histogram
    • Audio scope
    496 x 496 - 38K
  • Does the Lanparte BMPCC cage eliminate twisting?
  • Panasonic
    Starting 13 September, IBC 2013 will be held in Amsterdam. I would like to give all of you a preview of what we will have on display at the show.
    We have two main points we are trying to express:
    • improvements to the current HD workflows that support our users’ business
    • strategy for a future movement to 4K
    Panasonic believes that the simultaneous advancement of these two issues is extremely important.
    Following this line of thinking, at IBC we will be holding detailed demonstrations featuring content management systems and cloud-based solutions, as well as new file-based camcorders in our P2HD and AVCCAM lines, also a new “handy” studio camera, a new 2ME live switcher, and new HD production tools.
    We will also be displaying some solutions for “Beyond HD”, including our Ultra Wide Angle Camera system, which provides a stunning 64:9 picture.
    Finally, we will be making major announcements regarding our 4K strategy. I can’t say more than that at the moment, so ask that you please look forward to our press announcements from Amsterdam!
    For anyone attending IBC-come see us at Booth C45 in Hall 9!
  • Leave here note if you'll be at IBC this year.
