Let me amend and clarify my workflow a little bit. This is my workflow exactly. I work on Mac computers. Adapt it to the software and machine that you own.
All Pro level film workflows are similar to this. Keep in mind, most 35mm feature films have a Digital Intermediate that consists of DPX sequences. So the workflow was established using a model that had separate audio from video. All pro workflows separate audio and video and so that audio can be handled by a specialist. Yes, audio is THAT important.
1) Edit in an NLE. ----GET FILM LOCK!---- (can't stress this enough. Film lock means you are done editing. No more cuts need to be made. Keep in mind, Resolve 10 will allow further editing if needed.)
1A - If I need noise reduction I will export XML to AE, use GHrain Killer to reduce noise, and export the selected clips individually as ProRes444, and replace in the timeline in FCP X. But I rarely have noise issues anymore. [I'm hoping the new Resolve 10 NR functions which include temporal NR controls and features similar to GK will eliminate this step. [NR only available on full version of Resolve and not free "lite" version]
2) Export audio to Soundtrack Pro (or) OMF to Pro Tools or Logic (or whatever) for final sound mixing/editing. (If doing music video type work, this isn't necessary, just skip to step 8 on the audio side) I do all my audio in Pro Tools unless I need BG noise reduction, then I use Soundtrack Pro
3) Export your Edit via XML or AAF to After Effects/Davinci/SpeedGrade/Baselight or whatever platform you are using for grading
4) Grade - [I now grade everything in DaVinci using CG Pro] When grading in DaVinci use XML roundtrip to FCP function [ProRes444], but import the resulting XML into AE rather than returning to FCP (use Xto7 if necessary)
5) I do all my titles and graphics in AE, so this is never a problem. BUT if your titles are created in Motion, or in your NLE, export them in a format with an alpha channel for compositing. (Quicktime Animation with Alpha, PNG sequence, TGA sequence, etc.)
6) If your titles and graphics are not being done in AE, composite titles and graphics onto Graded Narrative in AE. I can usually skip this step, as all my titles and graphics are done in AE.
7) Export final narrative video track with Grades and composites out of AE to ProRes 444 or DNxHD 444 file.
8) Export sound mix as wav or aif file. (or in the case of surround, multiple files, or ac3 file)
9) Marry sound to video either in NLE with 32bit color processing, or in Quicktime Pro QT PRO users can hit "save" and skip to step 11 because all QT Pro will do is weld them together with no loss.
10) Export final product to high data rate 444 codec.
11) Using final product - make DVDs, Blurays, web videos, etc. (replace stereo audio with Dolby ac3 where appropriate)
Yes it seems a bit complicated at first, but it soon becomes 2nd nature. Adopt this and thrive.
Pro Tools
What are you using for audio? I'm still waiting on FCX/Logic X to have proper integration, but for now, I just use an ancient copy of Soundtrack Pro. Apple is soooo close (in my book) to having a stellar pair of programs for video and audio once again. Of course, Resolve is the ultimate in color programs, but from all accounts, it works just fine with FCX already.
always do audio separately.
http://www.personal-view.com/talks/discussion/comment/55553#Comment_55553
Great, looking forward to seeing more. I've pretty much bought everything you have for sale now. :) BTW, on your re-import to Premiere, do you have issues with no audio track coming in?
Resolve is always the best way to go.
As soon as the paint dries on my new office, I'll get moved in and and start cranking out tutorials. but it's pretty simple. Export XML, grade in Resolve, render footage, export XML, re-import to Premiere.
Bought Pro and played with AE a bit and it seems to me that Resolve is actually the easier way to go, even when you have to deal with round tripping. Shian, do you have a tutorial for roundtripping from Premiere and Resolve? I'd like to see your method to compare.
Thank you. Well done. :)
Ha! I took advantage of the Labor Day sale to upgrade to "CGT Pro Plus", I know I need what you're selling. I also plugged you this morning over on the COW in the SpeedGrade forum. Hows that? Thanks again @shain.
I know I shouldn't... and it won't do anything to change my image around here... but most days, I feel just like this.
per Vitaliy tech support should be handled through email or PM
yes Pro Plus is both
Oh wait.. I bought Pro and just noticed that the Downloads page shows a separate purchase for the AE Toolkit, is that correct? It looks like they are separate products.
User Presets. The video explaining how to create the User Presets folder is on the member page. They go in there. Then refresh the list, or restart AE, either will work.
I watched the install video but still don't see how to install the presets for AE on Windows platform? I put the CG Universal folder into 'C:\Program Files\Adobe\Adobe After Effects CC\Support Files\Presets' and still don't see the gears under Animation Presets.
@Shian Thanks man I used 2 GH2
Lenses:
Lumix- 20mm, 14mm, 14-140mm
Canon FD - 24mm, 28mm, 35mm, 85mm, 135mm
& 90% of the rigs I used they were from PV deals so BIG THANK YOU TO VITALY
@Aksel Wow. Great news. Congrats.
Glad ColorGHear was able to help in both departments, the final product looks great! What'd you shoot on?
ALSO 25% off storewide this Labor Day Weekend, so if you've been waiting for a deal... now is the time. Even 25% off subscription renewals.
@Shian thank you very much for all what you are doing. I have learned a lot from your tutorials & I am still learning. I am actually a director. but I like to know as much as possible about all the different departments so I can know what is possible & what is not in each situation. I just directed my first movie & because our budget was almost inexistent I had to be the cinematographer also. without your videos that would of been almost impossible. so thank you again.
PS we ended up selling the movie to TV channel in Morocco ;)
Teaser
this is the movie without CGH
This is the movie with CGH
sorry no English Sub yet. I am working on English & Spanish
What???? Me? Show off?? Unthinkable.
@shian Show off
Can't speak for everyone, but if you're doing it right, then you are using GHears for everything including primary correction or (the tech pass) as I did in this video.
Sorry if this is a dumb question but have to ask.. do you guys do primary correction first and then add gears or use the gears exclusively?
Shian ...
Even with 35 years as a portrait photog, owned/operated the studio and my own color-lab most of the years we were still film 'cause we were too damn picky for most pro portrait labs, and all my Zone VI lab gear for b/w, teaching Zone System et al ... learned a fair amount from your long vid over at ColorGhear on putting together the Zone System for video.
In all the use I've made of it, it's always been just for tonal control ... not particularly concerned with colors. Your emphasis on using it, and knowing the IRE ratings for a wide set of colors to plan the placement of colored items, such as walls, draperies, that sort of thing ... was quite fascinating.
Thanks a bunch ...
Neil
Wow...from 26min down to 5min. I knew AE was inefficient but, wow.
It's so frustrating knowing how indispensable AE is but at the same time how poorly it does so many things. Back before Puffin sold out to Pinnacle (to die a double death) I'd replaced as much of my workflow as I could with Commotion because what the two packages shared was so much better in the Puffin implementation (roto and tracking especially).
It's sad because Commotion, like Nuke and Katana, were created by actual visual effects professionals and not a software company with mostly academic experience. So much hardware gets thrown at trying to make After Effects faster when it's really a software problem.
@vicharris no clue
Some helpful tips for speeding up After Effects rendering
