Sony FDR-AX1 4K pro camera, $4500
    The Sony FDR-AX1 Digital 4K Video Camera Recorder is the first consumer 4K video camera from Sony. They've used the technology developed for their professional video cameras to create a compact, easy-to-operate 4K consumer model that's designed to make 4K video and professional-quality audio available to the masses. The FDR-AX1's powerful image processor is identical to the high-performance processors found in Sony's professional video cameras. By incorporating an image processor that can handle 4K video at 60 fps into a consumer camcorder, everyone will be able to document important family moments, get creative with friends, record sporting events and capture the world around them in lifelike detail. The FDR-AX1's native 3840 x 2160 4K resolution enables you to create movies with four times as much detail and quadruple the image quality of a Full HD 1080p camcorder. Plus, this model features a back-illuminated 8.3MP Exmor R CMOS image sensor that works in concert with the processor so you can record at the maximum frame rate - even when shooting 4K video. This means that even your high-speed action shots and sports videos will be clear, sharp and detailed.
    In order to provide 4K video recording in a consumer model, Sony designed the FDR-AX1 to support the XAVC-S 4K/HD recording format which is usually reserved for professional applications. However, since the XAVC-S codec will save as an MP4 wrapper, you can still create web-friendly videos that can be easily shared on social media sites like YouTube. Another highlight of the XAVC-S recording format is its ability to record images at 150 Mbps in 4K. In fact, it can record images at 50 Mbps even when you're shooting in Full HD 1920 x1080 resolution. The FDR-AX1 has also adopted a more professional-type of recording media thanks to the inclusion of dual next-generation XQD media card slots. Both XQD card slots support fast 4K/HD writing and reading rates. Plus, you can use the relay recording function to switch between XQD slots and lengthen your recording time. You'll also be able to quickly transfer footage via SuperSpeed USB 3.0 from your XQD cards to your PC by using an optional XQD reader/writer with a USB 3.0 connection.
    Another feature that makes the FDR-AX1 a professional-class consumer video camera is its audio recording capability. It records 2-channel Linear PCM audio with a built-in high-performance stereo microphone. However, the camera also features dual integrated professional-class XLR audio inputs for connecting external microphones. You'll even be able to mix audio tracks from the internal microphone with the audio recorded from any connected external mics. There are a variety of shot-enhancing functions and manual control options as well. More experienced videographers will be able to take advantage of the independent zoom, focus and iris rings. Plus, the camera's viewfinder and LCD monitor employ Peaking, Zebra and Center Marker functionality for more advanced shot setup and autofocus options.
    Other image-enhancing features include three ND filters and five unique Paint functions, which will help you achieve a more cinematic aesthetic with your movies. The FDR-AX1 has flexible connectivity options as well. Besides the XLR audio inputs, the camera is equipped with a headphone jack, an HDMI output that will transfer 4K footage to compatible 4K Bravia TVs, a USB 2.0 port for fast data transfers, an analog A/V output, an accessory shoe and more. With the flexible connectivity options, professional-class features, 4K recording capability and ease-of-use, the FDR-AX1 bridges the gap between consumer and professional-class. While experienced videographers will be able to really produce great video and audio with this model, even ambitious beginners will be able to master this camera and capture professional looking, cinematic 4K video with ultra-clear stereo audio.
    Capture 4K 3840 x 2160p Video at 60 fps
    This model supports 4K 3840 x 2160 resolution. With four times better than Full HD 1080p image quality, you'll be able to capture the finest details at high resolution and produce vibrant, realistic images. Plus, the fast image processor is the same one employed in professional Sony models, making it possible to record 60p movies at the camera's full resolution for smooth playback with no loss in realism - even when panning the camera and shooting moving subjects.
    Sony G Lens with 20x Zoom
    The Sony G Lens is an aspheric lens with special low-dispersion glass. It's specially tuned to capture subtle qualities of definition and color. In addition, the lens offers a broad 20x optical zooming range with a 31.5 - 630mm (35mm equivalent) focal length that enables an expansive range of video expression.
    1/2.3" Back-Illuminated 8.3MP Exmor R CMOS Image Sensor
    Sony's unique Exmor R CMOS sensor has a back-illuminated structure with wiring layers on the back of a photodiode (light receiving element) that dramatically boosts low-light sensitivity for shooting more lifelike images - even in dim lighting. This Sony technology also makes the camera nimble, so it can read massive 4K data at 60 fps.
    Professional Image Processor for Real-Time 4K / 60 fps Recording
    The FDR-AX1's image processor is identical to those in 4K camcorders used by professionals. It rapidly processes signals transmitted from the CMOS sensor and finalizes images. In processing the vast 4K data in real-time at 60p, the processor achieves four times the resolution of the Full HD 1080p format. This processor also features high-performance noise reduction for truer images, while image quality adjustment functions support greater freedom of expression. It is also specially tuned for the FDR-AX1 to deliver accelerated image processing performance.
    XAVC-S Consumer-Use 4K/HD Recording Format
    The FDR-AX1 records 4K/HD movies in the XAVC-S codec, which was developed for consumer usage based on the professional XAVC 4K/HD codec. XAVC-S uses MPEG-4 AVC/H.264 long GOP for video and LPCM for audio compression, while saving files in MP4 format. The XAVC-S codec also allows longer recording times within a given media capacity than XAVC, making 4K recording easier and more convenient.
    XAVC-S 150 Mbps 4K Video & 50 Mbps HD Video
    With the FDR-AX1, high-quality XAVC-S video can be recorded at up to 150 Mbps. Additionally, there is also an option to record high-quality Full HD 1080p video at 50 Mbps.
    Dual XQD Media Card Slots for High-Speed 4K Recording & Playback
    The FDR-AX1 features two XQD media card slots. XQD media cards provide smooth, high-speed reading and writing of 4K/HD video. Plus, a relay recording feature makes it possible to lengthen recording by automatically switching between two or more media options. You can quickly transfer data to a PC as well, by using an XQD reader/writer with a USB 3.0 connection. The FDR-AX1 is compatible with S-Series, H-Series and N-Series XQD media card types.
    View 4K/60p Video on Compatible BRAVIA TVs with Supplied HDMI Cable
    The FDR-AX1 supports playback of your recorded 4K content on a 4K TV by simply connecting the two devices using the supplied HDMI cable. Thanks to the camera's original function, you'll be able to transmit 4K/60p (4:2:0, 8-bit) signals to a Sony BRAVIA 4K TV, which is specially tuned to bring out the full quality of your 4K/60p video recordings. Even fast-moving sports and action footage will be clear and smooth. To enjoy this content on a Full HD monitor, simply change the menu HDMI output settings to 1920 x 1080. If you have a 4K monitor, you can use the supplied HDMI cable to transmit 4K/30p signals from the camera to the monitor.
    TRILUMINOS Color Technology
    The FDR-AX1 supports Sony's TRILUMINOS Color technology, which allows you to view photos and movies in rich, natural colors on any TRILUMINOS-equipped television. The expanded color gamut ensures lifelike, vivid colors when you playback your recorded video and still shots.
    Save 4K Video Content to Your PC
    The FDR-AX1 provides two methods for connecting and transferring footage to a PC. You can use a USB cable or insert your XQD memory card into an XQD reader/writer that is connected to your PC. You can also save data from the camera to other media sources like external HDDs. Once you've download data onto your PC, you can use Sony's PlayMemories Home software to manage and play your videos. You can edit video with the XAVC-S-compatible non-linear editing software as well. After your footage is edited, you'll be able to upload and share your 4K movies on social media sites like YouTube.
    Built-In Microphone & Professional-Class Audio XLR Terminals
    In addition to a high-performance internal microphone, the FDR-AX1 features two external XLR jacks for connecting external microphones that can also be used to record superior-quality audio together with your movies. You can also mix audio from recordings made using the internal microphone and externally connected microphones, respectively.
    Three ND Filters & Five Paint Functions for Expressive Cinematic Looks
    The FDR-AX1 features three ND filters for adjusting the amount of light entering the image sensor from the lens. There are also four filter settings: Clear, 1/4 filter, 1/16 filter and 1/64 filter. These filters and settings give users the ability to match shooting conditions, as well as adjust the shutter speed and aperture even on bright, sunny days. There are also five paint functions (white balance, gamma, detail, skin detail, matrix) that can be combined and adjusted in the paint menu to create expressive movie styling such as cinematic looks.
    Seven Assignable Buttons & Three Independent Control Rings
    The FDR-AX1 was designed with two start/stop buttons. One is located on the side of the camera grip, while the other is located on the handle. This affords ease-of-use while shooting. The handle also features a zoom button that enables convenient access while shooting from low angles. There are seven assignable buttons as well, which can be programmed with functions that enable users to quickly access them without using menus. Assign functions include: Marker, Zebra, Peaking, Focus Magnifier, Auto Exposure Level, SteadyShot, Color Bars, Rec Lamp [F], Rec Lamp [R] and more. Having seven assignable buttons will allow you to adjust to varying shooting conditions on-the-fly. There are also three manual control rings on the camera for focus, iris and zoom.
    Zebra, Peaking, Center Marker & Guide Frame
    Shooting tools such as Zebra, Peaking, Center Marker and Guide Frame are designed to assist you in shot setup. They'll help you get the cinematic expression you are after. Zebra highlights overly bright areas with stripes in the LCD and viewfinder. This feedback helps users adjust brightness and prevent whiteout, especially on the subject. Peaking simplifies focusing by highlighting in the LCD and viewfinder the areas most sharply in focus. Users can finely adjust the peaking level and choose white, red, yellow or blue peaking to clearly contrast with the subject. By making it easier to know where the shot is in focus, this feature helps users achieve the desired manual focus setting. Determine the center of your image at a glance using the Center Marker feature in the LCD or viewfinder, while the Guide Frame works as a guide for aligning horizontal and vertical lines.
    Specs:
    • 1/2.3" back-illuminated Exmor R CMOS sensor
    • 18.900,000 pixels
    • Sony G Lens with Optical SteadyShot image stabilization
    • 4.1 - 82 mm F/1.6 -F/3.4 (31.5 - 630 mm )
    • Filter Diameter - 72 mm
    • Minimum Focus Distance - 0.4" (1 cm), tele - 31.5" (80 cm)
    • 6 aperture blades
    • ND Filters - Off, 1/4, 1/16, 1/64
    • Rings - Focus ring Iris ring Zoom ring
    • Video modes
      • 4K: 3840 x 2160p at 60 fps (150 Mbps)
      • 4K: 3840 x 2160p at 30 fps (100 Mbps)
      • 4K: 3840 x 2160p at 30 fps (60 Mbps)
      • 4K: 3840 x 2160p at 24 fps (100 Mbps)
      • 4K: 3840 x 2160p at 24 fps (60 Mbps)
      • 4K: 3840 x 2160p at 50 fps (150 Mbps)
      • 4K: 3840 x 2160p at 25 fps (100 Mbps)
      • 4K: 3840 x 2160p at 25 fps (60 Mbps)
      • HD: 1920 x 1080p at 60 fps (50 Mbps)
      • HD: 1920 x 1080p at 30 fps (50 Mbps)
      • HD: 1920 x 1080p at 24 fps (50 Mbps)
      • HD: 1920 x 1080p at 50 fps (50 Mbps)
      • HD: 1920 x 1080p at 25 fps (50 Mbps)
    • Dimensions - 7.44 x 7.6 x 14.25" (189 x 193 x 362 mm) including NP-F970 battery
    • Weight - 5.38 lb (2.44 kg) camera only , 6.1 lb (2.77 kg) camera and NP-F970 battery
    Available at:
  • 47 Replies sorted by
  • No genlock.
  • Almost as good as the Samsung Note 3~!
  • Sony is teaming up with the Napa Valley Film Festival showing off the latest Sony gear and films in the Sony lounge.
    This year, we’re kicking off the first NVFF SONY 4K FILM CHALLENGE, a timed filmmaking competition starting Tuesday, November 12th. Armed with the Sony 4K Handycam Camcorder, five teams will embark on the 60-hour challenge to craft a short film based on randomly-assigned topics. Each team will receive genre, prop and location requirements, after which it’s up to their creative ingenuity to craft the ultimate short film.
    http://blog.sony.com/2013/11/sony-at-the-napa-valley-film-festival/comment-page-1/#comment-31009
  • After doing an apples to apples comparison with the GH3, I can see there is a substantial increase in detail. The fact that I can actually see noise and artifacts on the still frame is throwing me, but I better reserve judgement until I can compare the final output in typical circumstances.
  • I have been testing for a few hours. This has one of the worst pictures I have seen on almost anything. I can't imagine how Sony produced the sample videos on this. Noise and artifacts are visible and obvious everywhere and DR is minimal. Other than that, the hardware is beautiful and it keys rather easily. If someone can suggest what I might be doing wrong, I would appreciate it. I am viewing in Premiere Pro CC, WMP, etc.
  • Yup--but someone will also make a 4K camera with a larger sensor. I'm looking forward to 4k, but not replacing ten cams. I may have to wait till the price drops.
    Yes, of course. But some people want 4k right a way. Sony offer them good option. Far from perfect, but in good light it is good camera.
  • @DrDave
    I think it is more funny that we have such complains :-) As people who will buy this camera know that they are doing.
    Same shit happened with HD transition with threads full of complains. It'll all pass.
  • Does anyone besides me think it is funny that this $4500 Sony cannot compete in Low Light with a mid-level Camcorder like the Canon M400 (used ~$250)?
  • The combination of a small sensor packed with a great amount of tiny pixels doest not do well to the low light capability of this camera.
    LOL. Surprise, surprise.
    Even with larger cameras you'll see higher pixel noise.
  • "I would expect this kind of high resolution small sensor handheld camera to be a great working tool for anyone who is doing “run&gun” events, documentary style shooting and even covering sport. I would expect such a camera to perform well in all lighting situations but unfortunately this is not the case with the new Sony FDR-AX1. The combination of a small sensor packed with a great amount of tiny pixels doest not do well to the low light capability of this camera. As you can see in the various sample footage I took, even using the gain control did not help much improving the overall dark images the camera produces. (see Oriental flavor-Night video). Instead, noise was added to the picture. (all in all I’ve used gain 3db, 6db, 9db up to 12db)."
    http://www.cinema5d.com/?p=21457
  • Having a 8MP frames to choose, i think this camera could be the all in one-holy grail for wedding photographers. Sony is moving forward! (Finally)
  • Hmm, this is cool. But it is best to make separate topic for it.
  • @mpgxsvcd
    Check first post in topic.
  • What are the lens specs on this camera?
  • @killagram
    May be. Price was present on B&H and Amazon :-) So it is correct.
    It was also told at IFA and present on the sites who make coverage.
