Any good? Looking to grab these for interviews.
I think you can find those much cheaper. They look exactly like ones you can get off of amazon and ebay for under $200. The case even looks the same. Just re-branded. If they are, they don't look too bad but they are fragile. Better suited for studio use where you won't break em down after each shoot. Pretty green too but nothing some -green couldn't handle. Not bad for under $200, pretty damn expensive for $545. Where are you located?
@vicharris Brisbane, Australia.
Yep, there's a long topic about it here. I actually resold these in LA for a bit till I developed a guilty conscious because of their quality.
@azza_act http://www.hypop.com.au/continuous-lighting/photography-rectangle-soft-box-lighting-set.html
same quality ... cheap and nasty ... they work
Even cheaper. Same shit, Different company. Throw some ND in the front if you need to dim em! :)
I suggest to get ones with 5 lamps socket as they can be all individually switched. here only by pairs.
So you won't need NDs in such amounts :-)
Isn't one of those the 5? That is the one I would recommend, yes. Since like you said, it has the 5 separate switches on the back. They all still need at least 1/4 minus green as an fyi but now I'm feeling I'm just repeating the other topic! I will stop now. OP, go find the other topic :)
I use a 200w CFL mogul base bulb rated 90 CRI that I got off Amazon for about $100/bulb. Its output is equal to roughly a 800w tungsten, and it comes in a protective box. With a Chimera Triolet and softbox, you have a powerful but portable key interview light.
Thanks for the links guys. But one thing, do they have the "green" cast?
