@robertGL I spotted the 64 Go Komputerbay x1000 which are said to be the best. and its great so far. Yet I have a different camera (5DMKIII). My CF Reader is Lexar USB 3 (CF+SD) which is really fast (as long as you plug it to a native USB 3 slot)
My komputerbay 32gb 1000x card got corrupted almost immediately after putting it in my 50D. I'm suspecting my card reader did it in.. what kind of card reader do you have?
@driftwood Great news Nick ! I'll be definitely looking for your LUT. Yet the "BMD Film" + little contrast fine tuning is really nice. I agree that Hunters is really bright. (too bright) It seems more a "glamorous wedding films" LUT that Cinema LUT. (to my eye)
@driftwood looking forward to it! Thanks for taking the time doing something that I'm sure tons will benefit from. Cheers!
Ive been working (still am) on a LUT for the ML RAW DNGs match for my DELL U2713H and the U2413 14 bit programmeable LUT monitors. Its a very difficult and time consuming task. Huge range in the matrix which needs constant refinement. Hunters is good but I tend to agree its a little bit too 'bright' in the highlights and contrasty colours (but it could be the montors) - I prefer a classic film print look and I've been comparing countless LUTs in Resolve in an effort to make one which works with my grading/setup.
@thepalalias, the Minolta to EOS adapter I use it this one.
I must say that it has a very nice and snug fit. Seems to work well. I haven't compared it to any other make, but it seems to be doing a good job. I have this adapter, the 50mm 1.4 Rokkor X and an Anamorphic lens on the 50D and it all hung on there pretty well. Of course i'd suggest a lens support, but even without it I wasn't noticing any issue with the adapter.
@muddmanrich Yes they are.
(my god, it's creator will hate me right away :))
Haha, i'm sure you'll survive. Juan Melara's LUTs you referred to are the ones found under this link?
http://juanmelara.com.au/print-film-emulation-luts-for-download/
@muddmanrich you're welcome. Also keep in mind that Hunter's LUT is not a rock-solid industry standard LUT, it's nice but kind of "home-made" and Beta. (my god, it's creator will hate me right away :)) it is more Videoish than filmic (mimic Alexa Rec.709) You may try LUT from Juan Melara blog or others LUT straight coming from Industry DI Lab (ok that's the hardest to get... especially in Europe where Lab are totally Paranoïd with sharing their LUTs)
@ghostlayer makes sense, I'll give it a try as well. Tks.
@muddmanrich I am pretty new to Resolve too. I've asked Juan Melara (http://juanmelara.com.au/) here's his answer to "our" question : +++++++ If you are using the BMD Film setting, I wouldn't apply the log LUT. Using BMD Film is the exact setting you should be using. It is getting your footage into log gamma space. Any difference you are seeing between shots is because the exposure is different. This happens to footage from all cameras.
If you still have too much contrast try removing it using the contrast/pivot control under the log colour wheels. Or try balancing it out by using the log or lift gamma gain colour wheels. ++++++++
I haven't had time to try but I'm pretty sure I'll follow his advice (his blog is awesome on color grading) he also provides LUT
@ghostlayer: Yes I know, flat profiles should be the way to go, but the direct import with this settings is already quite more flat than the original look, allowing a fair amount of color correction. I think the ranges it brings in the scopes are enough for my color correction needs. :)
The most difficult is to get a correct LOG/flat from DNG. (as Cinestyle wont apply)
Yeah likewise. I've found that setting the clips to "BMD Film" helps, but it is still not a totally LOG/flat image and adding a LUT like Hooks or Hunters often makes the footage look overly red and saturated. So you tweak it further before adding the LUT or after? I have the 50D so I'm sure it's not completely the same in regards to grading but any tips help as I am pretty new to Resolve. I look forward to seeing more of your footage!
@Wilbo Take your time..
@Aria So which adapter do you suggest for the Minoltas on the Canon APS-C cameras like the 50D?
@Wilbo yes it does
@ghostlayer damn, that 5dmk3 footage is looking good :)
@Aria and @TrackZillas Man, I would really like to join the 50D club... really need to think things through (money wise)... really enticing :)
-W
@jazzroy thanks for sharing your workflow. "BMD film" brings a LOG aspect to the footage, usually LOG footage are to be graded using LUT (at least on the long feature films I have worked on) For like 4 years now, flat looks became trendy looks (Cinestyle,Prolost Flat, Marvel Cine, Flaat), and many DSLR filmmakers and colorists have considered it almost as a final look/grade (super desaturated and low contrast) whereas it was made to prepare footage before applying the proper LUT. (often contrasty with real deeps blacks) Anyways Color Grading deals with personal taste a lot.
@ghostlayer: I simply convert with raw2cdng.exe, config Davinci camera raw config with Project-cinemadng-project/as shot/BMD/BMD with recovery highlights on and they are good for color correction without any LUT applied.
@peaceonearth: nice one, it made me laugh! actually they are both friends of mine, and she's a good cameraman (or camerawoman?), but better than me at cooking!
I just can't recommend getting a 50D highly enough. It's so cheap for the chance to play around with RAW recording and Magic Lantern is making it better and better every day. Moreover it's a really terrific camera. So solidly built. The talk now is that Mosaic Engineering is making a 50D VAF Anti Aliasing filter and that would be awesome. Overall it's still a developing story, but you can actually film with it right now, just not as conveniently as more mature systems. But you can't beat it for under $500.00.
I've been testing with my Minolta Rokkors and actually the adapter I bought is better than the one I had for my GH1. Got lucky with that.
@Wilbo The 50D is a solid camera.. great choice by getting the BMCC instead of the BMPCC more bang for your buck that's my next camera. For time being I'm all 50D and my awesome GH2.. It would definitely be a great option for you while you wait for your BMCC, most importantly to get your feet wet with Raw learning the workflow. Let me know if you decide to get the it so I can welcome you to the 50D club :)
