Panasonic G6 topic, GH2 replacement camera
  • 1330 Replies sorted by
  • Got to second @c3hammer there. Have shot hours of footage on the G6 and am still surprised how the video codec holds up. 50p is not as rich as 24/25p admittedly. But shooting in 24/25p on a fisheye with infinity focus and loads of detail, results are still very good. My guess is that the much improved NR in the G6 improves compression effiency quite a lot. Of course some instances where my hacked GH2 still has upper hand, but the difference is not so much as I would have thought. For documentary shooting, I find myself reaching for the G6 more than the hacked GH2.
  • Here's my first sample of 1080-60p slowed to 24p. This was all shot with the G6, a Nikkor AIS 600mm and a Lumix 100-300
    Don't know about any mud or artifacts in any shots I've ever taken with this thing so far. I use this cam for the high detail ETC and for it's ultra light weight on a jib pole stabilizer I've been developing. The only artifacts I've ever seen with it so far is dimly lit shadows in etc mode show fixed pattern noise that is pretty bad.
    Cheers, Pete
  • @neokoo right! landscape with a challenge or unreasonable: mud artifacts. . . Therefore, the GH2 remains until further notice the number 1
  • @sammy
    I shoot 50p most of the time, not so much for slowmo but for HFR aesthetic, with fairly high image quality requirements. Too high in fact for G series price range, but isn't that true for most of us here... Anyway, used to have a hacked GH2, now using G6. In my experience, whether 1080p50 on unhacked G6 is better than 720p50 on hacked GH2, depends on what you're shooting.
    Video codec on stock G6 seems to be optimized for capturing people from close range, at least that's where I've had best results with it. If it's well-lit people, not moving very fast, in close to medium shots, then stock bitrate 1080p on G6 might be sufficient and resolution increase over 720p a visible improvement.
    But in highly detailed shots, landscapes, available light documentary, fast movement, shakycam etc., the low-bitrate codec of G6 can cause artifacts, and high bitrate 720p on GH2 might be better. Hacked codec on GH2 can retain more information, both spatial and temporal, even if pixel amount in video data is smaller. While it won't be as sharp as real 1080p, it could be more pleasing to look at than 1080p with compression artifacts.
  • @woolhats, I never actually tried it. It does work, Sorry for the bad info.
    I would swear I read that it didn't work in 1080-60p with avchd. I must have just confused this with the GH3, which I don't believe will shoot with ETC and 1080-60p at all. It was the reason I hadn't considered the GH3. Now I'm not so sure that is true either though :)
    @sammy 1080-60p is full quality and significantly higher resolution than 720-60p at the stock bit rate. I don't have a GH2 so I can't compare to the high bit rate 720-60p clips.
    Cheers, Pete
  • What's the feeling regarding 60p for slow Mo on the g6 1080p vs gh2 only 720p .has anyone compared the 2 for 60p ..I just got the bmcc mft and woundering if its worth the change to g6 from gh2 just for better slow motion results ...thanks
  • c3hammer-"Most importantly, the G6 doesn't shoot with ETC at 1080-60p in avchd. Only in mp4". Thats not true! No problem shooting ETC in avchd 50p...
  • MP4 and avchd use the same h.264 video and acc audio encoding, just a different transfer stream. Also mp4 doesn't have all the avchd bd junk associated with it. Most importantly, the G6 doesn't shoot with ETC at 1080-60p in avchd. Only in mp4. Every clip I've ever shot with the G6 has been in mp4.
    I bought the G6 specifically for filming wildlife. I use the ETC and 1080-60p with either a 600mm Nikkor AIS or the 100-300 Lumix almost exclusively.
    I posted a video with mostly long range, 3000mm equivalent shots of some north american elk earlier in this thread. There is one wide shot of some green aspen trees and a little red dirt road later in that video that shows the ultra fine detail achievable with 1080-60p in wide landscape tyoe shots.
    Cheers, Pete
  • @C3hammer Hi Pete, I was going to post some up but I'm was only using AVCHD not MP4. I thought MP4 has lower IQ?? I'll have to give it a try! When shooting 25p in AVCHD I've been fairly impressed... It's super sharp, including wide shots. Love to see your work too using the g6 :)
  • @ azza_act,
    Do you have any samples of this? I've had great results with 1080-60p, mp4 encoding on my G6.
    I have found the G6 to be exceptional with wide detailed shots. I'll have to admit that most of my truly wide shots have been with the new 14-42 II kit lens. It gives super clean images at 14mm in landscapes. I also have some sample shots from a 12-35mm at the camera store. That lens is completely amazing from every thing I captured with it. Other samples are with a vintage Zuiko OM 24mm f/2.0 or almost a 50mm equivalent. While not wide by any means, it gives incredible landscape video. Same with my OM 50mm f/1.4 when shooting mountains and moving cloud formations.
    My only issue has been been with low light landscape shots. You can really see the fixed pattern noise at any ISO when the light is too dim. I can be very appearant when exposing for ultra bright clouds in the shadows and dark pines.
    Cheers, Pete
  • Yeah, the g6's 1080 60p isn't very good on wide shots... Pretty disappointing. Anything close it's fine but filming wide detailed shots it falls apart.
  • Just few days my GH2 has a new friend (would say - girlfriend :) ) - G6 with new 14-140mm. Nice kit. What I like most about G6 that with non original batteries (I have two Patona brand) it shows battery icon and it works what was impossible with GH2! It alone worth to buy G6. This cheap thing is cheap to use too. And yes, EVF on G6H2 is more better to focus than with G6. But LCD is really good, just need a good LCD viewfinder for it. And for delicate G6 body - cage. Maybe somebody has found it for G6 which will fit this little buddy?
  • @Stonebat Hehe! No, I'm the Swede with a longing for a true Panasonic eye cup :-)
  • Hello, I'm a pianist and I use one fz200 and one LX7 to shoot piano videos. Do you think the G6 would be more better about this video? I think in buy the G6. Please, watch in 1080p.
  • @oscillian Are you the canadian? My memory is fading. If yes, do u need to make a different eye cup design? I was hoping GH2's work on G6.
  • I have HyperPrime 25mm 0.95. Yes it shows CA at 0.95. Yes I miss GH2's aliasing prone EVF.
    I hate Panasonic.
  • And concerning our perpetual pet peeve: adding an eye cup is a bitch :(
  • @Stonebat It depends on how critical your focusing is. I'm talking about very shallow 0.95 DOF when the blue peaking graphics actually are in the way of seeing where focus lands. In a close up its the difference between nailing the eye leashes or the eye's iris. The GH2 EVF makes a subtle kind of aliasing effect on stuff in focus. But for wide and mid shots it poses no trouble and actually helps compared to the GH2.
  • Darn... why did I sell gh2 :(
  • @Stonebat The G6 EVF is better color wise, but the GH2 is sharper and has no edge blurring depending on your viewing angle. Peaking helps a lot for focusing (in good lighting) on the G6, but I can more easily pull focus with the Nokton 25mm on my GH2 and nail even eyelashes on close ups.
  • @eyenorth Yeah in theory in-body NR should work better than post-processing NR. G6 sounds like the good case.
  • How's G6 compared to GH2 in terms of EVF performance and hotshoe build quality? No I'm not a troll!!!!
    Thanks.
  • Don't have a beef in this eoshd thing, but I read his review and mostly agree. Have brought the G6 along for several jobs now, and it's such a joy to use and the images it produces very nice - brings a smile to my face. Having owned both the d5200 and the G6 I would also say the G6 is more usable in low light even though you can't crank the ISO up to 25.600. The NR in the G6 is quite non-intrusive to the image and produces usable material at high ISO's. The d5200 pretty much falls apart in mid-range luminance levels and below once you touch the ISO dial.
  • OK so i test it a little...
  • Isn't it kind of funny and tongue and cheek? I think it's a stretch to think calling someone 'Voldemort' is bullying them. I mean he was kind of a badass, just also, you know, basically the source of all evil. So...exactly like EOSHD!
