Metabones lens speed booster adapter, focal reducer
  • 873 Replies sorted by
  • Funny how much this topic picked up after they release an mount that most people actually use... now if they'd only come out with the EF version already...
  • Light falloff is mostly due to the lens (not the SB), and maybe a little due to the lighting.
  • @brianc1959 (a big!) thank you sir. Looks fantastic and as if most people will have to adjust their SB's rear element to get results like that.
    Is the light falloff on the edges of the chart due to the lighting? or the SB?
  • Below are some test shots using the SB with a Nikon 50mm f/1.2 AIS lens on an Olympus OMD. The first three are at f/1.2, giving a 35mm f/0.90, and the second three are at f/2.8, giving a 35mm f/2.0.
    640 x 480 - 126K
    640 x 480 - 93K
    640 x 480 - 100K
    640 x 480 - 133K
    640 x 480 - 93K
    634 x 480 - 117K
  • Another example, although almost everything in close up. Click on "Metabones Speed Booster Test" https://vimeo.com/user1449917 Can't imbed directly due to vimeo permissions.
  • Nikon DX has a 28.4 mm image circle diameter. 28.4 mm x 0.71 = 20.2 mm.
    • GH2 16:9 non-ETC: 21.4 mm diagonal
    • GH3 16:9 non-ETC: 19.8 mm diagonal
    • BMCC: 18.1 mm diagonal
    • BMPCC: 14.3 mm diagonal
    So on the GH2, it's close. It will depend on the particular lens, like mcbob's tests showed. The other cameras are fully covered.
  • Keep in mind a 16x9 image on DSLR's and the mirrorless cameras is a crop of a 4x3 or 3x2 frame meaning there is some room to have a slightly bigger FoV that will be ok. All tests I've seen say the standard 16x9 image on any MFT camera's (except the GH2) with all lenses tested seem ok. The issues seem to be with the GH2 and other MFT cameras shooting stills in taller aspect ratio's.
  • "Working" and "covering" are two diffrent things; DX lenses designed for a 1.5x crop sensor may or may not cover the lesser 1.3-1.4 crops of MFT+SB cameras.
    I had a quick chance to fondle a bunch of DX lenses at a local camera store to check their coverage on the GH2 + SB (effective video crop ~1.32?). Here's a quick list of coverages:
    Sigma 10-20 (full coverage) Nikon 10-24 (very slight corner darkening) Nikon 16-35 (corner vignetting throughout range) Nikon 18-200 (slight corner vignetting throughout) Nikon 17-55/2.8 (full coverage)
    Also tested the Rokinon 8, 35, and 85 primes which worked spendidly; the 8 did have plenty of fishy wierdness at the edges, but that's expected.
    The 18-200 and 16-85 were the only two of the lot that had what I'd consider unacceptable vignetting. The 10-24 was very useable, and the Sigma 10-20 and Nikon 17-55 delightful.
  • @ahbleza Looking forward to your tests. Thank you!
  • Their answer says it all, you just need to use the aperture ring on the adapter. It will work.
  • I was asking him about an specific lens, the new sigma 18-35 1.8 (http://www.bhphotovideo.com/c/product/967345-REG/sigma_18_35mm_f1_8_dc_hsm.html)
    maybe that's why I got that answer, I am sorry about the confusion I am really unfamiliar with Nikon mount lenses.
    But thanks for the answers, I think I understand a bit better now.
  • The MetaBones adaptor (as with my other two MFT adaptors) each have a mechanism for manually controlling aperture. You can use the Sigma with Nikon interface just fine, but expect to change exposure by hand, and not through any electronic interface.
    For those who are expecting a more extensive test, I will be shooting some BMCC with MB-SB tomorrow, and am in pre-production for a TV pilot to shoot later this month, so there's plenty of footage coming soon. I've also pre-ordered the new Sigma 18-35, and will shoot a test with it as soon as it arrives, which is likely to be by the middle of August.
  • "I went back and read a bunch.. but not every single page... im just extremely confuse about it because after sending a mail to Metabones they answer to me saying that the adapter wont work with the sigma lens..
    "Sorry! Our nikon g adapter have not electronic control……only support manual focus and manual aperture control. You can use your sigma Lens on it, but need use adapter ring for aperture control"
    so i wanted to check here with some of you, that's all, sorry if I bother anybody.
    thanks!"
    Nikon G itself means the lens has no aperture ring, so if an adapter is a Nikon G adapter it will work with Nikon G lenses (including 3rd party Nikon G mount lenses). You don't need electronics to control the aperture on Nikon G lenses. Nikon G adapters just have an adapter ring on it to move the lever on the back of the lens.
    648 x 504 - 135K
  • I went back and read a bunch.. but not every single page... im just extremely confuse about it because after sending a mail to Metabones they answer to me saying that the adapter wont work with the sigma lens..
    thanks!
  • @RRRR, thanks, I thought I was taking crazy pills the past few months or something :)
  • @vicharris not quite on topic but yes, there seems to be a lot of new posters who have not read anything from before. Maybe some old ones who are lazy, too.
  • @oscillian, sort of yes.
    Looking forward to some comprehensive testing.. (not just one tester, one SB, one lens).
  • All Nikon Mount lenses except for the one mentioned by MB will work..........period. Seriously, I really am starting to think nobody reads any past posts in threads anymore. This is happening all the time now, I really don't understand it. For people who have been here for years, is this normal or has it ramped up the past couple months?
  • Wow! So it works... and those lenses don't have a manual aperture control right? and the adaptor works.. thanks so much for your answer!
    C.
  • @CHARPU I'm using Sigma lenses with Nikon mounts, and they work perfectly on the Metabones Speed Booster. I'm betting the 18-35 will be usable just fine, since my other Sigmas also work.
    Here's a test I did:
  • wait a second, so we can use the adaptor for sigma lenses? I thought it only works with manual aperture? Will we able to use it on the sigma 18-35 1.8 if we get it on the nikon mount??? Im really wondering... anybody knows the answer?
  • Shouldnt we expect the Speedboosted Tokina 11-16 to look the same as if mounted on a APS-C sensor? On my old Nikon D80 it's no way as blurred in the corners. Let's see if someone dials in the back focus correctly before we give up all hope for a fast and wide m43 lens.
  • A curved focal plane (corner sharpness dropoff) is to be expected on a wide and fast lens, though it looks rather severe, a bit like the slr magic 12mm. (other wide lenses might be a better fit wide open - I´d look at slightly slower lenses for better overall sharpness) Question is what happens when you stop down?
    For me, the c/y speedbooster works great with the 28mm f2 even wide open. I´d say the lens looks better than cropped.
  • @Brian202020 +1 & +1 I had the privilege of ordering 2 LCs! They were both identically baaaaad!
  • You can see some sharpness on the items on the sides of that image. It might not be perfect, but I can tell you that image looks ten fold better than the Light Cannon images.
